Drivetrain Helix to release m62 kit?
Old Nov 12, 2006 | 05:58 AM
  #76
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
Originally Posted by VurnB
Is the Helix kit going to be GIAC tuned?
I hope not. Given how long it took to get a 15% map it might be 2008 before it's seen. Seriously, there's probably not going to be enough M62 cars out there to make it woth GIAC's time.
As for the "worth" of the M62 kit, to each his own. I've gotten tons of crap from the local autocrossing community for "ruining" my Mini with the Tk kit. It doesn't stop me from enjoying the hell out of it just about every day. The M62 will still be better than silly stuff like lambo doors or 126 carbon fiber bits or $2000 wheels IMHO.
Old Nov 12, 2006 | 06:40 AM
  #77
isellem's Avatar
isellem
Originally Posted by saifa
Agreed. After all these contraptions, bolt-ons, M62's, Twin C and straight turbo cars I am surprised none of the vendors have come up with some sort of standalone solution to replace the endless array of piggybacks. IMO the first one that does is gonna have a nice lead on the competition.
Seann
The standalone is probably quite aways away... or quite a bit of money away. The reason why is the drive by wire throttle. That is the biggest hump in the whole deal. If someone wants to switch to a cable accutated throttle arangement... they could have one almost immediately. Currently there aren't any manufacturers of standalones that have drive by wire capability. You must switch to use the system.
The funny thing about this is that no one is really using piggy backs in this community anyways. There are not that many of you guys running fuel controllers such as an AFC. THe "movement" for self tuning in this community seems to be lacking. Everybody seems to want "flashes" and someone to fix there yo yo or flat spot or stumble. Which is quite understandable! It sounds great to just plug in and make more power, or drive smoother. We all bought MINI's because we love driving... Not sitting on a dyno getting it to run properly. AND there is no problem with that. Some people just want to enjoy there cars!
Standalones are alot of work. Very few people on here would even know what to do if they had a standalone on there mini... once they installed it they would have trouble just getting the car to turn over... let alone idle, then idle properly, then accelerate, and deccelerate, and WOT. Going to a standalone is NOT easy. But it will be worth every second spent putting it on the car.
Old Nov 12, 2006 | 06:20 PM
  #78
obehave's Avatar
obehave
Originally Posted by Mini Fireman
So a 40hp & 40lb/ft of torque increase for $4000 would be your rough limit? From what I've read/heard this has been achieved with the M62 kit. What will be interesting to see are the results of fitting the kit to the test cars with their varying levels of mods.
I'm also interested to see what variations the Helix kit (and any others) have as compared to the DDM/M7 kit. Multiple development avenues is a good thing.
That's not cheap by any means but not terribly unreasonable either.
That would be the whole package though. No surprises. No "oh BTW" add ons.
Options are always good
Old Nov 12, 2006 | 08:22 PM
  #79
saifa's Avatar
saifa
How difficult is it to switch the TB...?? Just nuts n bolts or are there lots of codes and sensors and stuff to watch out for? As long as you have a good tuner and a proper install standalones aren't that big of a deal. I had an AEM EMS in my 2G Talon back in the day. I didn't have a clue of what the heck was going on but the fella who installed it did...after a while on the dyno it purrrred and i never had the need for another tune.
Seann
Old Nov 13, 2006 | 05:09 AM
  #80
SpiderX's Avatar
SpiderX
The estimate for tuning a stand alone was $20K...... even if that is not realistic 1/4 is out of the question
Old Nov 13, 2006 | 06:35 AM
  #81
saifa's Avatar
saifa
What??? Where did that figure come from?
Old Nov 13, 2006 | 07:10 AM
  #82
Alex@Helix's Avatar
Alex@Helix
Don't forget a new pedal box if you are replacing the Throttle body: the stock gas pedal is just a potentiometer which is not built to actuate a throttle cable. A stand alone is pretty hard-core. Lots of parts, lots of tuning and some potential issues with BCM integration (DSC control, etc.).
Old Nov 13, 2006 | 09:58 AM
  #83
Bilbo-Baggins's Avatar
Bilbo-Baggins
Originally Posted by obehave
Pistons are the issue.
The stock bottom end has held up under 250-300 HP very well.
I do believe that "Fireball Tim" managed to break in to the 10 sec range with a stock block, crank and head. That is over 500hp!
Old Nov 13, 2006 | 11:42 AM
  #84
SpiderX's Avatar
SpiderX
Onasled and Don (precision) both commented on the cost of a full race stand alone system and tune and for some reason that is the number I recall.... I could be remembering wrong.....
