Drivetrain Spotting LSD
Old Feb 10, 2006 | 02:32 PM
davidlt4's Avatar
davidlt4
Spotting LSD
How can you tell if your MCS is equipped with LSD?
Old Feb 10, 2006 | 02:35 PM
orthomini's Avatar
orthomini
lsd
it starts to see trails and colors.
Old Feb 10, 2006 | 03:16 PM
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
Do a nice long burnout. 1 tire mark= no lsd. 2 tire marks = lsd.
Old Feb 10, 2006 | 04:45 PM
ChiliCooperS's Avatar
ChiliCooperS
if smoke is not coming from one side of your car when turning aggresively. I wouldn't no anything about that though.
Old Feb 10, 2006 | 04:54 PM
OldRick's Avatar
OldRick
Check the original window-sticker invoice.
Old Feb 10, 2006 | 05:36 PM
petecrosby's Avatar
petecrosby
In general....
get the front wheels off the ground
take the transmission out of gear
spin one o fthe front wheels
If the car has LSD, then the other wheel will spin
in the same direction.
If the car does not have LSD then the other wheel
will spin in the opposite direction.
Old Feb 11, 2006 | 05:50 AM
davidlt4's Avatar
davidlt4
Other than something physical like these suggestions i was thinking more like option code sheet or list printed somewhere on the car.
Old Feb 11, 2006 | 06:23 AM
petecrosby's Avatar
petecrosby
I would imagine one of the characters in the VIN will tell you
but I don't have a decode for it. Ask the dealer.
Old Feb 11, 2006 | 06:35 AM
jlm's Avatar
jlm
I don't think the wheel spin method works with the quaife, which ceases it's limited slip action if one wheel is completely off the ground. anyone confirm?
Old Feb 11, 2006 | 08:48 AM
ingsoc's Avatar
ingsoc
You may be right on that one, jlm.... but, I'm not sure that the diff would interpret the presumably slow, small acceleration on the one wheel as slip... since it's mechanical, I'm pretty sure there's a threshold for intervening. Anyone?
Old Feb 11, 2006 | 08:55 AM
mbabischkin's Avatar
mbabischkin
How about starting with the easy one... When was your car built? Pre-Jan 05 build then you definately don't have the factory LSD. You can check the build date by looking on the plate mounted inside the drivers side door..
Old Feb 11, 2006 | 09:01 AM
ingsoc's Avatar
ingsoc
LOLOL @ ^^^^^. Hats off to ya, that's succinct and quite possibly more helpful than anything I had thought of. Much respect, d00d!
vulkandino
Oct 31, 2015 08:29 PM
Colt45Magnus
Oct 1, 2015 04:08 PM
MINI Stupor
Oct 1, 2015 11:36 AM
bahman
Sep 30, 2015 01:59 PM
Sep 28, 2015 09:13 AM
