Drivetrain How much HP would this add
Old Mar 29, 2003 | 06:16 PM
Azzurri's Avatar
Azzurri
A Magnaflow Exhaust,Headers,Madness intake,Throttlebody,Supercharger Pulley,ECU upgrade. and any other hp upgrades. What would the HP range be 230? or so?
Old Mar 29, 2003 | 06:23 PM
caddman's Avatar
caddman
depending, randy and i are very close to each other on the hp, but he has different mods than i, but the combo should be approximatly in the area of 230 or so at the crank... if that helps ya any...
Old Mar 29, 2003 | 06:26 PM
Azzurri's Avatar
Azzurri
Thanks, that does!
Old Mar 29, 2003 | 06:29 PM
GARFIELD's Avatar
GARFIELD
Ok, give me some advise. I have an 03 MC, not the S. What are a couple of mods I could do to this car to increase HP, & how much increase should I expect?
Thanks,
Terry
Old Mar 29, 2003 | 06:34 PM
caddman's Avatar
caddman
but i forgot to mention that the ecu upgrades are not finished yet so that hp may or maybot be acheivable, i am hoping that the ecu will
as far as the mc, thereare not to many mods for it, but there are some, check with randy, he has a couple and a couple up his sleeve i believe, there is also a turbo kit for the mc supposed to bring it to 200hp, but im not sure how well it actually pans out, talk to randy because im sure he can at least point you in the right direction...
Old Mar 29, 2003 | 06:46 PM
StarLog's Avatar
StarLog
Caddman,
Who is randy.? I also want to increase my hp. 02 MC..
If we put a trubo on a MC then you have compression to think about, and rob and piston 's may not hold up.
What about porting the heads, and regrinding the cam?.
The idea is not to have to remove the motor and make changes, so a BOLT ON version would be sweet.
Old Mar 29, 2003 | 06:48 PM
caddman's Avatar
caddman
https://www.northamericanmotoring.co...uname=RandyBMC
very nice guy delt with him on many occasion, and plan to be doing some dyno tuning and stuff to get the eco programming up to speed i hope....
Old Mar 29, 2003 | 06:51 PM
caddman's Avatar
caddman
http://www.mini-motorsport.com/
this is his webpage as well, he has a catalogue, for you to browse,
great guy hope this helps....
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
