Drivetrain WMS SportBox RAF
Old Oct 17, 2006 | 01:20 PM
  #26
MattMan's Avatar
MattMan
Coordinator :: Minis Under the Arches (Oct 25-28)
Wow, how bad is NAM when people are fighting over vocab.....
Old Oct 17, 2006 | 01:21 PM
  #27
PGT's Avatar
PGT
oooh....loaded question. melikey
Old Oct 17, 2006 | 01:29 PM
  #28
myzamboni's Avatar
myzamboni
Originally Posted by Greatbear
Please keep the thread on topic, lest it find itself melted down in a refractory furnace.
I'm confused . . .are you talking a light-sourced or heat-sourced furnace?
OK, back on topic everyone.
Can current HDI owners get the RAF portion to update their intake?
Old Oct 17, 2006 | 02:10 PM
  #29
PGT's Avatar
PGT
follow up Q to that will be WMS HDI or DDM DHI?
Old Oct 17, 2006 | 02:21 PM
  #30
sdv515's Avatar
sdv515
i saw a pic of that gold foil stuff wrapped around the roll cage of a race car before. also solar blankets are very effective at reflecting heat back, somewhere like 80%.
Old Oct 17, 2006 | 03:37 PM
  #31
jlm's Avatar
jlm
"refractory" refers to the high heat property of materials (crucibles, things like that, metals like tungsten, tantalum, inconel, etc.)
"refraction" is the bending of light waves
Wikpedia ain't always the end-all.
that being said, stainless steel is not considered a refractory metal. It does have a low thermal conductivity for a metal, which is probably the feature Randy is espousing
Old Oct 17, 2006 | 04:14 PM
  #32
RandyBMC's Avatar
RandyBMC
Temporarily Banned
I may have espoused incorrectly - I was referring to a term I was using way back at university doing thermal labs. Sorry if it caused confusion, but I think the point was clear. In terms that are as concise as I can say, I used stainless steel because it has a much better tendency of keeping things that are hot on one side from being hot on the other side.
As far as the thermal coatings, there are coatings out there I would use, but the cost is too prohibitive. We are going to offer a riveted thermal blanket barrier as an option.
The unit will work with the scoop for the DFIC, but it will not work (that I am aware of) with the DFIC itself unless used without the RAF - the SportBox will work with any intercooler the same as any of the other aftermarket CAIs.
As for compatibility with the original WMS HDI design, I have built this unit to supercede all CAIs on the market. With some fabrication it could work, but the SportBox has a removable block plate that is used for the RAF.
I would be happy to entertain ideas on a RAF specific logo! It sounds cool.
Keep the questions coming, and let me know if I missed any.
Thanks,
Randy
Old Oct 17, 2006 | 04:21 PM
  #33
PGT's Avatar
PGT
so, a notch out of the side of an HDI and that piece will fit? sweet!!
Old Oct 17, 2006 | 04:33 PM
  #34
RandyBMC's Avatar
RandyBMC
Temporarily Banned
It may - the SportBox has a larger volume, but I believe at that point of the box, the height is the same. I haven't tried it, but I would think it could be done with a little fab - anything can be really .
Hope that helps!
Randy
Old Oct 17, 2006 | 05:19 PM
  #35
obehave's Avatar
obehave
Le Mans and other endurance cars use it.
The frame rails are coated in some instances which when tied to the interior roll cage lead to lower cab temps.
Very cool...
Old Oct 17, 2006 | 05:25 PM
  #36
PGT's Avatar
PGT
the hatch cover of a McLaren F1 is covered in it too
Old Oct 17, 2006 | 05:31 PM
  #37
herbie hind's Avatar
herbie hind
Originally Posted by kapps
Ok, who's going to be the first to try THIS stuff on their intake?
a guy at ktr performance swears by that stuff.
Old Oct 17, 2006 | 05:55 PM
  #38
Partsman's Avatar
Partsman
Legion_of_Doom
This is rather confusing.
You wouldn't really have a DFIC scoop without a DFIC.
If the RAF duct for the SportBox(quote from your post on the WMS forum) "utilizes the unused part of the IC scoop on the bonnet". How would this be possible when the DFIC scoop closes off that part of the scoop?
image courtesy of gandini
Old Oct 17, 2006 | 06:22 PM
  #39
Johan's Avatar
Johan
This guy is using a GRS intercooler and is Having good results with this scoop
Old Oct 17, 2006 | 06:35 PM
  #40
Partsman's Avatar
Partsman
Legion_of_Doom
That's cool.
I only said that because most people that have it, got it with the DFIC.
Old Oct 17, 2006 | 06:38 PM
  #41
Johan's Avatar
Johan
That's cool.
