Drivetrain Front Mount Intercooler
Old Jan 24, 2006 | 08:12 PM
Wake|MCS's Avatar
Wake|MCS
I was wondering if there was a different way to make a front mount than that which Randy Webb uses and which Fireball Tim Racing uses. Well, I mean I know there is, a local mini shop here, Precision Autowerks, developed a front mount that doesn't use the same route. Which would be better in terms of performance. Would it matter. Also, could you use FTR's without getting rid of the hoodscoop (they replace it with lexan)...
Old Jan 24, 2006 | 08:46 PM
danielg's Avatar
danielg
Here's how Nuzzo does it:
Old Jan 25, 2006 | 03:54 PM
Wake|MCS's Avatar
Wake|MCS
Yea i've seen that. I mean on the front bumper though...
Old Jan 25, 2006 | 04:15 PM
RED FURY's Avatar
RED FURY
the one that has carbon fiber that front mounts is not road worthy ... I've seen it come off the mounts, on track
Reason is, it is anchored still and the engine moves all around
Old Jan 25, 2006 | 04:23 PM
Wake|MCS's Avatar
Wake|MCS
That would be the Webb Motorsport front mount...
Old Jan 25, 2006 | 04:24 PM
RED FURY's Avatar
RED FURY
Um .. correct ... I have pics of that happening, before and after
Old Jan 25, 2006 | 04:42 PM
Wake|MCS's Avatar
Wake|MCS
Please share!
Old Jan 25, 2006 | 04:49 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Here is the Webbmotorsports one:
It looks very nice but if it moves out of its bracket, it might not be the best solution then...
Old Jan 25, 2006 | 05:39 PM
saifa's Avatar
saifa
Thats the Dastek intercooler (same guys as Unichip)...maybe Webb imports it. Anyways I heard that thing is pretty LOUD. Even worse if your going twin charge. Also the core, while surface area is bigger the thickness is not which can cost efficiency.
Old Jan 25, 2006 | 08:26 PM
ingsoc's Avatar
ingsoc
Luis, the guy who is developing the kit and who owns Precision Autowerks, is a friend of mine. He is a great and talented guy, and he has installed all of the mods on my car. Anyways, he called to tell me that he was releasing this piece a while ago, and I'm simply thrilled about that, because it will be SWEET.
He had a custom front mount on his last MINI [which his wife kinda killed...heh], and he is going to be selling something very close to his original design [which was uber trick] very soon. The design works quite well and is much less invasive [and more streetable] than what is currently around. That's all I can really say. I'm sure he'll be putting it up sometime soon. Anyways, he's a great guy, and I can guarantee that this piece will be IT.
Old Jan 26, 2006 | 04:47 AM
RED FURY's Avatar
RED FURY
Please share!
Pre-Track Above .... Post Track Below ... DNF the Race at Laguna Seca .
Old Jan 26, 2006 | 04:53 AM
DrkSilvrMini's Avatar
DrkSilvrMini
Red Fury..........are those pic's of the unit on your car?
Old Jan 26, 2006 | 04:59 AM
RED FURY's Avatar
RED FURY
NO .... They are of a silver JCW, another guy named Phil, a psychiatrist, a good guy that entered the Phil Wicks Race at Laguna Seca in Dec 2005
I borrowed a car(MSFIT's) for that event, my car is RED
Old Jan 26, 2006 | 01:26 PM
Wake|MCS's Avatar
Wake|MCS
Yeah Luis is a great guy, I just recently (last month) got my 19% pulley installed by him. Talked with another mechanic about his front mount, was told they needed to recreate basically the entire thing except for the mounts taht go into the stock intercooler snoots because the rest of it was totalled...
Old Jan 26, 2006 | 01:47 PM
CFMINI's Avatar
CFMINI
I know Phil (the psychiatrist) with this FMIC and he is working on getting boots that are more like bellows to allow more flex when the engine moves and he also just installed one of those Japanese engine dampers to limit engine movement.
That FMIC has a unique sound - like a screaming cat
Old Jan 26, 2006 | 03:10 PM
Wake|MCS's Avatar
Wake|MCS
Any pics of that car on the track? I'd like to see how the FMIC looks...
Old Jan 26, 2006 | 03:50 PM
chows4us's Avatar
chows4us
I was wondering if there was a different way to make a front mount than that which Randy Webb uses and which Fireball Tim Racing uses. .
check out what has been said at MINI2. Seems like it is prohibitively expensive (building a FMIC for the MINI) although I haven't got a clue why.
Old Jan 26, 2006 | 07:33 PM
Wake|MCS's Avatar
Wake|MCS
Because of the amount of custom fabrication that needs to be done. Completely custom charge pipes, custom mount for the intercooler, figure a way to turn the oval shape of the stock snoots into a circular tube, it all adds up... Then you have to test it to make sure it was all worth while, if it wasn't, go back to the drawing boards, etc... Despite all of this, I hope to fab up a one-off for my car in the near future...
Old Jan 27, 2006 | 07:55 AM
Bahamabart's Avatar
Bahamabart
I have the solution for your buddies slide problem - I had a similar problem and these little brackets cured it for they don't allow the bellow to compress.
these little brackets where compliments of stanely hardware - home depot
Old Jan 27, 2006 | 10:59 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
There were a couple of reasons for that issue at Laguna Seca - we have been running the unit our our car with quite a bit more time on the track with no problems. It is loud though! We have given Phil solutions to the problem he ran into in NorCal.
Hope that helps!
Randy
IQRaceworks
Jul 15, 2022 05:51 AM
AWOL
Mar 28, 2016 10:51 AM
silence2-38554
Nov 12, 2015 09:39 AM
FLYM1N1
Aug 15, 2015 11:20 AM
bleonard1401
Aug 4, 2015 09:39 PM
