Drivetrain Torque King?
Old Nov 30, 2005 | 04:14 AM
SpiderX's Avatar
SpiderX
Torque King?
Who has posted the most torque out of a "non twin charge" Mini S?
and more importantly what are you mods? and if you did any experiments with "taking this off and putting that on" etc. posting that would be great.
I have gone back to all my dyno sheets and the highest I can find uncorrected for DLL is 156.6. one says 160 but I threw it out because most are at 155ish
(what would a Mini be like if you could develop 200 whp and 200 ft lbs)
Old Nov 30, 2005 | 08:28 AM
spillman's Avatar
spillman
I pulled 185.
Old Nov 30, 2005 | 08:35 AM
MSFITOY's Avatar
MSFITOY
When I pulled 192whp last year, I think the torque was around 170-180 mark I'll have to check my records...
Larry Clemens's Avatar
Larry Clemens
176 ft-lbs at the wheels
2005 MCS w/ 15% Alta pulley, CAI, 62 mm TB, one-ball exhaust, MTH version5
Conditions: Ambient temp 93. Hood open. 2x 5,000 fans. 93 octane
Old Nov 30, 2005 | 08:45 AM
DrDiff's Avatar
DrDiff
Coordinator :: Northwest Indiana MINIacs
MINI One D
Too bad they don't bring the MINI One D here. I know a few Diesel tuners that could have that thing making more tork than a MSC JCW!
Old Nov 30, 2005 | 09:35 AM
snid's Avatar
snid
Why is a Cooper S thread in the Cooper (non S) area?
Old Nov 30, 2005 | 09:47 AM
dave's Avatar
dave
pug poo picker-upper
Thread moved.
Old Nov 30, 2005 | 09:58 AM
Tüls's Avatar
Tüls
Turbius Maximus
186 here...
Old Nov 30, 2005 | 11:09 AM
SpiderX's Avatar
SpiderX
I am amazed at those high numbers I wish I knew what and why my torque numbers are so low..........maybe I am too free flowing? My highest uncorrected WHP is just over 200....I'm stumped suggestions are welcomed
Old Nov 30, 2005 | 11:31 AM
MSFITOY's Avatar
MSFITOY
Refer to "Screw the Dyno" thread Bob Maybe it's just your dyno
Old Nov 30, 2005 | 11:42 AM
betet's Avatar
betet
What about the tuning? How does your A/F look like from the dyno?
///Gilbert
Old Nov 30, 2005 | 11:58 AM
SpiderX's Avatar
SpiderX
///Gilbert
High 11s
Old Nov 30, 2005 | 01:06 PM
hornguys's Avatar
hornguys
196 whp, 174 ft.lbs. torque, 9 months ago, before a few other mods, tested at Balanced Performance in Sugar Hill, GA.
Old Nov 30, 2005 | 01:30 PM
F15EWeapon's Avatar
F15EWeapon
November 23rd, 2005... Uncorrected I posted 194.3 hp/ 170.5 ft. lbs.
Hood open, 45 degree ambient.
SAE corrected... 185.2 hp / 162.5 ft. lbs.
Mod list in Signature... Dyno sheets in Gallery. Oh yes... with a Dynojet.
Old Nov 30, 2005 | 02:40 PM
betet's Avatar
betet
High 11s
Pretty safe and rich for optimal power, was the Unichip custom tuned?... If you can custom to tune it and try 12.8 - 13 , then you should see more power.. Not sure enough to see what others are seeing..., btw, is it a pretty flat 11s?
///Gilbert
Old Nov 30, 2005 | 03:08 PM
SpiderX's Avatar
SpiderX
My last Dynojet number with no fans running just getting in and getting out for a quick check was 188.7 with 155.7 at the wheels no dll correction.
like i said my best WHP was slightly over 200 but the toque number is still low.
I have one run from July where I did 197.7 with only 145.8 before a few mods like Alta IC, custom tune, crank pulley, intake manifold, alta cai and probably a few other things i can't think of. this is subtraction by addition more torque but less hp.
Old Dec 3, 2005 | 04:17 PM
gt5816v's Avatar
gt5816v
If you run it that lean you will vapooorize a piston....
///Gilbert
Old Dec 5, 2005 | 08:12 PM
betet's Avatar
betet
Actually 12.8 - 13 is still pretty safe as long as the EGTs show otherwise. With my 1.8 Miata, I ran this A/F ratio , w/ "not too hot" EGTs on a stock block boosting 9lbs of boost. Only reason I stopped at 9lbs, because Mazda decided to use "weak rods" on their blocks post 1997 MX5s... . I think my MCS should be able to handle this with no problem.
I'm sure our DMEs try to keep it near high 13s low 14s when cruising/idle to keep the CAT happy....
///Gilbert
Old Dec 5, 2005 | 08:26 PM
Skiploder's Avatar
Skiploder
Three runs on the dyno, we'll go by the honor system since I do not have a scanner:
1. 181.4
2. 179.3
3. 185.5
Old Dec 5, 2005 | 08:29 PM
ingsoc's Avatar
ingsoc
///Gilbert
Seriously d00d, I highly recommend against this. It's your car, but it's not worth what I believe is certain catastrophic failure to suck out that last 10 hp. REMEMBER, this is a SCed car and the intake temps are pretty high [prolly higher than you were running]. Think about it.
Old Dec 5, 2005 | 08:33 PM
betet's Avatar
betet
That's why I said "unless the EGTs says otherwise"....
///Gilbert
Old Dec 5, 2005 | 10:17 PM
ingsoc's Avatar
ingsoc
///Gilbert
Fair bit, just expressing my honest reservations.
Old Dec 6, 2005 | 04:51 AM
SpiderX's Avatar
SpiderX
1. 181.4
2. 179.3
3. 185.5
I can't get over these numbers....... are these corrected for Drive line loss?
I run my A/F real close to 12 ....even if I was to lean out for more ft. lb. that would not get me near your numbers......what are your mods?
MGBill1186
Oct 2, 2015 06:54 AM
pkillur
Sep 30, 2015 10:51 AM
EVMini
Sep 28, 2015 10:20 AM
Nicefeet
Sep 27, 2015 11:14 AM
Sep 25, 2015 12:32 PM
