Drivetrain headers-what do you have? which is best?
Old Apr 28, 2006 | 11:28 AM
  #126
Dr Obnxs's Avatar
Dr Obnxs
Probably the ones with the OEM cat.
From the top, the heat shields block any view. To get flagged, they'd have to go under the car, or put you on a lift.
Matt
Old Apr 28, 2006 | 11:47 AM
  #127
Mini Works's Avatar
Mini Works
Hello 04SDmini
of all the headers have seen out there,
the Larini picture below, look the most factory like
It does have the two locations for the 02 sensors
Old Apr 28, 2006 | 12:00 PM
  #128
Dr Obnxs's Avatar
Dr Obnxs
Except for that shiney SS look...
so it would have to get very dirty to look OEM.... I know! Stamp Mini all over it!
Matt
Old Apr 28, 2006 | 12:54 PM
  #129
Mini Works's Avatar
Mini Works
Maybe it needs a mini sticker
Old Apr 28, 2006 | 01:55 PM
  #130
mattsmini's Avatar
mattsmini
broken megan header
Hey guys I just thought you would like to know I found out yesterday that my pilo/megan race header has a leak in it. It's the first version header the one with the long flex pipe in it, any ways that flex part is now leaking and sounds horrible . I just emailed Pilo and am now waiting for a reply. Also it's only been on around 2500 miles. Has anyone else had this problem?
Old Apr 28, 2006 | 02:13 PM
  #131
markldriskill's Avatar
markldriskill
What I'd like to see...
A "showdown" dyno and road test as closely controlled as possible between the following headers comparing results with and without catback systems and with and without ported head; all other mods /conditions frem aining equal. And have a panel of judges respected in the Mini community to oversee all the testing:
> bone stock OEM
> JCW
> Dinan
> Milltek
> Larini
> Alta
> OE with pre-cat "removed"
> any other "street legal" (TUV approved would be Okay with me) headers
clearly displaying all of the following statistics for all test systems:
> HP through entire rpm range
> interior and exterior dB
> torque through entire rpm range
> scientifically recorded sound clips
ONLY REASON I CAN THINK THAT the manufacturers aren't doing it themselves -- not even in smaller scale -- is that it just isn't that impressive bang-for-the-buck improvement!!
Manufacturers -- prove me wrong... I dare you!!!
Old Apr 28, 2006 | 02:20 PM
  #132
Dr Obnxs's Avatar
Dr Obnxs
You'll never get it.
It's a biatch to compare something as simple as air fliters! And headers are even harder. and then there's the fact that the results will be much different given a car with and without a ported head, for example.
Sorry.
Matt
Old Apr 28, 2006 | 10:10 PM
  #133
maxmini's Avatar
maxmini
I have the Jackson racing header modified by the addition of the stock cat. There will be no smog issues .
Randy
M7 Tuning
Old Apr 30, 2006 | 07:40 PM
  #134
skuzy's Avatar
skuzy
Originally Posted by Bahamabart
Its available TODAY.
OBX Header (200 bucks) + recycled stock cat = my total cost plus install was 400 bucks. Of course you can opt to purchase an aftermarket cat.
my poitn exactly. Mini works, etc vendors pay attention. obx = $200.. and u get the same results. aftermarket cats can even be purchased and included and the total cost will still be way lower than $1000+
Old May 1, 2006 | 04:58 PM
  #135
JSCspeed's Avatar
JSCspeed
Just as an FYI, the new Alta headers are out right now, these are brand new -- available with or without a cat.
They are priced well-above the $200 offerings mentioned earlier.
If anyone is interested, PM me for pricing I have both models (catted and catless) in stock.
There is a lot of R&D behind these, typical of Alta -- very nice piece.
Old May 1, 2006 | 05:29 PM
  #136
meh's Avatar
meh
Great bang for the buck!
I'm running the OBX header coated inside and out with Jet-Hot and a magnaflow 2.5" cat all for under $450[IMG]images/smilies/thumb-up.gif[/IMG] Just remember to clear out the holes of the coating before installation or you'll end up doing it 2x
Old May 1, 2006 | 07:20 PM
  #137
Yangsen's Avatar
Yangsen
Drop USD $1,275 then you can spoil yourself with the Hamann manifold...