Old Nov 13, 2006 | 12:52 PM
  #85
MiniMacPR's Avatar
MiniMacPR
x2 I also remember the same number from both references
Old Nov 13, 2006 | 05:37 PM
  #86
obehave's Avatar
obehave
Yes but that's just one car. A large number are in the 250+ range with little issues.
FBT and others did use different pistons though when going high boost and high HP.
Old Nov 13, 2006 | 08:57 PM
  #87
spillman's Avatar
spillman
280whp is about the limit of stock pistons. But that number is with a supercharger (M45) attached. So raise that a good bit for no supercharger.
And a decent stand alone should be in the 10k range. Not 20k.
Old Nov 13, 2006 | 10:38 PM
  #88
AZMCS's Avatar
AZMCS
Really? Randy is running a stock bottom end with over 300whp. He actually talked me out of doing this with my TC plan.
Old Nov 13, 2006 | 10:46 PM
  #89
spillman's Avatar
spillman
Sounds like a high reading dyno. And I doubt his turbo is flowing that much. Maybe at the crank.
Old Nov 14, 2006 | 12:38 AM
  #90
SpiderX's Avatar
SpiderX
Just repeating Don and Onasled ......as I have no interest..... I think they were adding a lot of money for a very detailed in depth tune, which from my experiecnce is not hard to believe.....for a true race car
Old Nov 14, 2006 | 07:37 AM
  #91
RebelToRumble's Avatar
RebelToRumble
Wow, only 300 hp? :-/
What compression are the MCS cylinders?
Old Nov 14, 2006 | 08:06 AM
  #92
obehave's Avatar
obehave
8.3:1
300 HP is pretty darned good from 1.6 liters. 300HP for 98 cubic inches is not bad at all.
Old Nov 14, 2006 | 08:26 AM
  #93
spillman's Avatar
spillman
8.3:1
Well all you have to do is swap in a piston with a lower ringland and a larger ring gap. The stock ring gap is too tight in my opinion.
Old Nov 14, 2006 | 08:42 AM
  #94
RebelToRumble
I couldn't imagine how expensive it would be to double the MCS's horsepower. I could never pay 1,500$ for an exhaust only to gain 5 horse power.
I guess it's like that with every new[er] car. Kinda why i like driving something older, everythings inexpensive.
Old Nov 14, 2006 | 08:45 AM
  #95
JustJAY's Avatar
JustJAY
Even your Z will start to get expensive the older it gets and the fewer parts there are around. Hell, how much is a 350 now?
Old Nov 14, 2006 | 09:51 AM
  #96
RebelToRumble
It's not that expensive to greatly modify my car. There are a few "z31" fanatics that create early 300zx parts at very nice cost.
With a boost controller, and stock everything else a turbo Z's are able to push 275hp. After that the small 270cc injectors start to go lean.
[bigger] Turbo - Depends where you go - 500-1000$
Intercooler - eBay ~300-400
Full 3" mandrel bent exhaust turbo back - 700$
Cam - 170$
Valve Springs - 200
ECU Tune - 300$
Fuel (pump & injectors) - 3-400$
About 3-400 rwhp with about ~2,000-2,500
I havn't done much to fuel/ecu for reliability reasons (i don't know what i'm doing when it comes to ecu/fuel)
Old Nov 14, 2006 | 10:39 AM
  #97
thulchatt's Avatar
thulchatt
Z32's, second gen 300ZX, can go from 300hp to 400hp with about $1500 in mods (intake, reprogramed ecu and exhaust)
I had a 300ZX just before buying the MINI.
Old Nov 14, 2006 | 10:49 AM
  #98
obehave's Avatar
obehave
Sorry I don't understand the reference.
Maybe you're confused with my "you should do new pistons for more power" statement on another thread.
Yes the top land is too narrow and there is room for quench improvements as well.
Old Nov 14, 2006 | 11:08 AM
  #99
obehave's Avatar
obehave
It's also a far more commonly available motor and it definitely isn't 1.6L.
It's 87.5% larger. Quite a bit easier to make more HP on a bigger motor.
Old Nov 14, 2006 | 11:40 AM
  #100
stevecars60's Avatar
stevecars60
Google Haltech. $20k is way out of line for a stand alone. I had 1 of these on my 78 911. Yes it took time to get the programing right. Yes you should do the tuning on a dyno.And it passed MA emmissions. But - it can be done.
Electromotive also has a stand alone that has about the same learning curve.
At the time TWM was making throttle bodies for FI which made removing the Bosch Jetronic easy. I still have a couple of thin 40s that were going on my Spitfire ( still may ). This car would be easy because it's a 66 - no emmissions.
The Mini - could be done with few modifications but the tuning might be tuff to pass state emmissions
