Drivetrain apexi turbo timer install help.
Old Oct 7, 2006 | 09:26 AM
ilscoobydooll's Avatar
ilscoobydooll
can anyone help me out installing this in my car....i tried reading the instruction but it is only saying vehicel specific harrness. And it has no universal wiring instructions and i am a little lost with what wires go to what...please help.
Old Oct 7, 2006 | 09:37 AM
cooper99's Avatar
cooper99
Why are you installing a turbo timer for a supercharged car?
Old Oct 7, 2006 | 09:43 AM
ilscoobydooll
that because i am twin charged
Old Oct 7, 2006 | 10:04 AM
Bster's Avatar
Bster
Nice....!
Old Oct 8, 2006 | 08:28 AM
ilscoobydooll
anyone have any idea of how to install this?
Old Oct 8, 2006 | 12:47 PM
TheBlackBrian's Avatar
TheBlackBrian
Which TC kit is this? I thought all of the TC kits used water cooled turbos.
-Brian
Old Oct 8, 2006 | 05:23 PM
ilscoobydooll
i have the alta kit...but most turbo's with water and oil lines can be ran without the water line....i actually melted one of the Hoses. so decided to go with out the water lines going into the turbo there fore needed a turbo timer. so i need to know which wires to hook to what on this turbo timer.
Old Oct 8, 2006 | 08:51 PM
Ryephile's Avatar
Ryephile
You probably melted a hose because you didn't properly thermally sheild it from the turbine or exhaust, not from fluid temps.
You probably don't need a turbo timer unless you have a habit of running WOT for a while and then immediately shutting down.
Old Oct 8, 2006 | 08:53 PM
Eastsidemini's Avatar
Eastsidemini
water lines
I had 2 custom water line bango made to longer, it is now 4" away from the turbo housing and keeping the hoses away from the heat
Old Oct 8, 2006 | 09:43 PM
TheBlackBrian
It may be easier(and in the end cheaper) to sell the timer and reinstall the coolant lines with some heat rap material. If that is not enough, route the lines differently. Do you have a picture of the install? Maybe I can offer some suggestions.
-Brian
Old Oct 8, 2006 | 10:24 PM
Eastsidemini
-Brian
I totally agree with Brian The 2 water line bango going into the turbo housing can be lenghten to keep the hoses away from the heat source. Let me know if you need photo and I can e-mail it to you.
Brian, any idea to keep the filler tank from being too hot? What is the best way to get all the air bubble out? Thanks.
Old Oct 8, 2006 | 10:48 PM
TheBlackBrian
Are you talking about the reservoir tank? The coolant will get hot no matter what, but not hot enough to cause problems. Make sure you use a high quality coolant/water mixture(a bottle of Redline Water Wetter added into the system should be enough). You can bleed out the air if you have accumulated some through the screw type bleeder in front of the intake manifold once the engine is up to temp.
-Brian
Old Oct 8, 2006 | 11:22 PM
Eastsidemini
-Brian
Thanks bro I did all that already. I just fishing for new tricks if any
Old Oct 9, 2006 | 02:39 PM
ilscoobydooll
yes true it may be cheaper and all...but i rather not hook up the water lines again....didnt like it to begin with when installing the system. just more clutter...anyways can anyone tell me how to throw this thing in.
Old Oct 9, 2006 | 02:54 PM
TheBlackBrian
Try PMing someone at Fireballed. They are using the Apexi A/F ratio module to tune there kit, so they might know something about the wiring and such.
-Brian
Old Oct 22, 2006 | 11:19 PM
Bster's Avatar
Bster
So is it possible to install a Turbo timer? I mean with all the immobiliser and all... would the turbo timer work? Irregardless of whether it's needed or not, of course.
Has anyone manage to install one?
Old Oct 23, 2006 | 09:18 AM
spillman's Avatar
spillman
I remember vaguely when I attempted to install a remote start. You can make the car run without the key once the car is started. You just have to make sure all that when you turn the key off the output wires from the ignition switch recieve constant power. I don't have a wirring diagram. But if you know what you are doing you should be able to use a multi meter and do a little testing.
Old Oct 24, 2006 | 08:34 AM
Bster's Avatar
Bster
Alright... I just wanna make sure that it's doable. I don't know anything about electrics so am going to let my mechanic do it.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
rckrzy1
Aug 11, 2015 06:06 PM
kpl
Aug 11, 2015 04:52 AM
