Drivetrain Wisdom of raising the rev limiter??
Old Apr 21, 2006 | 06:24 AM
SpiderX's Avatar
SpiderX
1) I over red line my car from time to time and when the engine cuts .. I get a little annoyed.....I have thought of raising the rev limiter. The question is that on my dyno sheets the torque starts to die off up there so what is the answer...... is this worth doing or not?
2) the unichip does not have the ability to raise rev but MTH does so I am considering getting an MTH flash just to raise the rev limiter
3) is there a MTH on dyno tune format yet?
Old Apr 21, 2006 | 08:54 AM
ingsoc's Avatar
ingsoc
There's still power to be gained above 6800. There is NO hp loss from 6800 to 8000, at least with a Schrick cam... Even when the 8k software that I am running was first being developed and wasn't yet dialed in (during testing), they saw gains past 7500, which held to redline. With development, it sure feels like they've tapped even more power, although I will not know about the performance on my car until my summer vacation comes [when final tuning is done and I can make it to the dyno]. It's all in the tune, though.
Of note, torque can and will fall off depending on your head work, but rpms are high enough that hp ["power"] continues to climb and hold.
Old Apr 21, 2006 | 09:49 AM
Johan's Avatar
Johan
MTH will not bring your RPM past 7250 -- Johan
https://www.northamericanmotoring.co...&highlight=rpm
Old Apr 21, 2006 | 12:43 PM
SpiderX's Avatar
SpiderX
Hmmmm ..... anyone else?
Old Apr 21, 2006 | 04:21 PM
Wesport's Avatar
Wesport
I have somewwhere around a 7200 cut off with Giac and 15%. This is great - I use this regularly on the track and yes - there is better power up their. I will be moving to 18% soon and am aware that this will overev the SC. But I do not want to give up the higher redline. Any thoughts?
Old Apr 21, 2006 | 04:53 PM
MSFIT's Avatar
MSFIT
Doesn't m7 have like 8250 software?
Old Apr 21, 2006 | 06:39 PM
macncheese's Avatar
macncheese
RPM = Ruins People's Motors
Old Apr 21, 2006 | 06:46 PM
SpiderX's Avatar
SpiderX
The red lines for the SC are posted somewhere and yes with 18% you stand a good chance of hitting the red line of the SC....the question is, for how long....... a used SC goes for between $300 and $450 plus the labor.... this is an old debate...lots already written.....
I am thinking about what the power is like at the extreme top...... I notice that I can shift at 7000 and the rev limiter does not hit but if I was to drive for 15-20-25-30 seconds at 7500 I would be concerned for the SC.....are you following this? 7250 with 19% is really living on the edge of getting out the check book but I think that is where I want to go because my duration will be only a second or two
who knows the cheapest way to accomplish this?
Old Apr 21, 2006 | 06:47 PM
MSFITOY's Avatar
MSFITOY
I agree on this one...if one wants a high RPM motor, it needs to be carefully engineered to operate at higher than designed revs...short stroke, lighweight reciprical componants, blue printed/balanced everything...not very reliable nor cost effective with MINI's current powerplant.
Transplanting a Hyabusa is a better way to go if you want high reving power...350hp and 13,000rpm
Old Apr 21, 2006 | 06:51 PM
SpiderX's Avatar
SpiderX
Originally Posted by MSFITOY
I agree on this one...if you want a high RPM motor, it needs to be carefully engineered to operate at higher than designed revs...short stroke, lighweight reciprical componants, blue printed/balanced everything...not cost effective with MINI's current powerplant.
There you have it....... thanks Sid
Old Apr 21, 2006 | 08:01 PM
ingsoc's Avatar
ingsoc
Meanwhile, I'm still enjoying my 8000 rpm with an 18% . So far, so good.
