Drivetrain Here we go again...
Old Oct 26, 2006 | 09:11 AM
  #101
stevecars60's Avatar
stevecars60
Originally Posted by DrPhilGandini
Regarding MSFITOY's photo of the underside of the DFIC with heat shield installed: any evidence or thoughts on whether this is better than the ceramic coating that comes on the DFIC from the factory? The ceramic coating is very thin compared to the thickness of the aluminized blanket stuff I just got from Pegasus.
cheers,
Phill don't try it. It will defeat the coating. These coatings are designed to spread the heat evenly so there is not hot spot. For the DFIC this helps the TE by allowing lower temps on the coated surface. Would you insulate a radiator? It is possible that an uncoated DFIC could benifet from the insulation. Need to wait & see
Old Oct 26, 2006 | 09:51 AM
  #102
latte hiatus's Avatar
latte hiatus
That's a good point, but while ceramic coating is meant to act as a layer of insulation, adding an aluminized heat barrier would help redirect radiant heat away from the ceramic in the first place, causing the DFIC (and consequently the IAT) to be cooler overall. This is based on the assumption that the ceramic is cooled predominately by the passing of air through the DFIC (and not, presumably, from the hot engine underneath).
Old Oct 26, 2006 | 10:03 AM
  #103
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Actually my diverter allows some air to pass under the DFIC. Perhaps the best idea would be to insulate the intake manifold that sits under the IC (as per the post on insulating the OEM IC) and keep air moving in the area. Of course nothing seems to help in stop and go traffic, but that's life in the big city...
There's someone (pberry51) on another thread that glued the aluminized barrier over their ceramic coating....ooops.
cheers,
Old Oct 26, 2006 | 10:16 AM
  #104
MSFITOY's Avatar
MSFITOY
Ok...if my buddy Chad at DT can secure me an O2 sensor today...we'll find out how loud this bad girl will be tomorrow
The O2sim won't get here in time so I'll have to live with the fricken yellow warning...
Old Oct 26, 2006 | 10:39 AM
  #105
stevecars60
It is not insulation. It is designed to stop hot spots by evenly disipating the heat. This alows for better TE, thats why you will find different coatings on the dome & skirt of pistons.
Dr Phill has a better idea, "Actually my diverter allows some air to pass under the DFIC. Perhaps the best idea would be to insulate the intake manifold that sits under the IC (as per the post on insulating the OEM IC) and keep air moving in the area. Of course nothing seems to help in stop and go traffic, but that's life in the big city..." There may be more than enough air passing below the DFIC to cool that plate because the coating works both ways. The plate may get warm but it will be cooler in the bigger picture, even in stop & go traffic.
Old Oct 26, 2006 | 10:47 AM
  #106
latte hiatus
It is not insulation. It is designed to stop hot spots by evenly disipating the heat. This alows for better TE, thats why you will find different coatings on the dome & skirt of pistons. [...] The plate may get warm but it will be cooler in the bigger picture, even in stop & go traffic.
I agree completely that the ceramic serves to dissipate heat in an even manner - but regardless, ceramic is, by definition, an insulator, as it does not conduct heat.
As you've said, in this case, the ceramic acts both as a heatsink (by distributing heat over a large surface area) and an insulator (by shielding the air in the DFIC from heat).
Old Oct 26, 2006 | 10:55 AM
  #107
obehave's Avatar
obehave
An insulator resists heat exchange but does still conduct heat.
Ceramic is outstanding at dissipating heat.
Just look at those Shuttle tiles.
http://www.nasa.gov/missions/shuttle/f_blankets.html
Old Oct 26, 2006 | 11:13 AM
  #108
latte hiatus
LMAO! Thanks to you, now I've got an image in my head of a ceramic-tiled MINI plowing through the atmosphere in re-entry, with fingers of flames licking the ceramic.
The ceramic composite disc brakes that Porsche uses may be more relevant to automotive discussions. Those catch on fire, too!
Old Oct 26, 2006 | 11:45 AM
  #109
stevecars60
A tiled Mini... with paisley tiles..... I have a matching tie.... Did I win?
The Porsche breaks get so hot they will burn anything that gets close but they also cool at an unbelievable rate. I can't remember the #s but it was almost unthinkable. And yes that is a pretty good comparison.
Using coating on pistons is an easy way to see how the ceramic work. After 5 to 10 race hours the piston will look almost new. This is 1 of many reasons not to put anything over the DFIC coating. I would think M7 would have consulted a company like Max Power or the like that does coating for all types of race pistons, and make a descission on the type of coating best suited for their product.
Old Oct 26, 2006 | 11:49 AM
  #110
Wake|MCS's Avatar
Wake|MCS
No you won't... Somewhere on here there's a thread on a "mechanical o2 simulator" that's used widely on honda's and other cars. If I'm not mistaken you take 2 spark plug adapters or extenders and screw them into each other, you drill one out a bit and put that one into the existing o2 bung. You screw the o2 sensor into the spark plug adapter/spacer... Cheap too, and works better than the electrical simulators as some people have had bad luck with those...
Worth looking up... Good Luck Oh and take some video... just cause...