No worries, I would of thought the same thing but I know this guy
I really like this Air Box Randy it looks pretty "trick" I am in the market for a new intake. Thank you for keeping us up-dated -- Johan
Old Oct 17, 2006 | 07:17 PM
  #42
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Originally Posted by pberry51mini
Will this work with the DFIC scoop?
Paul
Ah...no. The DFIC is much taller than the stock or other ICs, and the exit horn would interfere with the ram tube.
btw, I must have missed the post, but I don't ever recall seeing TE readings from pre-intake filter, pre-SC, and the usual pre- and post- IC? Do we have any evidence, other than anecdote that a significant lowering of post IC temperatures can be achieved by a (relatively) small lowering of the pre-filter temperature.
Just asking...
cheers,
Old Oct 17, 2006 | 08:08 PM
  #43
F15EWeapon's Avatar
F15EWeapon
Just asking...
cheers,
I'm sure once a production ready unit is available, Randy will enlighten us as must as possible. I'm anxious to see numbers from him as well as independent testing. DFIC discussion aside, I'm sure anyone can see how having a horn utilizing direct ram air would be beneficial. This filter would see fresh air from below, the side, and from whatever it will pull from the cowl vent. I guess the bottom line for me is that I can't really imagine any better way to get more air into the box, save cutting a hole in the hood and installing a nice scoop there as well.
Old Oct 17, 2006 | 08:19 PM
  #44
RandyBMC's Avatar
RandyBMC
Temporarily Banned
You are right - the unit would not work with that version of the M7 scoop - again I don't think that is all that bad... There must be more than one version of the "M7" scoop.
Thanks for posting the pic - it helps!
Randy
Old Oct 17, 2006 | 08:22 PM
  #45
Tüls's Avatar
Tüls
Turbius Maximus
I belive the term we are searching for is
CAUSTICS adj. The enveloping surface formed by light rays reflecting or refracting from a curved surface, especially one with spherical aberration.
Caustics are formed by light that is reflected or transmitted by a number of specular surfaces before interacting with a diffuse surface, or when reflecting off non-Lambertain surfaces. In English, sometimes in the real world, materials can focus light and cast effects, like the highlights at the bottom of a swimming pool or the pattern caused by brushed metal
I deal with reflective/refractive properties alot in 3D doing simulations or just making pretty pictures... and well... almost anything reflective/refractive can cast caustics.... I dunno how this effects an intake.. but... there's a neat new word we can all use to further confuse overly technical conversations
nice intake Randy!
Originally Posted by Will @ M7 Tuning
I was wondering the same thing. I wasn't aware that stainless steel could bend light, or that it was even transparent...
Oh really? Refraction =/= refractivity.
Noun1. refractivity - the physical property of a medium as determined by its index of refraction
Refractivity referse specifically to an index of refraction, which is a property of waves transmitted through a material. Refraction is in fact a multi-use term, which does apply to metals, but refractivity does not. So educate yourself first, others second. At least try to use the right term.
Originally Posted by camelpilot
hehehe, just because YOU dont know about the term "refractivity" being used with regards to metals, does not mean it isn't.
You need the educating hence the tone of my previous post, and you are about to get schooled again. I thought you were smarter than that.
It's totally correct for the term refractivity to be used with regards to metals. It's used everywhere, all the time, dont ask me why. Maybe it's because heat is a wave and a metal can be a medium??
Anyway, I can link you from one of the 12 pages of google search results from the web if you like.
I dont mean to start a little pilot light here or anything, I just dont see the point of your first post is all. I obviously know as much about Metal Refractivity as you do. :P
Old Oct 18, 2006 | 06:08 AM
  #46
obehave's Avatar
obehave
nice intake Randy!
Old Oct 18, 2006 | 06:17 AM
  #47
obehave's Avatar
obehave
Just asking...
cheers,
You will see measurable and repeatable lowering of IC temps with a drop of 10ºF at the filter.
You will see differences with lesser changes but they will also arguably be within statistical noise levels. 10º is pretty solid.
I've recorded this with temp probes next to the filter and pre and post IC.
For sh**s and grins just turn a can of compressed air upside down(or use a can of circuit cooler) and freeze your filter
The propellent is CO2 so doing this while the car is running isn't a good idea.
Old Oct 18, 2006 | 07:11 AM
  #48
Bahamabart's Avatar
Bahamabart
is the back open on this unit to source air from the window vent?
Old Oct 18, 2006 | 08:53 AM
  #49
Soul Coughing's Avatar
Soul Coughing
The reflective material on the top of the boot on the Mclaren F1 is gold
Old Oct 18, 2006 | 09:22 AM
  #50
Big Daddy's Avatar
Big Daddy
At $30 per linear foot, I'd be swearing too!!
