Drivetrain Cam Shaft upgrade considerations...
Old Oct 18, 2005 | 06:55 PM
dominicminicoopers's Avatar
dominicminicoopers
I was thinking about getting the Schrick cam shaft for my MCS. What are some of the consideration I should take into account when adding this to my MINI? Better or worse MPGs? Better or worse throttle response? Better or worse idle? Do I need to have software changes to keep from going lean/rich? Etc.?
Last edited by dominicminicoopers; Oct 19, 2005 at 09:50 AM. Reason: spelling error
Old Oct 18, 2005 | 07:40 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
what else have you done to your car?
Old Oct 19, 2005 | 06:27 AM
dominicminicoopers
List of engine mods
* Twin-charged (SPI/MegaMini)
* Custom 3" Magnaflow exhaust
* Kingsbourne Wires
* Screamin' Demon Coil Pack (Pilo)
List of engine mods that will be going on car when potentially adding the CAM
* stronger pistons
* powerflex bushings on upper engine, lower engine, and gearbox mounts.
p.s. deltman, I got your PM...
Old Oct 19, 2005 | 06:44 AM
Brain1.0's Avatar
Brain1.0
Manufacturer
Ok, cool. I didnt realize I knew you when I posted.
Originally Posted by dominicminicoopers
List of engine mods
* Kingsbourne Wires
* stronger pistons
Old Oct 19, 2005 | 06:54 AM
SpiderX's Avatar
SpiderX
I was thinking about getting the Schrick CAM for my MCS. What are some of the consideration I should take into account when adding this to my MINI? Better or worse MPGs? Better or worse throttle response? Better or worse idle? Do I need to have software changes to keep from going lean/rich? Etc.?
I have a "street cam" and I wonder about the advantages and disadvantages of the "race" cam
Old Oct 19, 2005 | 07:01 AM
JeffS's Avatar
JeffS
Slightly OT, but does anyone have the specs of the stock camshaft? Just wondering what the Schrick is modifying.
shrick
Intake: Duration 264º, Lift 9.5mm, overlap 0.5, peak timing 114º, open at 18º, close at 66.
Exhaust: Duration 272º, Lift 9.0mm, overlap 0.65, peak timing 114º, open at 70º, close at 22º.
[edit] looks like stock is 236 intake 243 exhaust with lift around 8.5mm
Old Oct 19, 2005 | 07:46 AM
dominicminicoopers
Huh? I was unaware of two types. Do you have a URL for the two types?
Old Oct 19, 2005 | 08:42 AM
Brain1.0's Avatar
Brain1.0
Manufacturer
I dont think there are 2 anymore, one was more mid range. They pretty much only market one cam for the S now. That is the one most people have, me included. There are no idle problems and it pulls pretty good. Its better than stock but it could be better.
Old Oct 19, 2005 | 10:14 AM
SpiderX's Avatar
SpiderX
There absolutely was two types. one race one street. My street works great
Old Oct 19, 2005 | 11:33 AM
dominicminicoopers
Curiosity is killing me. Which type did they get rid of? Or did they make a new one and get rid of the original two?
Old Oct 19, 2005 | 01:40 PM
SpiderX's Avatar
SpiderX
I have no idea....today was the first i learned that one was discontinued.....I'm sure Randy Webb knows as he is a dealer
Old Dec 17, 2005 | 03:34 PM
dominicminicoopers
bump
What are some of the consideration I should take into account when adding a CAM to my MINI? Better or worse MPGs? Better or worse throttle response? Better or worse idle? Do I need to have software changes to keep from going lean/rich? Etc.?
bump
Old Dec 17, 2005 | 10:19 PM
SpiderX's Avatar
SpiderX
For what it is worth...they got rid of the "street" cam and only have the race. RW says that it only makes a dif in the last few hundred rpm and just a few hp.........I wish some one from Schrick would comment.
Supertractor3
Apr 7, 2017 11:16 AM
molala
Oct 2, 2015 01:53 PM
Sep 3, 2015 02:06 PM
Sep 3, 2015 10:29 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