Old Apr 22, 2006 | 06:46 PM
Wesport's Avatar
Wesport
Next week when I change from 15% (Alta) to 18 % (M7 16% + M7 2% crank pulley) and add the new 380cc injectors from Helix I will go get my 15% Giac refreshed with the 18-19% Giac flash made for bigger injectors. I do not know if this will lower my redline from the 7200 the Giac 15% gave me (anyone know?). I do not mind killing the SC as long as it does not hurt the internals. Of course if the SC last then great. On Road Atlanta I probably do spend at least 20 seconds every lap over 7k.
Wes
Old Apr 22, 2006 | 08:12 PM
SpiderX's Avatar
SpiderX
I say, GO FOR IT.....it's only money and down time...if you can afford it .... be like the guys who track their Lambos and blow them up regularly.... (now that is real $$$$$$).... we have to have people who push it so we know where the limits are....may as well be you..... we owe you a debt of gratitude my good man....
Old Apr 22, 2006 | 11:07 PM
BFG9000's Avatar
BFG9000
I have the GIAC for 19% from Helix, and the rev limiter is 7200.
Old Apr 22, 2006 | 11:12 PM
MSFIT's Avatar
MSFIT
http://www.ballerzrun.com/
totally off topic...but speaking of people spending way money..
Thank you for applying for BallerZ Run.
1. Fill out the form below in it's entirety. All fields marked with asterisks * are required.
2. Make sure you provide us with accurate contact information
3. Press the submit button when completed
4. If we choose to accept your application you will be contacted within 24 hours of your submission
5. Once accepted, payment must be paid in full within 72 hours to hold your spot and a car # will be given to you.
$9,985 entry fee increases to $11,485 on March 1st.
e30-ix kid
hahaha, that is an excellent idea. no more $75,000 speeding tickets with any luck.
it was 75k right? i havent watched it in a while.
that was his bail, but it got lowered
Old Apr 23, 2006 | 01:13 AM
Soul Coughing's Avatar
Soul Coughing
there's one run, that took place in 4 continents, and it was about 100 grand to enter, it included things like air flights for all cars, registration for all countries, 5 star hotel etc... i would need alot of money to warrant wasting it on something like that..
Old Apr 23, 2006 | 05:08 AM
Bahamabart's Avatar
Bahamabart
SO when the cab drops you off at the house and your wife wants to what the hell happened and why was the car towed to the dealer - you can say "its not my fault, SpiderX made me do it!"
Old Apr 23, 2006 | 05:09 AM
SpiderX's Avatar
SpiderX
Exactly...... remember the add "Give it to Mikey"
Old Apr 24, 2006 | 06:53 AM
Rickkys'S's Avatar
Rickkys'S
Spider X,
I went through the same problems as you with concerns with the MTH and Unichip!
What i have done is send my standard file off to a company in the UK called chip tuning info@chiptuninguk.com who i had raise it to 7600rpm , then i got mth to raise the idle 150 rpm then loaded it up and got the whole thing set up on the dyno with the unichip!
I also have 1 standard file set at 7250 run for 98 ron fuel and 1 for 95 ron fuel, but i use the 7600rpm all the time!
It cost me £60 to get the rev raised via e-mail so that will be around $100 i guess.
I do wish i set it up to 7400rpm now as my power drops away at 7325rpm on the dyno and regardless to what people think 8125 imho is too much for our little mini unless you have serious mods to hold it together, the kind of mods that Jlm done to his motor....endyne was'nt it!
I think that the power may be dropping off due to to much heat from the 19% or because of valve float but how can i tell!
I must say though that the Unichip is very good indeed and am really glad i went down that route, it will be running a water inj system in the next couple months so its not just a chip and is very versitile.
Good luck!
Old Apr 24, 2006 | 09:17 AM
SpiderX's Avatar
SpiderX
Originally Posted by Rickkys'S
Spider X,
Good luck!
Thanks for the post..... valuable input, again thanks
Doc Pain
Mar 10, 2021 04:50 AM
M7Speed
Jul 10, 2018 09:26 AM
Suspension Products
Oct 1, 2015 11:53 AM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
Sep 28, 2015 09:13 AM
