Drivetrain Here we go again...
Old Oct 21, 2006 | 09:05 PM
  #26
ChiliCooperS's Avatar
ChiliCooperS
OHHHHH YEAH that's the middle school i went to yepp im a schmuck.
This is the high school i go to know(senior hells yeah!) uhhh yeah this is only about half the length of it... as you can see we descriminate against the handicapped. No im just kidding it was taken across the street in a different parking lot. My schools almost two blocks long and about one block wide and has two levels.
I definitely want flames though
Mikey
Old Oct 22, 2006 | 07:50 AM
  #27
Bahamabart's Avatar
Bahamabart
Originally Posted by MSFITOY
Look at the difference between the Webb head exhaust opening and the header flange
Inside line is the flange...
MMMM that proabably means my header is lining up perfectly to to my stock head
Old Oct 22, 2006 | 08:00 AM
  #28
MSFITOY's Avatar
MSFITOY
Think removing this amount will help? No kiddin...:impatient
Holly Cow...talk about blockage
Old Oct 22, 2006 | 08:24 AM
  #29
norm03s's Avatar
norm03s
Msfitoy,
Did you get a matched exhaust flange gasket with the Webb head?
If so then why not make a template from it or use it to lay over the new header flange to mark it up for porting.
Old Oct 22, 2006 | 08:26 AM
  #30
norm03s's Avatar
norm03s
BahamaBart, your OBX is perfect with the stock head ports, nice little anti-reversion step in there.
Old Oct 22, 2006 | 08:32 AM
  #31
SpiderX's Avatar
SpiderX
This is consistent with what we saw..... take out that material and good things will happen
Old Oct 22, 2006 | 08:52 AM
  #32
stevecars60's Avatar
stevecars60
Looks like there won't be much gasket after you cut - #1. If a leak starts, it will get bad quick.
Old Oct 22, 2006 | 10:06 AM
  #33
norm03s's Avatar
norm03s
stevecars60's, right that's awfully close
Which header is that again?
Old Oct 22, 2006 | 10:24 AM
  #34
stevecars60
The Megan that's not made by Megan???
Old Oct 22, 2006 | 10:30 AM
  #35
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
The photo of the header flange material to remove is what I saw when I put mine on--I just used a die grinder to remove all that red stuff down to the primaries.
cheers,
Old Oct 22, 2006 | 10:44 AM
  #36
stevecars60
cheers,
The problem is, there won't be much interference for the flange gasket. If that was my header, I'de be welding another 1/8"+ to the #1 corner before making the cut. There is a, relatively important, relibality issue after the cut on #1.
Old Oct 22, 2006 | 10:45 AM
  #37
SpiderX's Avatar
SpiderX
cheers,
which is what "we" (Dave...I sat and watched) did.....it is interesting to note that there is still a lip that would probably benefit from adding some material to make it smooth but we did not do that
  #38
kurvhugr's Avatar
kurvhugr
Excuse a neophyte question here, but what's the easiest way to determine exactly how much/what needs to be milled? If putting a new header on you don't have deposits conveniently marking the way. tia
Old Oct 22, 2006 | 10:58 AM
  #39
stevecars60
The best way that I have found is to make a template out of thin copper or aluminum ( 20g is what I use ). I prefer copper as it can be a little easier to use. Save the template for that head so it may be used on another header or if you are fabing your own header.
Old Oct 22, 2006 | 01:12 PM
  #40
MSFITOY's Avatar
MSFITOY
Here ya go...one down...three to go...
Old Oct 22, 2006 | 01:17 PM
  #41
Wake|MCS's Avatar
Wake|MCS
Looking Good!
Old Oct 22, 2006 | 01:23 PM
  #42
Bahamabart's Avatar
Bahamabart
REALLY? you checked it out? anti-reversion?
My previous post was just a leg hump for MISFITOY .
Old Oct 22, 2006 | 01:32 PM
  #43
RCMini's Avatar
RCMini
After you get done grinding them headers you'll definetely have to let us know the results. I am tempted now to pull my header off. Just for a look.
Old Oct 22, 2006 | 02:10 PM
  #44
norm03s's Avatar
norm03s
Sure did!
Didn't you see those pictures on the OBX thread some time ago. I posted pictures of before and after using the OEM flange gasket on my OBX. The OEM gasket is larger than the OEM head ports I just made them match perfectly.
Thing is all this stuff has been discussed before on here and now being rediscovered.
Always check and recheck it’s the details that count.
Old Oct 22, 2006 | 02:14 PM
  #45
SpiderX's Avatar
SpiderX
You are right, but it did not seem relevant to me at the time ( I was wrong)
so many threads......... so little time
Old Oct 22, 2006 | 04:06 PM
  #46
Bahamabart's Avatar
Bahamabart
I'm curious as well - I'm not sure I want to KNOW!
  #47
mdsbrain's Avatar
mdsbrain
He is making the ports larger to match up with his ported/polished cylinder head.
Old Oct 22, 2006 | 04:07 PM
  #48
Bahamabart's Avatar
Bahamabart
Like Spidy said - so many posts so little time. If you know the thread tell me and I will go back and take a look. I used the OBX gasket that came with the header.
Old Oct 22, 2006 | 04:49 PM
  #49
MSFITOY's Avatar
MSFITOY
Bye Bye bulls eyes...Pristine glass by Pilkington, installed Friday by Henderson Glass...made in Findland...Findland? I thought they only produce hot leggy blonds... They make very nice glass too...The thought of Hot Leggy Blonds making Mini glass makes me warm all over
Tint band thanks to my good friend 4GASM... I used a laser leveler to produce a clean water line...
Old Oct 22, 2006 | 05:32 PM
  #50
mdsbrain's Avatar
mdsbrain
Hotness! And I see you put your wipers back on haha
