Drivetrain Alta Turbo Kit
Old Apr 12, 2007 | 04:56 AM
  #276
Mini-Morgan's Avatar
Mini-Morgan
Hi everyone,
I've been reading this thread with lots of interest and so close to taking creating an Alta twin charge too but just have a few questions really:
How long is the turbo lag? I was thinking it might be less having the extra exhaust pressure from the SC output.
Does anyone have a copy of the install instructions or maybe an install how to guide? Really any help with getting it 100% right first time around is very welcome.
Since i'm on the other side of the pond does anyone see any problems with the right hand drive car having a different lay out? e.g. brake cylinder and such.
Is anyone using their kit with the standard MINI LSD too?
I'm only planning a fully stock setup to begin with and then moving onto 20+ boost later after quite a few mods.
Thanks guys! What i've read so far has to be the most info anywhere on the net in one thread about twin charges. Fantastic! What impressed me most is just how helpful everyone is and even Alta dropping by to see how you're doing.
Old Apr 12, 2007 | 07:22 AM
  #277
Trickle X's Avatar
Trickle X
Send me your email addy and I can forward you the install instructions. Do you happen to have bonnet pix? That would help as I would be able to see what was different from the left hand drive.
As for turbo lag, its really not an issue.
Old Apr 12, 2007 | 12:57 PM
  #278
Mini-Morgan
Thanks for the quick response. Will PM you in a minute with email addy
Here's a couple of pics. I'd really love to keep the strut brace if I can work around it as it really has made so much difference to the cars handling that you wouldnt believe! Let me know what you think. I can get different angles if required down the back tomorrow if you require?
Is anyone running the V2 Alta Intercooler with great success?
Attached Thumbnails Alta Turbo Kit-dave1.jpg   Alta Turbo Kit-dave2.jpg   Alta Turbo Kit-enigne_322.jpg
Old Apr 12, 2007 | 01:06 PM
  #279
Trickle X's Avatar
Trickle X
I dont see anything that is different from that view than the lefthand drive cars. The big thing would be your DP clearance. I am not sure if your steering linkage would be in the way then. Its hard to see in there, and you really will be removing all of the back black plastic. As long as the steering linkage isnt in the way you should be good. As for the strut brace, the intake pipe may clear it underneath, but if not, you may need to alter that pipe. Check out the pix in my gallery to see how high it runs. There is a little bit of play with the pipe depending how u clock the compressor side of the turbo.
Old Apr 12, 2007 | 01:16 PM
  #280
Mini-Morgan
Thats good thinking and i'll check in the light but i'm confident that the power steering shouldnt be too much of a problem.
Have just been look at a few peoples installs and looks defiantly possible to work around the strut brace but just need to watch for engine movement so probably somenew engine mounts.
Thanks for having a look, always good to get a second set of eyes to have a quick look for anything I might have missed.
Old Apr 22, 2007 | 01:08 PM
  #281
Mini-Morgan
Hi
Looks like there wont be a problem on a right hand drive.
A couple more questions though:
Has anyone has problems with engine temps using the +5% supercharger pulley? e.g. less water flow
Is anyone running the kit or similar with a stock pulley?
Anyone working on or have removed the supercharger completely and using an electric water pump?
Old Apr 22, 2007 | 01:18 PM
  #282
Tüls's Avatar
Tüls
Turbius Maximus
I run with stock pulley...
300 and 400 HP TC video
(the above video was before the front mount)
and here's the Widow with the SC removed
Widow
Old Apr 22, 2007 | 01:41 PM
  #283
Trickle X's Avatar
Trickle X
Yeah....heat is an issue....I do notice I run hotter even at idle. I am removing the SC in the next few months & running an electric pump.
Old Apr 22, 2007 | 02:30 PM
  #284
Mini-Morgan
Widow
Wow great vids! Naturally I would love the Widow but have to be realistic at the moment. Still 300HP in a MINI has to run fantastic!
Old Apr 22, 2007 | 02:44 PM
  #285
Mini-Morgan
GTT tuning over here are about to release a turbo only kit very soon but they are looking for £8K/$16K which is far more than id like to spend. They have raised a very interesting issue with how water is passed through the block e.g. in and out the same side because the SC is blocking the cylinder 1 port which explains why so many tuned MINI block that cylinder first.
Also with an electric pump you can delay it starting to let the engine warm up a bit more or vary the flow depending on temp and even run for a minute after the engine stops to cool the turbo and protect it a bit from the extreme heat once the engine stops.
Let me know how you get on! Are you creating a new inlet manifold yourself?
Old Apr 22, 2007 | 02:45 PM
  #286
TC1's Avatar
TC1
Wow, Tuls, I am real impressed. Neat video too. Maybe someday I'll get to 300 horse power in my MINI... maybe...
Old Apr 22, 2007 | 06:17 PM
  #287
Longboard Mini's Avatar
Longboard Mini
Widow
Awesome vid. I would love to go for a ride in your car some time. Are you coming to socal anytime soon?
Longboard
Old Apr 22, 2007 | 08:27 PM
  #288
sandersonc2002's Avatar
sandersonc2002
I am also interested in the ALTA Twurbo. Could someone foward me a copy of the instructions? I'd really appreaciate it Thanks!
Old Apr 22, 2007 | 08:29 PM
  #289
Trickle X's Avatar
Trickle X
Send me your email addy...
Old Apr 22, 2007 | 08:33 PM
  #290
sandersonc2002
my email is sandersonc2002@yahoo.com
Old Apr 22, 2007 | 08:47 PM
  #291
Trickle X's Avatar
Trickle X
You have mail!
Old Apr 22, 2007 | 08:49 PM
  #292
sandersonc2002
Thanks!
Old May 8, 2007 | 08:39 AM
  #293
Mini-Morgan
Afternoon guys!
Quick question on mounting of the Turbo, does the ALTA kit have a brace to mount the turbo or is it purely held in place by the manifold/manifold bolts? Do other kits do it the same way.
My drive to work with ever increasingly bad roads just got me thinking this morning that the manifold bolts must have to take some punishment with the pot holes around here.
Old May 8, 2007 | 09:42 AM
  #294
Trickle X's Avatar
Trickle X
No the only thing holding it in is the manifold and the downpipe bolted to the rest of the exhaust. Mine is holding up fine, but make sure you get their thicker manifold as the thinner ones will crack in short order.
Old May 8, 2007 | 10:33 AM
  #295
Mini-Morgan
Thanks, defiantly will make sure its the thicker one and i'm just waiting for the new CAT downpipes to become available. Will be interesting to see if there is any power loss with the CAT but required for me to get through the tests over here. Will be working on a decat pipe for track use as a future plan.
Cant wait! Let the project begin!
Old May 8, 2007 | 05:46 PM
  #296
SSMini's Avatar
SSMini
Need some help... Does anybody have instructions on how to install the O2 simulator? I tried to open the PDF file 4-5 times with no luck. I emailed then with no reply. Really wish they would include instructions with the part.
Thanks....
W0TM8
Dec 19, 2019 07:50 AM
AWOL
Mar 28, 2016 10:51 AM
Mib4840
Oct 13, 2015 10:10 AM
stierzy34
Sep 15, 2015 04:40 PM
