Drivetrain Least favorite modifications
Old Sep 16, 2006 | 05:21 AM
  #126
ltz_mtr's Avatar
ltz_mtr
it may be because you're running boost in situations where you normally wouldn't (low throttle applications would usually divert more air into the intake bypassing the S/C), but now with VGS you're boosting with low enough pressure that the system can't cool the charged air. Mash the gas the temps should drop, right? I run the detroit tuned bypass valve for a more elegant solution to the issue. I have no way to check temps, but I wonder if that alters the equation? Or maybe I spent more $$$ to heat up my charged air . Then that part might qualify for this list )
Old Sep 16, 2006 | 06:42 AM
  #127
MSFITOY's Avatar
MSFITOY
Originally Posted by stevecars60
If the IC core design creates a large enough presure drop the SC needs to work harder creating more heat? What do you think? Just a thought.
If the BPV is shut when the engine is not under load, the SC is creating unnecessary pumping loss as heat...
Old Sep 18, 2006 | 08:39 AM
  #128
stevecars60's Avatar
stevecars60
No doubt.
With the BPV disconnected & tied shut, on this car, I don't see IATs anywhere near what you see. I know this is happening to more people with the VGS mod than the people posting on NAM. It's the why..... mp5999 with a 250, that's a big number..
Pker
Apr 11, 2017 12:14 AM
vulkandino
Oct 31, 2015 08:29 PM
ryGuyMCS
Oct 6, 2015 12:04 PM
point665
Sep 29, 2015 12:41 PM
R53UndaPSI
Sep 21, 2015 09:42 AM
