Drivetrain $8 Dollars of Home Depot Stuff...
Old May 19, 2006 | 09:54 PM
not-so-rednwhitecooper
I'll give more info later, im too tired to type
So far all i know it the intercooler doesnt stay hot for long
Old May 19, 2006 | 10:32 PM
Malcon's Avatar
Malcon
good ideal...it looks kinda funny. to me it looks like it wouldnt really get a "spraying" effect, but more of a squirting effect.
Old May 19, 2006 | 10:42 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
hahahah weren't you just telling me how you didnt want to shop from small name tuner companies because they make cheap parts?
That's ghetto rick
Old May 19, 2006 | 11:01 PM
That's ghetto rick
Haha, yes, but it works... so i will have to do more buisness with Home Depot Tuning.
Old May 19, 2006 | 11:02 PM
who said it had to spray?
it engulfs the entire IC in cold water.
Old May 19, 2006 | 11:15 PM
Rick-Anderson's Avatar
Rick-Anderson
I was thinking of using a soaker hose - LOL. Seriously, though, I bet a person could use flexible copper or aluminum refrigeration line with VERY small drill bits to make a pretty cool (pun intended) sprayer.
Old May 19, 2006 | 11:24 PM
well, thr true test will be to see if it heps keep the car cool while drag racing. i have a serious heat soak issue.
i went from a 14.8 cold to a 15.3 hot!
Old May 20, 2006 | 06:46 AM
batrugger's Avatar
batrugger
You wouldn't need to drill, you could just use the misters that they sell to cool off patios
Old May 20, 2006 | 07:44 AM
Rally@StanceDesign
they also make some "mist-er" connections for watering plants on a timed machine.....it lets out a very fine mist.
Old May 20, 2006 | 07:53 AM
Smokey's Avatar
Smokey
If you were at Home Depot you should have gone to the garden section and picked up some 1/4" black irrigation tubing. Much smaller footprint and they have small misting nozzles. Different spray patterns also!
Old May 20, 2006 | 08:02 AM
polizei's Avatar
polizei
Seriously...I'm interested in doing something like this just because....lol. How do you make it work, how would I make it work, and where did you run, and how did you run the line for the water? Instructions would be awesome. Maybe this will be my first DIY project just for fun. I don't ever race, so it would in sense be useless to me...but still fun! haha
Oh, and how would I run the water (from the windscreen sprayer I'm guessing? With just water?) so that I could JUST spray the IC, not the entire car (ie. Headlamps, and front&rear windscreens)?
MCSG - MINI Cooper S Ghetto lol
-Cody
Old May 20, 2006 | 12:32 PM
bmweater's Avatar
bmweater
I like it! But how do you get the water to spray? And wheres the resvoir?
Old May 20, 2006 | 12:35 PM
Motor On's Avatar
Motor On
I'm glad I'm not the only one who bought car parts from the Depot yesterday.
Old May 20, 2006 | 12:48 PM
Smokey's Avatar
Smokey
Most just use the headlight washer system as the res and pump method.
If you don't have the xenons - a washer pump at autozone is like $5 and a few feet of hose, wire and a momentary on switch and you've got it!
Old May 20, 2006 | 02:47 PM
Rally@StanceDesign
just a heads up. If you dont have xenons, you dont have a resevoir on the driver's side....just the windshield one which is on the passengers side. Only xenon fitted cars come with the driver's side resevoir. It can be purchased through your dealer, or even from mini madness (for one of their cooling related mods).
Old May 20, 2006 | 03:53 PM
qwertmonkey's Avatar
qwertmonkey
Just a few questions: what is the source of the water? What and where is the reservoir? How do you control it?
Old May 20, 2006 | 08:26 PM
Windshield washer bottle and pump wired to a momentary puch button.
also, i changed the design today, i'll post pictures later...
Old May 20, 2006 | 09:03 PM
polizei's Avatar
polizei
I was going to go and purchase the parts tomorrow.....any chance on an update? I need to know what to buy, how much work is invovled (if it's even worth it really), where/how to run the stuff, etc.
And where do you get a "punch" switch, and how/where do you mount it!?
Thanks a ton! New pics would be awesome too when you get a chance!
-Cody
Edit* My idea was to get small black flexible tubing from the gardening section, approx. 1/2" diamter or smaller, and drill holes in the tubing, which will be all around the IC. I then would run that into a tank of water of some sort.....then hook up a button (your "punch" button I guess) then I should be good! Hopefully it will cover the whole IC, but how do I get it to "spray" more than "squirt"?
Old May 20, 2006 | 09:27 PM
Motor On's Avatar
Motor On
You can pick up a momentary switch from radio shack, the come in packs of two and have several options (including jet fighter cover)
Curious as to why not use vaccum line for the plumbing, I imagine it would cost less than $8 at that point, but cool idea and good job of putting it into practce.
Old May 20, 2006 | 09:54 PM
Mine doesnt srpay, it squirts solid 1/16th of and inch streams.
It covers better thand it covers faster than a mist does.
Old May 20, 2006 | 10:02 PM
Rally@StanceDesign
wouldnt mist be better for the cooling properties though? or am i mistaken that its the evaporation that helps lose heat?
Old May 20, 2006 | 10:06 PM
beats me.
all i know it it goes from hot to cool very quickly.
Old May 20, 2006 | 10:14 PM
MSFIT's Avatar
MSFIT
black zipties > blue zipties
Old May 21, 2006 | 08:31 AM
polizei's Avatar
polizei
How do you have the button ran so when you press it, it release's the water? And how do you/can you set up the button and water. Ie. hold the button done for aslong as you want, or hit the button once....it's on a timer, say 3sec?
And how does your tubing "squirt" the water all over the IC? Where did you drill the holes so the water will come out. And how did you run the tubing into the resivor? I was thinking of rigging up a standard bottle somewhere, and having the tube getting water from there. This would save the water for the windows to...or would this just be absoutly pointless?
-Cody
Old May 21, 2006 | 10:53 AM
thebill's Avatar
thebill
So you're spraying windshield washer fluid onto the intercooler? Isn't that what's in the windshield washer fluid reservior? Or do MINIs use water on the windshield because they're so special?
I was just reading on another thread of someone using a soft plastic reservior sourced from a Nissan truck - might have a pump built in & may be easy to fit in somewhere, maybe behind the "firewall" on the passenger side?
