Drivetrain Vacuum port location on MINI Cooper S intercooler
Old Feb 5, 2003 | 12:58 PM
Arly's Avatar
Arly
I am thinking about adding a mechanical Boost gauge, but I am unsure where the vacuum line is located for me to "tee" off from. Does anybody have any pictures for where the vacuum line is that is easy to get to? I have seen some pictures that has it underneathe the intercooler on the left side as you face the engine compartment. Has anyone done this to their MCS?
Old Feb 5, 2003 | 01:33 PM
Davbret's Avatar
Davbret
We hooked up a boost guage when doing dyno runs. It's just a T section you tap right where you said: left side of intercooler, under the duct from supercharger to intercooler. It makes sense if you have the boost guage in front of you so you can see what needs to go where.
R
Old Feb 5, 2003 | 01:47 PM
Arly's Avatar
Arly
Thanks!
How easy is it to get to? And where is the best place to route the tube to the dash area? Also, what is the best way to wire the lights to the boost gauge?
Old Feb 5, 2003 | 04:49 PM
jlm's Avatar
jlm
when I plumbed my boost gauge, i removed the intercooler and the rubber boots to access the manifold- to-fuel regulator hose; you cut the hose near the manifold, insert a tee, and attach your vac line. a very hard place to get to, but a needle nose plier and a beer were useful. this was covered on mini2 racing forum (got boost?) last fall; i think the panel light wire is yellow with white, but you should look for the other post to be sure.
zdw2082
Oct 5, 2015 09:59 AM
nomar116
Aug 12, 2015 05:24 PM
Minii cooper bean
Aug 11, 2015 02:10 PM
nomar116
Aug 9, 2015 09:42 AM
joelcseymour
Aug 7, 2015 12:43 PM
