Drivetrain DFIC numbers
Old Jun 20, 2006 | 07:27 AM
  #176
obehave's Avatar
obehave
Originally Posted by dmh
snip.... I will, however, test it for free as I have offered.
Yea, you and about 20 more of us
Old Jun 20, 2006 | 10:19 AM
  #177
Tüls's Avatar
Tüls
Turbius Maximus
Originally Posted by mtrspt5
Same track, similar weather conditions, I can tell I have more power, as I can watch where my revs are at specific points on the track. Can this be captured on the dyno?
Yes... on an eddy current dyno.... you can even run the quarter mile... or just go for a drive... same variables... every time... the best part is the weather can always the same... especially if you dyno is inside
Went and put on an M7 extreme scoop. Same track, similar weather conditions and now I am having to shift sooner in certain sections. Another noticeable gain on top of just the GRS. Can you measure this on the dyno?
yes... same as reasons before... for instance the time it takes the car to rev out I can acuually tell with in 5 HP what it made... yeah I have spent too much time tuning cars LOL....
Old Jun 20, 2006 | 11:13 AM
  #178
rkw's Avatar
rkw
Everybody seems to be focused on doing a dyno, which is difficult to properly set up to evaluate this product. In the meantime, are there other numbers that can be useful for comparison, such as 0-60 time (or other speed ranges)?
Old Jun 20, 2006 | 12:00 PM
  #179
RECOOP's Avatar
RECOOP
Originally Posted by Will @ M7 Tuning
We want you to trust us most of all. If we can all agree that you will accept data released by M7 is data valid to the product on the test car, and not going to apply 100% of the time, but will be real, unmolested data, then I'll be more than happy to perform dyno runs on a DFIC. ...
That is quite reasonable. Your assurance that the data will not be massaged to meet marketing preconceptions is quite welcomed. In addition to your dyno data (? eddy-current set-up), it would be helpful to see results from some of your actual performance testing, as has been suggested by others. Thanks for your honesty ---
Old Jun 20, 2006 | 10:48 PM
  #180
rkw's Avatar
rkw
No comments? Was this a dumb idea? I figured that 0 to 60 runs would give proper airflow and any advantages of the DFIC should show up.
Old Jun 21, 2006 | 04:40 AM
  #181
ingsoc's Avatar
ingsoc
A proper 0-60 run would be interesting, since the DFIC seems to cool down from idle/heat soak quickly, but you've gotta think about things like launch technique and consistency. I think that a 40-70 run might be more reliable, since you're not gonna have issues with traction. Perhaps, though, the best would be to do a 40-70 or whatever and, instead of timing, to log peak g forces with a GTech or something like that. You can see which IC really helps the car pull the hardest. For windshield dynos, feel IS real!
Old Jun 21, 2006 | 08:12 AM
  #182
Bahamabart's Avatar
Bahamabart
While I think all forms of testing add value by giving us insight. I lean more towards the type of testing MATT has been doing when it comes to ICs.
MATT has tested stock, Alta, GRS and GTT. I am working with a vendor to get a Forge unit to him. I encourage M7 to do the same.
Old Jun 22, 2006 | 07:52 PM
  #183
hornguys's Avatar
hornguys
I would think 0-60 would reveal low end superiority and then a quarter mile would reveal top end.
Three runs each.
Frankly, I'd rather know those numbers than anything else.
Old Jun 22, 2006 | 08:17 PM
  #184
obehave's Avatar
obehave
Three runs each.
If that's all you're concerned with then just put a sprayer on the stock IC.
Old Jun 22, 2006 | 08:22 PM
  #185
MSFIT's Avatar
MSFIT
Originally Posted by obehave
If that's all you're concerned with then just buy an srt-4
fixed
Old Jun 22, 2006 | 08:29 PM
  #186
SpiderX's Avatar
SpiderX
Actually, Jim is one of the better autox Mini guys in the south.....I have a pretty good idea where he is coming from.
Old Jun 22, 2006 | 08:53 PM
  #187
obehave's Avatar
obehave
That's excellent but really for short bursts I can't see the larger IC helping.
It's a larger mass to heat soak between runs and if I remember right you can't spray during runs(auto-x newb here so insert slack where needed )
That said. I have the GRS and I spray the snot out of it between runs. ( I've been told this is legal?? ). Even with that by the end of my 3rd run last weekend ( course avg was around 60 sec so it was a long one, 87º and ~70%*humidity) my IC was "holy crap" hot and hard to bring down to " OK, I can leave my hand on it" temps. I hope you like my scientific terms
Just thinking that a smaller thermal mass may be easier to return to acceptable temps.
Unfortunately my IC inlet and outlet temp gauges aren't hard mounted so I have to take them out for events.
Old Jun 22, 2006 | 09:00 PM
  #188
SpiderX's Avatar
SpiderX
what the guys do down here is open the hood and put small amounts of ice on between runs
Old Jun 22, 2006 | 09:08 PM
  #189
obehave's Avatar
obehave
Yea, I forgot to mention I freeze my bottle the day before. Leave it in the fridge over night and by the time my heat rolls around there's ussally jst a block of ice floating on the bottle.
I think the ice thing is a better option but I'm **** about dinging the fins on a ~$800 IC
Old Jun 22, 2006 | 09:11 PM
  #190
SpiderX's Avatar
SpiderX
so are these guys..... home size ice cubes are carefully hand placed with lots of love.....sounds to me like you have it pretty much figured out
Old Jun 22, 2006 | 09:24 PM
  #191
obehave's Avatar
obehave
Tumbled so there are no sharp edges
Well, it works for me....that doesn't mean it's right though.
Old Jul 1, 2006 | 09:10 PM
  #192
Larry Clemens's Avatar
Larry Clemens
Originally Posted by maxmini
At this point Larry I feel that we could commit to the two week window. I am basing this on our other suppliers fulfilling their schedules as promised . If they do their job we can do ours and see that the good Dr. gets a sample to test. Thanks for the post and the interest.
Randy
M7 Tuning
Above posted 12 days ago. Will Dr. O have one next week?
Old Jul 2, 2006 | 12:18 AM
  #193
Dr Obnxs's Avatar
Dr Obnxs
Don't know for sure...
but I think when M7 has worked through the backlog (however long it may be) they'll box one up for me to play with.... But to be fair, I'd take care of the rabid customers first (and I don't mean that in a negative way....)
So while it's talken longer than some have liked, the testing is still in the pipeline.....
Matt
Old Jul 9, 2006 | 08:08 PM
  #194
obehave's Avatar
obehave
Bueller?
Old Jul 17, 2006 | 03:51 PM
  #195
WxSquid's Avatar
WxSquid
bump
Old Jul 17, 2006 | 08:05 PM
  #196
obehave's Avatar
obehave
Things that go...
Old Jul 17, 2006 | 10:35 PM
  #197
J0kER's Avatar
J0kER
...boom?
Old Jul 18, 2006 | 12:06 AM
  #198
skuzy's Avatar
skuzy
no where? :D
only kidding.. should be interesting
Old Jul 18, 2006 | 12:11 AM
  #199
Dr Obnxs's Avatar
Dr Obnxs
See post 193
of this thread....
Matt
Old Jul 18, 2006 | 07:54 AM
  #200
obehave's Avatar
obehave
Originally Posted by Dr Obnxs
See post 193 of this thread....
Matt
Oh no!
I'm stuck in an iterative loop and can't get out of this thread
