Drivetrain Will the Pilo Racing header throw any codes?
Old Oct 10, 2005 | 05:16 PM
markbradford's Avatar
markbradford
Just wondering if deleting the cat will
1. Throw a code? (assume it will)
2. Send the car into any sort of "limp mode" or anything?
Old Oct 10, 2005 | 05:29 PM
red rage's Avatar
red rage
Is the header coupled to a CAT ? I hope it is
I washed my car today, popped the hood to "spray it off" and got water on the engine, Threw a code and went into limp mode !!!
I hope it goes away !!!
Old Oct 10, 2005 | 05:34 PM
Dr Obnxs's Avatar
Dr Obnxs
No codes from headers per se....
but if you drop the cat, you will get a code due to cat failure. That's what the second 02 sensor is there to detect. There are little modules that you can plug in to make the system "think" it's working. It fakes the heater load, and the output of the sensor that indicates clean air. This isn't allowable for street driving, and is actually a violation of federal smog equipment laws, but then so is adding a header.
I don't think the car goes to limp mode with a cat failure code.
Hope this helps...
Matt
Old Oct 10, 2005 | 05:41 PM
markbradford
I have seen the cat-delete interfaces on other cars, but do you know if anyone makes one for the Mini?
Old Oct 10, 2005 | 05:42 PM
markbradford
Swappable test pipe and/or cat with flanges would be optimal.
Old Oct 10, 2005 | 05:49 PM
Dr Obnxs's Avatar
Dr Obnxs
I have seen them from Mini vendors....
But I don't remember which one! Helix comes to mind.. But a few phone calls should get you an answer... Sorry I couldn't be of more help...
Matt
Old Oct 10, 2005 | 05:51 PM
onasled's Avatar
onasled
Yea, if you remove the cat you will get a code and the "Check engine" light will come on within 10 miles of driving it. It will not make the car run any different as the computer takes it's info from that first censer before the cat.
You will notice a difference though in performance without the cat.
Old Oct 11, 2005 | 10:30 AM
red rage's Avatar
red rage
WHAT? I CAN"T HEAR ANYMORE, I HAVE NO CAT !!!
Old Oct 11, 2005 | 11:33 AM
onasled's Avatar
onasled
:impatient :impatient
Tell me about it. My other car is basically dead and while I'm looking for another, I'm driving the Mini on the road. Minimanis header, no cat, Miltek resonator into a 3" Flowmaster 40 series.
I'm sorry, did you say something?
I should take a photo of this actually as I come straight through and exit with a single 4" resonated tip through where the backup light was. Will be building a rear defuser this winter if I continue with this car.
Old Oct 11, 2005 | 11:54 AM
markbradford
Would a regular Milltek exhaust with OBX header and test pipe be that loud?
Old Oct 11, 2005 | 12:07 PM
onasled's Avatar
onasled
No, not that loud, but louder then with a cat. More raspy at higher revs.
Old Oct 11, 2005 | 12:19 PM
markbradford
OPtimally I''d like to be able to swap the cat or test pipe in and out at will. Is this a feasible solution if I got an OBX header? How accessible is the cat on this car? I installed my Milltek exhaust but I can't remember how accessible the leading edge of the cat is.
Old Oct 11, 2005 | 12:59 PM
red rage's Avatar
red rage
The Madness 2 Header can be had with both pipes ....
But it does fetch a high price, it might be THE ticket
BUT the optimal setup, according to George at Madness is the Borla street exhaust with the madness header, which would mean even more $$$$$
Old Oct 11, 2005 | 01:02 PM
red rage's Avatar
red rage
Build me one too please
Old Oct 11, 2005 | 01:22 PM
markbradford
The attraction of the OBX one is hte possible $/hp ratio. $175 plus a straight pipe to swap in = $300 max.
Old Oct 11, 2005 | 01:31 PM
red rage's Avatar
red rage
Agreed,
BUT I haven't seen the answer to a pipe or CAT that is the one to add to the OBX to keep it quiet, for a daily driver
Phil
Old Oct 11, 2005 | 08:19 PM
discodan's Avatar
discodan
Pilo is about to release a V2 header with removable CAT and test pipe that will start around $250 with test pipe and obviously more once CAT is available. expect this to be THE price leader once it hits market.
Old Oct 11, 2005 | 08:28 PM
markbradford
If it allows the stock cat to be bolted in the consider one sold.
I assume that bolting the stock cat in is also an option?
Old Oct 11, 2005 | 09:20 PM
discodan's Avatar
discodan
no, hi-flow CAT replacement will be available though. stock CAT(s) are welded onto the stock header.
Old Oct 11, 2005 | 10:22 PM
markbradford
OK.
What is the ID of the stock cat inlet and outlet please?
Thanks!
Old Oct 18, 2005 | 07:53 PM
skuzy's Avatar
skuzy
can one of u knowledgeable peeps help me with this problem?
ive got the miltek cat back.. love the exhaust.. but frankly its not loud enough.. what can i do to make it louder ? (excluding the option of getting a miltek header which is waaaaay out of my budget )
thanks.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Colt45Magnus
Aug 13, 2015 11:18 AM
Aug 12, 2015 01:24 PM
Aug 7, 2015 09:51 AM
