Drivetrain Crankshaft Pulley = really Bad idea...
Old Jun 10, 2009 | 09:03 AM
  #251
mdbsat's Avatar
mdbsat
How many people have had a lightened crank shaft pulley cause catastrophic damage or failure to their cars?
Old Jun 10, 2009 | 10:24 AM
  #252
MSFITOY's Avatar
MSFITOY
None here, 85k...why are people still debating this?
Old Jun 10, 2009 | 10:29 AM
  #253
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
100% agreed! This is a DEAD issue!
Old Jun 10, 2009 | 10:34 AM
  #254
mdbsat's Avatar
mdbsat
I do not have an answer for that. I used to have a lightened CS pulley. A friend needed in an emergency situation so I then went back to the OEM CS pulley. I did not have any problems with the lightned CS pulley though it was not on for too long. I did have a problem with the OEM one as it failed leading me to purchase the MUCH cheaper lightned CS pulley.
I was just wondering if anyone has had this major lightned CS pulley failure so many fear. I guess I would rather be safe than sorry.
Old Jun 12, 2009 | 09:22 AM
  #255
Hippie's Avatar
Hippie
I'm pretty sure that if peeps running these have blown the engines we would know by now
Me - I intend to put one on
Old Jun 12, 2009 | 07:58 PM
  #256
sonichris's Avatar
sonichris
just to add i've had one for at least 70k miles, no problems. the ones that did have probs had very high redlines (8k or so) and it was the oil pumps that blew up. like what has been said, this is a dead issue on minis. the first post that started this was on an inline-6 bmw. the mini does not need a dampened/weighted pulley.
Old Jun 14, 2010 | 10:08 AM
  #257
DSCS's Avatar
DSCS
bump....
Old Jun 14, 2010 | 10:12 AM
  #258
ADAMSALTAMINI
Originally Posted by DSCS
bump....
why?
Old Jun 14, 2010 | 10:20 AM
  #259
sonichris's Avatar
sonichris
105k miles, over 80k with the pulley, still no problems...
Old Jun 14, 2010 | 10:44 AM
  #260
Crashton's Avatar
Crashton
I don't think our cars could run without a crank pulley. I have one & I feel it keeps the belt from falling off. My MINI came equipped with it.
Sorry forgot my meds this morning...
Old Jun 15, 2010 | 04:21 PM
  #261
Raymazing's Avatar
Raymazing
The issue that should be in question is whether or not your factory dampened pulley is going to fail. Ive read more about stock pulley failure (splitting and fragmenting) than catastrophic engine failure due to an aftermarket pulley
Old Jun 15, 2010 | 04:53 PM
  #262
Fatherdeth's Avatar
Fatherdeth
True!!! Knock on wood, but I've got 60k+ on mine and no problems. I have heard more about the OEM pulley failing than an aftermarket one.
Old Jun 15, 2010 | 05:33 PM
  #263
maxmini's Avatar
maxmini
Now you are on to something .
Randy
M7 Tuning
Old Jun 15, 2010 | 06:15 PM
  #264
Raymazing's Avatar
Raymazing
The unfortunate thing about the aforementioned issue is there is really no way to test for it... I have removed my Alta 2% due to rattling from belt/tensioner. I plan on ordering the fluidamper that has just been released to solve both problems :D
Old Jun 15, 2010 | 07:39 PM
  #265
CrazyIvan's Avatar
CrazyIvan
Are you sure your tensioner just doesn't need to be changed? Mine was making noises before I even put the light weight pulley on.Engine is out of the car right now so I finally going to change the tensioner.
Old Jun 15, 2010 | 08:10 PM
  #266
ADAMSALTAMINI
+1000
Ray: There is no rattle from the pulley for SURE!. The tensioner may make a bit of noise on the earliest shipments. If you have a rattle shoot me a PM and I'll get you the isolator. Also be SURE it is installed properly. If you have any questions, our tech staff is always here to help. We want you 100% happy with your ALTA parts!
BUT....
Ivan may be right. The likelihood that the tensioner has taken or will take a big crap is the more likely culprit for the noise. Again hit up our tech dept. tech@ALTAPerformance.com or call 503-693-1702 so we can help further!
Old Jan 24, 2011 | 01:46 PM
  #267
///ACS330Ci's Avatar
///ACS330Ci
Add another OEM crankshaft pulley failure to the list. What a POS!
Old Jan 24, 2011 | 02:32 PM
  #268
ih8cornnuts's Avatar
ih8cornnuts
my oem crapped out at the end of october right around 166k
replaced with a stock 05/06 one
Old Jul 28, 2011 | 12:21 PM
  #269
dkellerd's Avatar
dkellerd
Well, I've made my decision after reading thru this whole thread! My stock crank pulley blew up last weekend leaving us stranded out of town. I will be replacing it with a cheaper non-dampened pulley which will save me around $300.
Thanks to everyone for input on this thread! I'd rather have a solid pulley than have this rubber damper, over-priced garbage leave me stranded again.
Old Jul 31, 2011 | 03:32 PM
  #270
ggcadc's Avatar
ggcadc
Yeah, serious garbage engineering that it didn't last 350,000mi... Cause you know an aftermarket piece is good for 500kmi... glad you stayed stock and weren't swayed by the hype.
Stock is fine, trying to say an aftermarket pulleys are somehow better is like saying an aftermarket door is better, they're mostly identical and arguably no one would be able to tell the difference in daily use.
Old Aug 1, 2011 | 11:39 AM
  #271
Da_Ghost's Avatar
Da_Ghost
Aftermarket pulleys aren't known for having an auto-destroying feature! So by default, they are better
Old Aug 1, 2011 | 06:09 PM
  #272
HeavyMetal's Avatar
HeavyMetal
Invalid argument.
Old Aug 3, 2011 | 08:27 AM
  #273
Eggburp's Avatar
Eggburp
Can't believe I wasted time reading this whole friggen thread!!!
But it raining and can't harvest the potatoes!
Just to cause problems....think I might go for a 2%
Old Aug 3, 2011 | 04:24 PM
  #274
Da_Ghost's Avatar
Da_Ghost
I had a lighweight crank pulley on my '05 Sunfire (2.2 Ecotec) for 96000km (4 years) of hard beating (over 200 runs on 1/4 mile track) and never had a single issue! I'm not even worried about putting one on my Mini!
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
The_Kid
Nov 3, 2016 06:30 PM
Sep 3, 2015 02:06 PM
M7Speed
Sep 3, 2015 07:48 AM
