Drivetrain Project M7 Hood Louvers!
Originally Posted by SpiderX
you know the advantage of flush rivets.......gives you that 40s aviation look
MSFITOY - On the other car pics, I see they eliminated the windshield pissers. What were your thoughts about this (considering you don't have wipers
). My first reaction was to eliminate and perhaps just add one pisser back in the center. I assume that the farther back you can mount the better?
Now that I have them and played with them a bit last night, I can appreciate you cutting them down and rounding them. DAM, I really don't want to give up my 1/9th advanatage.
). My first reaction was to eliminate and perhaps just add one pisser back in the center. I assume that the farther back you can mount the better? Now that I have them and played with them a bit last night, I can appreciate you cutting them down and rounding them. DAM, I really don't want to give up my 1/9th advanatage.
Hey, I'm just an idea guy with no accountability as to execution
I'm debating which route to go:
1-countersunk rivnuts and countersunk screws...cool and easily removeble but why go through all the trouble...
2-countersunk blind rivets...cool but not as easy to remove...
3-standard blind rivets...quick and still cool...can always do 1 or 2 later...
Probably 3 for as I want to get them on NOW...
Your 1/9 advantage is going to be sitting on top of the DFIC where it won't do much anyway
Originally Posted by MSFITOY
Yeah...more room for you to blow hot air out while your head is under the bonnet
and heres a pic of my garage / workspace (compare to MSFITOY) !!
I figure you might have some knowledge in aircraft construction with your background
Originally Posted by PARTSMAN109
Sid, maybe check these out...
http://www.hansonrivet.com/w42.htm
Thanks Joaquin...I just placed an order through McMaster for some standard rivets, countersink drill and countersunk rivets...should be able to start the installation tomorrow when they get here
Make sure you have the camera handy.
MSFITOY looking nice!! gonna be a neat mod!
i was looking in to them untill i saw a German Mini Clubsport S with this bonnet.. he had two mini rad fans to blow air thro the intercooler!
now that i likey!
now that i likey!
Originally Posted by Kentiki
Bart-Being in So Fla, is your garage about 1,000 F during the day like mine has been? If I just step foot into it, I start sweating. I need that fan of yours!
The only thing worse than my 1,000 temp Florida garage is my 2,000 temp engine comparment of my boat. The boat sits in the sun all day and there is just no air in the engine room. I drag that fan down to the dock.
now that i likey!
now that i likey!
The heat can be killer here for things like working in the garage on your car. I wouldn't even consider working on the car if I did not have one of these.
Here we go...final positioning
The pieces have been symetrically shaped, sanded and primered...
Next, I'll trace the outline of one side and transfer it to the other using an acetate template flopped over the center line...
You're not going to start offering more BS are you?
