Drivetrain M7 DFIC
Originally Posted by Dr Obnxs
First off, I'm happy to test this exactly the same way I did the Alta, stock and coated units. The data set will be nice.
And the Alta was a prototype, this is much closer to the released product.
Look in Alta's thread, and they too are going ahead with the unit.
Alta's prototype didn't have as good thermal efficiency as the stock, but had lower pressure drop, and did create more charge denesity and power.
The testing was done with a G-Tech accelerometer, not a dyno, but did get real-world air flow conditions.
Pressure drops were measured vs RPM with no load.
I'm not saying this as an edorsment or a slam to Alta's unit, just correcting some errors posted earlier in the thread.
With all that, the M7 unit looks nice, I saw it at AMVIV. When they have an extra unit and I have all my diagnostics back, I'll put it through the paces and let people know what I find.
Matt
Matt
So patents of the M7 unit seem ok with the Alta unit ?
I just called Randy to see how it was going with the DFIC, to my surprise he and Peter were actually in his car getting some numbers! He was reading them off as he was talking to me and the IC outlet temp just kept dropping!
Unreal, to say the least. Looking like I will scraping up some cash for this one!
I sure hope that they were driving through some cooler air
64 degrees out with 70 ambient (real jelous here, as it's mid 40s and raining outside) would be some serious mojo!
Matt
Matt
Matt
Matt
Originally Posted by TonyB
PARTSMAN109 - Sort of why I chimed-in on that thread you started a couple days ago
The cooler than ambient might be partially attributable to precip, if any...
Sorry I had to edit post #53 and remove the numbers.
I misunderstood Randy when I asked if I could post the numbers he was telling me.
Originally Posted by PARTSMAN109
They didn't say anything about weather conditions.
Sorry I had to edit post #53 and remove the numbers. I misunderstood Randy when I asked if I could post the numbers he was telling me.
However, the numbers are consistant from what I've experienced with IAT data collecting...If the standard Ram Intake can bring the IAT of Alta IC to within 15F of ambient (regardless whether it's 10F or 80F ambient), then it's not a stretch to conceive that a DFIC with much less air flow restriction (as the air flow is not taking two 90 degree turns before exiting) and higher velocity combined with an asymetric Ram Intake that incorporates roughtly double the apature area could drop the temperater another 10F...right about what they were reading
Originally Posted by MSFITOY
Too late
The numbers are consistant from what I've experienced with IAT data collecting...If the standard Ram Intake can bring the IAT of Alta IC to within 15F of ambient (regardless whether it's 10F or 80F ambient), then it's not a stretch to conceive that a direct flow with much less air flow restriction (as the air flow is not taking two 90 degree turns before exiting) and higher velocity combined with an asymetric Ram Intake that incorporates roughtly double the apature area could drop the temperater another 10F...right about what they were reading
I just got the real numbers and you wouldn't believe me if I told you
It appears too low to be physically posible but numbers don't lie. However we have some theories as to what is happening...Dream come true is all I can say for now
Will...looks like you'll need to do some CFD testing with the new Ram Intake as part of the equation to explain this
I do have a theory or two to test!
So when will we see some figures and numbers for this new intercooler?! I'm extremely anxious now...Should we go ahead and spend $900 on this, or wait another year and hope someone designs an efficient front mount?
Thank you all for being patient......
The R&D core has been tested many times since it's inception, but the scoop and diverter was questionable at best. As we did add two test ports on our
patented intercooler design, numbers where only a test instrument away
and honestly the numbers where very, very
promissing indeed.
As the hood scoop was received last Tuesday and the new diverter Thursday
morning, no time for testing was available last week (AMVIV Thurs-Sunday).
Fast forward to this afternoon and all I can say is......I'm stunned and
very, very
excited. I will give one set of numbers and I hope you understand
why I will hold back some of the readings as Will is doing some CFD Sim's
to figure out what happened.
M7 DFIC testing
70mph
3400 rpm
11.7:1 air fuel ratio
Pre core 182˚
Post core 63˚
Peter
Team M7
562-608-8123
promissing indeed.As the hood scoop was received last Tuesday and the new diverter Thursday
very, very
excited. I will give one set of numbers and I hope you understand why I will hold back some of the readings as Will is doing some CFD Sim's
M7 DFIC testing
70mph
3400 rpm
Pre core 182˚
Post core 63˚
Peter
Team M7
562-608-8123
Originally Posted by M7
M7 DFIC testing
70mph
3400 rpm
Pre core 182˚
Post core 63˚
Peter
Team M7
562-608-8123
70mph
3400 rpm
Pre core 182˚
Post core 63˚
Peter
Team M7
562-608-8123
. Peter, ol' buddy ol' pal, you may just need to throw a release party at the Dragon for this
. You know that Team M7 will be out, in full force!
Pre core 182˚
Post core 63˚
Pre core 182˚
Post core 63˚
A big thumbs up to M7
promissing indeed.
very, very
M7 DFIC testing
70mph
3400 rpm
Pre core 182˚
Post core 63˚
Peter
Team M7
562-608-8123
very, very
M7 DFIC testing
70mph
3400 rpm
Pre core 182˚
Post core 63˚
Peter
Team M7
562-608-8123
wow.