Sorry, I have only got pictures of the wrapped manifold. However, if you'd bleed another $2,200 or $2,500 you can have the CAT pipe and the muffler as well...
Attached Thumbnails headers-what do you have? which is best?-hamann-mini-manifold-1.bmp   headers-what do you have? which is best?-hamann-mini-manifold-2.bmp   headers-what do you have? which is best?-hamann-mini-muffler-1.bmp
Old May 1, 2006 | 07:44 PM
  #138
Mini Works's Avatar
Mini Works
I agree with you guys that $1000 bucks is a lot of dough for a header,
However lets be real,
You cannot compare my larini header to the OBX with the factory cat.
Our manufacturer Larini, did not gave us any printed material, but he assured us that on the dyno there was an increase in both HP and Torque.
And I agree with Dr Obnxs, it will be almost impossible to test all headers, unless someone has them all available and installs them on the same car, the same day, running on the same dyno.
Now to defend the manufacturers, at least the reputable ones, they will not bring to the market a product that they will not believe in, or proved to not be worth it, they have a reputation, too much too loose.
And as some of you said the market for headers for the mini is just to small.
I can guarantee you, that the Larini header might be expensive, but it is by far the best header available at this time.
Victor
Old May 1, 2006 | 08:36 PM
  #139
ingsoc's Avatar
ingsoc
No offense meant, but this just sounds wrong. What basis do you have for that guarantee, then?
By the way, you seem to be the only vendor who actively advertises their product offerings in related NAM threads, if you hadn't noticed... It's kind of getting tired. Again, no offense- just an FYI. Good luck with your entry into the market.
Old May 2, 2006 | 07:44 AM
  #140
JSCspeed's Avatar
JSCspeed
Got a taker on the Alta header dyno.
Old Dec 18, 2006 | 10:20 AM
  #141
mini_r53's Avatar
mini_r53
DUZ header uses thinner material so it is not durable.
Header was broken after drove on truck.
Probably this user is using inefficient exhaust pipe so exhaust gas won’t come out smoothly.
Old Dec 18, 2006 | 10:39 AM
  #142
JeffS's Avatar
JeffS
No, that's just the risk you run when you decide to build/install a system without any flex joints.
Old Dec 18, 2006 | 10:43 AM
  #143
minimc's Avatar
minimc
Looks blown apart to me... unrelated to metal thickness IMO
I could be totally off base, but it looks to my eye like this MINI owner cooked his cat, then kept driving till the canister blew apart. If true he might've baked his valves too. Just amazing that the cat should look so mangled! I can (only assume) that the heat & pressure in front of this mess is more of the root cause for failure. Further speculation... cat failure precipitated by some serious & LOUD backfire. I just can't see how driving it onto a truck could do this.
Old Dec 18, 2006 | 10:44 AM
  #144
mini_r53's Avatar
mini_r53
wooow
Thanks for your explanation.
This user didn't realize what is the problem.
Old Dec 18, 2006 | 11:15 AM
  #145
SpiderX's Avatar
SpiderX
I have a Miltek with the Milltek catback and I like the sound and power...... for the 62 I am getting a custom unit....... for the M45 I like the sound of the Milltek
Old Dec 18, 2006 | 01:01 PM
  #146
obehave's Avatar
obehave
That is one complicated exhaust system.
Old Dec 18, 2006 | 04:36 PM
  #147
stevecars60's Avatar
stevecars60
Complicated? It comes with a map. I think. It must. Right?
What do you think 1 of those bad boys cost? 1 pipe through 2 mufflers, then splits into 2 pipes into 1 muffler into 2 exhaust pipes, lots of nice bends... Whoa... A picture IS worth a 1000 words. We got da proof....
Old Dec 18, 2006 | 04:48 PM
  #148
obehave's Avatar
obehave
The Celtic Knot design.
Old Dec 18, 2006 | 09:57 PM
  #149
markldriskill
It's a three-ball.
Old Dec 19, 2006 | 05:08 AM
  #150
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
And as Lance Armstrong proves, all you need is one ball! That sucker must weigh a ton unless it's titanium... Yeh, I want one of those!
Or not.
