Drivetrain 15% install question
Old Aug 30, 2006 | 03:19 PM
soilsample's Avatar
soilsample
Hello all,
I'm getting ready to pull the trigger on a 15% pulley.
I live about 150 miles from the nearest dealer..... and not too keen on paying big labor charges for installation.
I don't see anything that looks too difficult on the webbmotorsports write up for installation.... but want to check:
I think I've read about people changing pulleys without lifting the engine. Am I dreaming? or is that true.
Any info on any new "techniques" would be great.
Donald
Old Aug 30, 2006 | 03:21 PM
Dr Obnxs's Avatar
Dr Obnxs
Lifting the motor is easy...
so don't sweat it, and getting the old pully off would be a pain, or worse, not possible. The key is having the right tools (belt tensioner and pulley removal tool).
Lifting the motor is only about 3 or 4 bolts and a jack.
Matt
Old Aug 30, 2006 | 03:32 PM
willymcd's Avatar
willymcd
getting the engine unhooked and up is easy, belt tensioner, can take some time if you don't have a tensioner (this was a pain in the @$$ for me), removing the pulley with a pulley puller is fast took 4 min with 2 of us. the only other hard part other then the tensioner is lowering the engine and aligning it right so the engine can be remounted.
Old Aug 30, 2006 | 03:33 PM
Eric_Rowland's Avatar
Eric_Rowland
You were dreaming - no way to get the tools necessary to pull the old one off without lifting the engine.
FWIW, Randy Webb used two jacks - helped in nudging things the right way.
Old Aug 30, 2006 | 03:43 PM
Dr Obnxs's Avatar
Dr Obnxs
The only thing I found that can take a bit of work to allign
is the bolt for the lower engine mount. I just stuffed a screwdriver into the bolt hole and engine mount, and pulled it into line.
Matt
Old Aug 30, 2006 | 05:27 PM
dnjat's Avatar
dnjat
No bad with the right tools!
Where do you live? If you are near Connecticut, I did mine last month and would be glad to help you. I have the tools you need.
Old Aug 30, 2006 | 06:40 PM
soilsample's Avatar
soilsample
Dnjat,
Thanks for the nice offer! Unfortunately, I live in Southwest Louisiana.....
Thanks to everyone else for the advice.
Next question:
Ive read some people say that they didn't remove "all the stuff" that was removed in the write up.
I plan to buy the puller that will let you leave the tensioner in place..... do I really have to pull the air box out? And all that other "stuff".
Thanks again
Donald
Old Aug 30, 2006 | 08:10 PM
willymcd's Avatar
willymcd
its not hard to take the air box off, i think it gets in the way of the driver side engine mount
Old Aug 30, 2006 | 08:26 PM
Smokey's Avatar
Smokey
Dnjat,
Next question:
Thanks again
Donald
Donald,
You need to pull the air box; 3 screws, 2 elec connections and 2 hose clamps and your done with it 15 minutes tops. And as ***** said you need to remove it to get to the DS engine mount bolt.
If you get the newer pulley puller you don't have to remove the tensioner system. You still need to remove the tension, but not the tensioner.
We just did one this afternoon, took the 2 of us a little less then 2 hours start to finish. I've got a diagram and some pictures of my tension tool in my gallery, cost me about $5 to make with some flat stock from Lowes.
I also pulled the PS inner wheel well cover, made routing the belt a lot easier.
Good luck
Old Aug 30, 2006 | 08:47 PM
creeker's Avatar
creeker
Smokey, looked in your gallery for your tensioner diagram and it not there. Any chance you could post it?
Old Aug 30, 2006 | 08:52 PM
Smokey's Avatar
Smokey
This should get you to the gallery page: EDIT: link didn't work so added pictures.
It was a trace, but in the scanning process the picture changed size, so pay attention to the measurments more so then the picture. The finished product has been cleaned up, edges rounded and the handle Plasti-Dip'd for comfort.
Started with a cardboard mock up to get the angles and rollpin locations:
Here's one more:
Alkaidovich
Jan 30, 2021 01:35 AM
adrchn
Aug 13, 2019 02:11 AM
silence2-38554
Nov 12, 2015 09:39 AM
squawSkiBum
Oct 2, 2015 09:21 AM