Old Oct 26, 2006 | 12:24 PM
  #111
MSFITOY's Avatar
MSFITOY
I looked at that but there's no room where the bung is...I'd have to weld in another bung where there's more clearance for the extension...
Old Oct 26, 2006 | 12:31 PM
  #112
Wake|MCS's Avatar
Wake|MCS
Oh, then I guess you will have to drive around with the light on haha...
Old Oct 26, 2006 | 12:37 PM
  #113
MSFITOY's Avatar
MSFITOY
I have been anyway...that's why this thread was started...because my bad Miltek cat needed replacing and the lights were on every two cycles
Old Oct 26, 2006 | 10:08 PM
  #114
MSFITOY's Avatar
MSFITOY
One AM...just got done and fired her up with the Megans and.......Holly Mother of All Exhaust Purrs real nice...I can hear each cylinder firing After a little warm up in my garage, I blip it few time and.....
I wanted to take her around the block and wake up the dead but it started to rain...:impatient
Old Oct 26, 2006 | 10:18 PM
  #115
spillman's Avatar
spillman
Ahhh... How sweet the sound is to any first start up.
Old Oct 27, 2006 | 03:38 AM
  #116
SpiderX's Avatar
SpiderX
I told you ... your gonna like this... opens up that head/engine......
Old Oct 27, 2006 | 02:51 PM
  #117
Johan's Avatar
Johan
Originally Posted by norm03s
Didn't you see those pictures on the OBX thread some time ago. I posted pictures of before and after using the OEM flange gasket on my OBX. The OEM gasket is larger than the OEM head ports I just made them match perfectly.
Thing is all this stuff has been discussed before on here and now being rediscovered.
Always check and recheck it’s the details that count.
Let me stir the pot a little in this thread.
On my Custom Head, the OBX header was actually larger than the exhaust ports. I think the OBX is 1 5/8" ?? Correct me if I'm wrong. Our flow numbers are comparable to the flow numbers on Randy's head. -- Johan
Old Oct 27, 2006 | 03:04 PM
  #118
Wake|MCS's Avatar
Wake|MCS
Haha I'm glad you enjoy the Megan/Edge header... Take some video pleaaassseeee...
Old Oct 27, 2006 | 03:29 PM
  #119
ChiliCooperS's Avatar
ChiliCooperS
Yeah what he said ^
I want some flames!
Mikey
Old Oct 27, 2006 | 04:58 PM
  #120
Bahamabart's Avatar
Bahamabart
Finish bolting up the Meagn? Should have kept the MILTEK
Old Oct 27, 2006 | 05:21 PM
  #121
Bahamabart's Avatar
Bahamabart
What siz e are the Megan?
looking foward to yr dyno comparison.
Old Oct 28, 2006 | 08:30 AM
  #122
MSFITOY's Avatar
MSFITOY
I still have both my friend
Yes...the Megan/Edge went on yesterday morning around 1am and boy can this set up wake up the dead It is definitely much more aggressive in it's bark but to me, there's no droning. I guess music is all relative to each persons ears...what was found to be too objectionable, I found it enjoyable and even tolerable...the question is whether my wife will agree (for the long Dragon trip) so I'll have to take her for a test drive
In normal traffic driving, it is a bit louder than my Miltek header. At highway speeds (70-80), the motor presence is distinct but not loud enough to overwhelm normal conversation with normal speach.
However, this setup is not for people who lug their motors...if pressed below 3k, it sounds like a Japanese rice cooker, only louder (that's how all motor sounds when lugged but they aren't aware of it)...I'm always above 3.5k anyway so that's not an issue...
Step on it, and that's when the fun begins...frankly, it sounds like a "race car" once the rpms are up on cams...no doubt what the driver's intentions are when I blip down shift and flatten the pedal
However, like I said, the jury is still out until the test drive with Mrs...
Old Oct 28, 2006 | 10:08 AM
  #123
Wake|MCS's Avatar
Wake|MCS
However, this setup is not for people who lug their motors...if pressed below 3k, it sounds like a Japanese rice cooker, only louder (that's how all motor sounds when lugged but these people don't know it)...I'm always above 3.5k anyway so that's not an issue...
So when cruising at a steady 2500rpm it sounds like **** basically? or you mean when you punch it from under 3k.. I normally drive keeping my rpm's below 3k for cruising.. How's your gas mileage since you're always above 3500?? lol... don't forget that video!! please!!
Old Oct 28, 2006 | 10:19 AM
  #124
MSFITOY's Avatar
MSFITOY
If you're under light load cruising at 2500...it's very quiet...just don't step on it at that low rpm...every car would sound like !@#$...you just don't know it because of the quiet muffler...there's no power there anyway...
With my mods, the milage is between 23 and 28, depending on right foot...
Old Oct 28, 2006 | 11:40 AM
  #125
DrPhilGandini
I think the MCS is a dog under 3k, in every gear. I normally reside between 3k and 4k even when cruising on the freeway. My Megan and Miltek catback sounds quiet under constant revs, but really gets loud when the go pedal is depressed. No ricers here. I'm glad it went well for you, Sid!
