Drivetrain Questions about OBX header and cats
Old Mar 22, 2006 | 12:20 PM
gobble's Avatar
gobble
After reading multiple posts about the OBX header, I'm really confused. My understanding of the MCS is that it has a pre-cat in the header followed by a main cat farther down the line. I've read multiple posts about people welding a cat to the OBX headers and don't understand why.
Lets assume I have a car that is used off-road only. If I remove my stock header and pre-cat assembly, can I simply bolt the OBX cat-less header in its place? Is it the same length and does it have the same connections as the stock assembly?
Old Mar 22, 2006 | 12:31 PM
Bahamabart's Avatar
Bahamabart
If your running off road - you do not from a legal stand point need a CAT. People are adding a CAT to the OBX header for street (legal) purposes. Pipe wise if you add a OBX header with out the CAT - you will be pipe short about 12" - basically the length of the CAT plus flange. But its simple straight pipe - no big deal add.
Old Mar 22, 2006 | 12:41 PM
gobble's Avatar
gobble
Am I right that there are two cats in the Mini? A precat and a main cat?
If so, removing the cat from the header would simply mean removing the pre-cat and the car would still pass an emissions test where I live. You would still have the main cat downstream. Right?
Does someone sell a straight pipe that fits or would I need to have something custom fabricated?
Old Mar 22, 2006 | 12:59 PM
Bahamabart's Avatar
Bahamabart
NO - The OBX header replaces - the stock exhaust manifold, precat and cat. If you want to pass emissiones test you have two options - graph stopck cat to obx header or purchase an aftermarket cat.
MIDAS/ any muffler shop can add the straight pipe - I don't think it qualifies as "custom" fabrication.
Old Mar 22, 2006 | 01:05 PM
gobble's Avatar
gobble
So the stock header has both a pre-cat and a main cat? If you weld the stock cat to the OBX header, do you end up with a main cat and no pre-cat? I guess I need to look at my car when I get home. I had an RX7 years ago that had a pre-cat in the header and a main cat farther down the line. It was quite common to replace the pre-cat with a straight downpipe. I was thinking the Mini had the same setup but I must be wrong. It would be nice if there was a bolt on cat that didn't require welding.
Old Mar 22, 2006 | 01:39 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
If you check other threads you'll see quite a few "bolt on cats" used with many aftermarket headers. I saw a guy with the OBX header and he cut the cat off the stock header and had someone weld a flange on to that end. He then bolted the header to the engine, the welded-on flare cat to the header and the cat flange to the exhaust pipe. Seemed to work just fine. I don't think you need the pre-cat to pass emissions (maybe not all states) but you sure need the cat, or some software that fools the engine into thinking it has one, and a sympathetic authority when they find out you don't have a cat on the road (!)
cheers,phil
Old Mar 22, 2006 | 01:50 PM
gobble's Avatar
gobble
It seems like for all the screwing around required for the OBX header including having to buy a cat and having to pay a muffler shop to do the install and welding the $950 or so cost of the Milltek header doesn't look so bad assuming you can bolt it on yourself.
Old Mar 22, 2006 | 02:27 PM
minimort's Avatar
minimort
The thing with that is, the OBX header is around $200 - $220 shipped, the Magnaflow cat or aftermarket cat is like $60 and to have a muffler shop install both and weld everything is like another $60, so that's what, $340 total?
That's why the OBX is a good deal, you save $600
Old Mar 22, 2006 | 02:29 PM
gobble's Avatar
gobble
I was guessing around $200 for the muffler shop labor assuming they charge at least two hours plus materials.
UPDATE: Just called the local Midas and explained the installation. They estimated $250-$300 knowing that the Milltek header could be installed in about 1.5 hours.
Old Mar 22, 2006 | 04:49 PM
minimort's Avatar
minimort
Sounds like the shop is charging a little much for that. MINI dealerships charge $100 an hour, so that would only be $150, so Midas should be able to do it for much less
Old Mar 23, 2006 | 06:51 AM
Bahamabart's Avatar
Bahamabart
I took all of the NAM information and pics posted and gave it to a qualified mechanic and had it installed (OBX header w/ stock CAT) for $400 BUCKS (parts and labor = all in). The job was turned around in about two hours.
Old Mar 23, 2006 | 10:31 AM
Longboard Mini's Avatar
Longboard Mini
I took off and installed my OBX header ($160 with shipping) myself in about 1 1/2hr's. Fit and finish was excellent. Install was simple.
I drove the car (sounded like a drag car) to my local "independent" muffler guy. He cut my old cat off the stock header took a couple measurements and welded on the supplied flange. He bolted it all together and we were done. He charged me $50.00 for his time.
My out of pocket cost: $210.00 .
Performance is great and the sound combination with my milltek still makes me smile.
Old Mar 23, 2006 | 12:46 PM
The MINITOR's Avatar
The MINITOR
All the screwing around (cutting and welding) cost me an additional .5 hours of labor at my shop, or $32.50.
PhoR53
Aug 21, 2015 05:10 PM
Aug 21, 2015 10:36 AM
Aug 12, 2015 01:24 PM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
