Drivetrain Best Short Shifter?
Old Sep 21, 2006 | 05:49 PM
  #26
JustJAY's Avatar
JustJAY
Well, I just found out that SF is 12/03 build. Yea, it won't work. So I guess I have to get the '02-'03 shift kit.
Old Sep 21, 2006 | 05:50 PM
  #27
JustJAY's Avatar
JustJAY
Originally Posted by ssallykat
Jay, if it doesnt work in Soulfire, I may be interested in buying it from you for Lenore.
I will deffinately sell it to you.
Old Sep 21, 2006 | 06:13 PM
  #28
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
I would highly recommend it. I would also suggest throwing a Whalen on it too. They just fit together nicely.
Old Sep 21, 2006 | 06:21 PM
  #29
cliff@coasttocoastusa's Avatar
Former Sponsor
I have the Alta on my car and love it. Another option to look at would be the new Craven Speed shifter. It is priced right and is super high quality. It is the easiest shifter to adjust throw. Just twist the nut on the shaft and the shifter goes from 0-50% in seconds (or anywhere in between).
Check it out here: Craven Speed Shifter
We also carry the Alta, Fidanza, and Helix shifter options.
-Cliff
Old Sep 21, 2006 | 06:35 PM
  #30
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
I have the Helix unit in my car. I wanted the shorter shifting, but I wanted to leave the shifter a stock length. I really didn't want my arm in the cup holders. I like it a lot, and have sold several after people have driven my car. I also sell a lot of craven speed shifters. they are priced well and are easy to adjust on the fly, with out tools. both are good units but personally I would rather spend $44 over $159, but both units are good. I sell both. hope that helps. feel free to give me a call if you have any questions.
Chad
Detroit Tuned
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Sep 21, 2006 | 07:26 PM
  #31
JustJAY's Avatar
JustJAY
Thanks for all your help guys.
Old Sep 22, 2006 | 07:53 AM
  #32
jaynicholson's Avatar
jaynicholson
Outmotoring.com has a link to the installation instructions for a B&M short shifter and it mentions the posibility of vibrations. I had a B&M in my previous car (SR20 powered sentra) and the vibrations drove me nuts if I used anything other that the stock shift **** which was heavily lined with rubber. Has anyone had vibration problems with the B&M in their MINI?
Old Sep 22, 2006 | 08:04 AM
  #33
RandyBMC's Avatar
RandyBMC
Temporarily Banned
We offer a shift unit that allows the use of the stock ****, the Whalen unit, or our own design (as well as any of the aftermarket set-screw type knowbs). It is very simple to adjust, using a collet style locker, and will not spin from the fore/aft orientation when loosened for adjustment. It is available in two variations - early and late production cars. We also use the best materials in the industry.
Let me know if you have any other questions at all!
Webb Motorsports Short Shifter
Hope that helps,
Randy
Old Sep 22, 2006 | 08:05 AM
  #34
MSFITOY's Avatar
MSFITOY
The best shifter design?
Old Sep 22, 2006 | 04:40 PM
  #35
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
I've had a B&M in my 05 S for (probably) over 6 months now. I don't have any vibration through the shifter. I haven't noticed it stiffening up either (like some people have mentioned in previous threads). Mine has been smooth and solid since it was installed.
Old Sep 22, 2006 | 05:00 PM
  #36
flyboy2160's Avatar
flyboy2160
well, you could always go with old reliable: just cut 3" to 3 1/2" off the shaft and stick some **** back on....
Old Sep 22, 2006 | 06:05 PM
  #37
JustJAY's Avatar
JustJAY
Back in the earlier posts, I mentioned that I wanted a shroter throw, not a shorter shaft.
Old Sep 22, 2006 | 06:06 PM
  #38
JustJAY's Avatar
JustJAY
Possibly design, but mostly function and fit.
Old Sep 22, 2006 | 06:12 PM
  #39
obehave's Avatar
obehave
Ditto. Mines over 3 years old with no real issues. You can always use the stock bushings. Softer. I tried them and got rid of them.
Powerlex motor mounts made a bigger difference in this regard.
BTW, just caught the Discworld reference.
Old Sep 22, 2006 | 06:24 PM
  #40
Grassroots Garage's Avatar
Grassroots Garage
Originally Posted by mikem53
I am in the market for a short shift also... I want the stock shifter to remain. You want the height to be close to the wheel... I plan on modifying the bottom portion of the shifter to get the short throw. I am condsidering 2 units... The Helix which has about a 40% reduction in throw, and the Ultek which works the same way but they clain an ideal 20% reduction in throw.. Can anyone comment on these units... Thanks
Hey Mike,
You ought to call me, I have a few option for you right here, and you'll get the M2C2 discount
--Dan
Old Sep 23, 2006 | 04:42 AM
  #41
AZMCS's Avatar
AZMCS
Originally Posted by RandyBMC
WMS FTW
Old Sep 23, 2006 | 05:40 PM
  #42
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
The biggest appeal to me of the B&M was the metal bushings. They are the thing that gives each shift that solid feel. When I had some warranty work doen with my car I was given a loaner and the shifter just felt vague. Not to mention I'm really used to my Whalen **** so the stock **** just felt ginormous.
Old Sep 27, 2006 | 05:37 PM
  #43
gnhovis's Avatar
gnhovis
Reverse
Originally Posted by JustJAY
I just bought a B&M short shift kit for an '04 MCS. Question, when I opened the box, it says 10/04 and later. I believe I have a 08/04, will this still work?
For people with '04 model year cars, I was told you can tell by the color of the main shift housing when you lift the boot. If the housing is gray, then the '04 and newer one is right. If it's white then you need the '02-'03 one. Is that how it worked out for you?
02miniSguy
Nov 17, 2015 10:29 PM
vetsvette
Oct 1, 2015 12:59 PM
ToroPerro
Oct 1, 2015 12:54 PM
MINI Stupor
Oct 1, 2015 11:36 AM
Samhillrocks
Sep 29, 2015 12:55 PM
