Drivetrain Here we go again...
Old Oct 22, 2006 | 05:45 PM
  #51
MSFITOY's Avatar
MSFITOY
Originally Posted by mdsbrain
Hotness! And I see you put your wipers back on haha
Free upgrade
This is where my 20hp was blocked...the carbonized area is the where exhaust gasses from my Webb head was being blocked by a standard Miltek header...
Old Oct 22, 2006 | 06:00 PM
  #52
cartar452's Avatar
cartar452
Originally Posted by MSFITOY
Bye Bye bulls eyes...Pristine glass by Pilkington, installed Friday by Henderson Glass...made in Findland...Findland? I thought they only produce hot leggy blonds... They make very nice glass too...The thought of Hot Leggy Blonds making Mini glass makes me warm all over
Tint band thanks to my good friend 4GASM... I used a laser leveler to produce a clean water line...
that scoop looks awesome...did it start out carbon fiber or is it all painted??
Old Oct 22, 2006 | 06:06 PM
  #53
MSFITOY's Avatar
MSFITOY
CF of course...thanks to the Dr M7
Old Oct 23, 2006 | 04:57 PM
  #54
skuzy's Avatar
skuzy
hey how did u go about ridding that excess from the exhaust header? dremel?
Old Oct 23, 2006 | 05:24 PM
  #55
MSFITOY's Avatar
MSFITOY
Something 10 times the power of a dremel 1/2" diam bi-directional carbide bit with 1/4" shaft and a 1/2 hp air die grinder...did the first primary in about 10 minutes The header's at a shop right now getting another bung welded on then I'll finish the grinding tomorrow...
Old Oct 23, 2006 | 11:12 PM
  #56
skuzy's Avatar
skuzy
lol 10 times the pwoer .. that would make sense!
hope it turns out as planned in the end
Old Oct 24, 2006 | 08:10 AM
  #57
Bahamabart's Avatar
Bahamabart
Just happens to be one of your few tools - huh! I'm on to you but you already new that !
Can't wait for the SOP report .
Old Oct 24, 2006 | 10:05 AM
  #58
MSFITOY's Avatar
MSFITOY
I'm sending Robbin down the tunnel to check out if you really did clean your garage
Old Oct 24, 2006 | 01:26 PM
  #59
herbie hind's Avatar
herbie hind
Think removing this amount will help? No kiddin...:impatient
Holly Cow...talk about blockage
so who's off here? webb or the milltech? as far as center i mean . it looks like all coming off one side.
Old Oct 24, 2006 | 02:07 PM
  #60
Bahamabart's Avatar
Bahamabart
Where do you think I stuffed all of my sh@t - in the tunnel - lol
Old Oct 24, 2006 | 02:42 PM
  #61
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
herbie:
That' the Megan header, and I think the grinding mask is off the OEM header gasket, which is very large compared to other aftermarket gaskets (like the one that comes with the Megan, eg.) My Megan was like this, and it seemed as if the flange had been offset during the setup for welding the primaries, as all primaries were displaced.
cheers,
Old Oct 24, 2006 | 02:49 PM
  #62
Bahamabart's Avatar
Bahamabart
Originally Posted by DrPhilGandini
herbie:
cheers,
If thats the case - doesn't speak well about the header.
Old Oct 24, 2006 | 03:16 PM
  #63
MSFITOY's Avatar
MSFITOY
Well ladies...I've decided to stick with the Miltek and the cat after reading and hearing all you guys warning about how insanely loud it would be:impatient I'll miss the opportunity to help add to the global warming effect though As we'll be on road more than the track (and I don't want to deal with finding/welding a cat for the Megan/Edge header), I've decided to be safe as I'm already bordering on the edge of "citation" loud with my modified Borla Race...don't need to push my luck
I've ground out the Miltek's flange to match the Webb head and I'm just waiting on Partsman who's been kind enough to order me up a reasonably priced OEM O2 sensor...for which I could kick myself for having snipped the cable too close to the original sensor that I thought was stuck on for good on the bad header. I got it off after the header was removed and realized that I just wasted a perfectly good/expensive sensor
I still lust after the thought of continueing the install of the Megan/Edge header as it's so nicely done (except for the slight flange weld offset which is not an issue)...even my hotrod header specialist said it was very well made and could not match the price to replicate one in stainless when I brought it in for a bung installation. And this guy can build any custom header/exhaust system I want...he does exhaust for funny cars
If I follow through with this, I'll put up the Megan/Edge header for sale which I'll finish grinding the remainding three ports. This woundn't hurt for someone with a stock head but would sure help if you have a modified one. It also has a third bung installed incase you want to install a wideband gauge
Stay tuned for more pics...
Old Oct 24, 2006 | 03:57 PM
  #64
MSFITOY's Avatar
MSFITOY
Oh hell...I don't know...help...I'm still lusting after the Megan/Edge header...the primaries are larger and longer...decisions decisions...:impatient
Old Oct 24, 2006 | 04:07 PM
  #65
Wake|MCS's Avatar
Wake|MCS
Why don't you try out the Megan/Edge header and see just how loud it gets... Plus if theres any added performance gains.. At the very worst it'll be too loud and you'll have to take it off. Better than wondering 'what if'...
Old Oct 24, 2006 | 04:12 PM
  #66
MSFITOY's Avatar
MSFITOY
I think I'm leaning your way
  #67
stevecars60's Avatar
stevecars60
If you don't get a Stahl, do the Megan. Your pipe guy, hot rodder is right. Plus, the best primaries for the bucks.
Old Oct 25, 2006 | 06:53 AM
  #68
Bahamabart's Avatar
Bahamabart
Are we going to get to see pics of the Miltek header match up to the manifold?
Old Oct 25, 2006 | 06:55 AM
  #69
Bahamabart's Avatar
Bahamabart
What to do, what to do - regardless of which way you go, I'll tell you afterwards you made the wrong decision - lol
Old Oct 25, 2006 | 07:18 AM
  #70
MSFITOY's Avatar
MSFITOY
Sure Bart...I'll just pull the motor, insert a tiny remote controlled camera situated just inside the exhaust header, hook up the header and take a picture...
Old Oct 25, 2006 | 07:28 AM
  #71
mdsbrain's Avatar
mdsbrain
We wouldn't expect any less
So is it bolted up yet?
Old Oct 25, 2006 | 07:42 AM
  #72
MSFITOY's Avatar
MSFITOY
I need to finish grinding the Megan/Edge headers tonight and then I'll start reassembly...
Has anyone had issues inserting these header from the botton in? The primaries flare out wider than Miltek and I'm wondering if they'll go in smoothly...
Old Oct 25, 2006 | 07:45 AM
  #73
Bahamabart's Avatar
Bahamabart
You know what I mean the same pic that you took of the Megan with red outline. How does the Miltek match up.
I think that all the grinding is making some one testy
Old Oct 25, 2006 | 07:55 AM
  #74
MSFITOY's Avatar
MSFITOY
Like this picture I posted above
I lined up the template I took of the head's port and painted the Miltek same as the Megan. They were displaced as well but were evenly divided on both sides. The main difference between the two headers are in the throat of the primaries...the Miltek are smaller diameter so the grinds were less severe...more of a champher...the Megan/Edge's primaries are larger diameter so there was more material to remove...
The Miltek's primaries appear to be designed for stock heads while the Megan/Edge has more room to accomodate ported heads...
I suspect the longer/straighter/larger diameter of the Megan/Edge primaries will have an edge over the Miltek in both sound and performance
  #75
chuckt's Avatar
chuckt
If it's too loud, why don't you just add a high flow CAT to it where the test pipe is.
