Drivetrain Hood Vents-part 3
Old Nov 8, 2006 | 10:37 AM
  #126
MSFITOY's Avatar
MSFITOY
Originally Posted by DrPhilGandini
I'll try to do a drawing, sometime between sleeping, looking after kids and work...
It's a half-baked idea!
I prefer my meat medium-rare so you're on the spot Phil...
Old Nov 8, 2006 | 10:52 AM
  #127
Partsman's Avatar
Partsman
Legion_of_Doom
That's how they all start out.
Old Nov 8, 2006 | 11:54 AM
  #128
Bahamabart's Avatar
Bahamabart
Actually, alcohol is the primary generation of new mods. Thats what they mean when they refer to creative juices flowing .
Old Nov 8, 2006 | 12:06 PM
  #129
Partsman's Avatar
Partsman
Legion_of_Doom
DrPhil said half-baked. That's how mine used to start out, back in the day.
Old Nov 8, 2006 | 01:24 PM
  #130
MSFITOY's Avatar
MSFITOY
A good dose of "courage" is what I started with before ripping into the hood...not too much though...that could lead to disaster
After a successful surgery...then we can work on the hangover
Old Nov 8, 2006 | 01:28 PM
  #131
WeeGas's Avatar
WeeGas
Ryan, I think you misunderstood in the PMs.
I am making one IC out of two stock units.
Would be cool to have dual ICs, but that would be some work.
I thought you were just messin' around in the PM.
Oh so you're making one UBER IC instead of the puny stock IC. Wouldn't it be better to use a high efficency IC (air to water or a sprayer) than one Giant IC? Although dually IC would be cool looking.
Old Nov 8, 2006 | 02:39 PM
  #132
Partsman's Avatar
Partsman
Legion_of_Doom
Ryan, what the hell is a UBER IC?
Water to air is nice, but adds weight and is expensve.
What I am doing is using the cores from two stock ICs, cutting them apart, and reassembling them so the ambient air coming through the scoop flows front to back like a DFIC, as opposed to top to bottom, like the stock IC.
The stock IC is actually pretty good, but it's drawback is the way the ambient has to go through it.
Old Nov 8, 2006 | 06:18 PM
  #133
WeeGas's Avatar
WeeGas
UBER IC = Super IC. It sounds like the setup you'll be trying to put in will be pretty nice. Are you going to dyno the car after installing the new IC setup?
Old Nov 8, 2006 | 06:56 PM
  #134
Partsman's Avatar
Partsman
Legion_of_Doom
I'll probably run it up to Swift to see it the crank pulley, pre-cat delete, resonator removal did anything.
It's very difficult to dyno an IC change without the proper facility and airflow simulation.
Will you be at MINIs Making-A-Wish?
http://nemini.org/index.php/topic,7203.0.html
http://www.minis-making-a-wish.org/
Old Nov 9, 2006 | 12:00 AM
  #135
not-so-rednwhitecooper
yeah, i think the cowl will work out nicely.
the real reason for my doing a cowl really has nothing to do with heat or anything, its just to aid in the placement of my new turbo.
4 more inches of clearence will help out alot.
Old Nov 9, 2006 | 02:07 AM
  #136
Eastsidemini's Avatar
Eastsidemini
cowl
What size turbo and type of header are you running? Are you saying it will stick out from the factory hood? I'm looking at the SPI manifold with the Garrett gt3071r turbo, it may need some firewall mod
Old Nov 9, 2006 | 02:10 AM
  #137
not sure on the turbo specs off hand, I'll get exact numbers tomorrow.
I'm making my own manifold that will lift the turbo up and out from behind the motor. i really dont like having it back there near the firewall. It will probably be 2 or 3 inches taller than the factory hood, so i will need a 4 inch cowl to clear it.
Old Nov 9, 2006 | 02:19 AM
  #138
Eastsidemini
Is the manifold like the one on the other forum? You know who I'm talking about That look sick
Old Nov 9, 2006 | 03:37 AM
  #139
simmilar, but not exact.
he went up and over, whereas im just going straight up, no curves, and it will be based off a stock OEM header to keep costs down to a minimum.
Old Nov 9, 2006 | 05:29 AM
  #140
Partsman's Avatar
Partsman
Legion_of_Doom
Make sure to post some pics.
Old Nov 9, 2006 | 09:43 AM
  #141
Eastsidemini
I think the oem tubing is too small to make high HP.
Old Nov 9, 2006 | 11:53 AM
  #142
Partsman's Avatar
Partsman
Legion_of_Doom
Here's a little PhotoChop for a matching Ram intake (sort of looks like a zit):
DrPhil, can you photochop a small bonnet scoop where the zit is?
Old Nov 9, 2006 | 12:26 PM
  #143
Bahamabart's Avatar
Bahamabart
MMh not sure about looks? But a good name would be the CAI mole scoop? I'm stuck on Austin Powers.
How about making it longer and curving with the grill line?
PS - I've had a cocktail
Old Nov 9, 2006 | 12:32 PM
  #144
MSFITOY's Avatar
MSFITOY
Two more hours for me and I'll toast you one
I'm liking the original idea more and more when you guys were talking about mounting a scoop above the air box...this is starting to look "fussy" as we say in the design world...
Old Nov 9, 2006 | 12:50 PM
  #145
Partsman's Avatar
Partsman
Legion_of_Doom
Mounting a scoop above the airbox is not out of the question, I just need to integrate it into the vent on that side so it doesn't look too busy, or fussy as you designer guys say.
How would that look?
Old Nov 9, 2006 | 01:18 PM
  #146
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
I've got agree with Sid here. The mole/zit scoop *could* be made to integrate better but it's going to impact the relatively clean lines of the bonnet (and I'd rather not mess with them myself.) But on the other hand, I was making v2 of my airbox diverter yesterday afternoon, and had to drive the car without it and I *felt* like it was very sluggish and unresponsive without the shot of cold air. Ambient was 71degF, and the car had a little heat soak.
Sid, you're going to have to move your guage to fit the airbox diverter to your DFIC...!
Old Nov 9, 2006 | 01:20 PM
  #147
MSFITOY's Avatar
MSFITOY
Huh?
Old Nov 9, 2006 | 01:53 PM
  #148
DrPhilGandini
I forgot you have the AGS, Sid, sorry! You don't need no steenkin' airbox diverter coz you dont have an airbox. my bad.
Old Nov 9, 2006 | 02:11 PM
  #149
well the manifold is only going to be as good as the exhaust ports, which are still stock, so i see no need to go any bigger.
Old Nov 10, 2006 | 08:54 AM
  #150
Bahamabart's Avatar
Bahamabart
The problem for you , me and MSFITOY is that we ALREADY made holes in our the hoods. Ideally a large exit vent on the left and then an intake scoop on the right.
