Drivetrain ITG filters
Old Oct 9, 2005 | 08:21 AM
Awheeler3296's Avatar
Awheeler3296
ITG filters
Has anyone tried the new ITG filter in there JCW CAI? I am looking for a better replacement filter.
Old Oct 9, 2005 | 09:58 AM
///ACS330Ci's Avatar
///ACS330Ci
I didn't know they had one I have an ITG filter on my BMW and have been really happy with it. Can you post a link to the filter you're asking about?
TIA
Old Oct 9, 2005 | 10:32 AM
Awheeler3296
http://www.myminiparts.com/proddetai...od=ITGJC&cat=7
Old Oct 9, 2005 | 10:42 AM
///ACS330Ci
Old Jan 28, 2006 | 09:01 PM
cooldaddy's Avatar
cooldaddy
I installed the ITG foam filter in my JCW intake this afternoon. No problems with fit or installation. There might be some increase in supercharger noise Can't comment on any additional performance from just the filter as I also installed the Detroit Tuned bypass valve (and removed the VGS mod as it never made any difference on my car - it was installed properly as all connections were intact before I removed them). Throttle response has improved and so far I can no longer detect the horrible yo-yo I had in my car...
Old Jan 30, 2006 | 09:18 AM
Bahamabart's Avatar
Bahamabart
I'm running a CAI w/ ITG filter (from MYMINI) and can only give it a .
Old Feb 15, 2006 | 06:34 AM
mbcoops's Avatar
mbcoops
How does one clean/maintain the ITG filter. I'm going to get one because it has to be a better option for the JCW intake over buying a 99$ paper filter everytime one gets dirty.
Also, any tips on installation? Or is it as straightforward as it would seem?
mb
Old Feb 15, 2006 | 06:49 AM
Bahamabart's Avatar
Bahamabart
mb
There are cleaning solutions available. I run RC cars and they have foam filters and one uses rc fuel to clean them so when it comes time I will most do the same.
Old Feb 15, 2006 | 04:27 PM
///ACS330Ci
mb
I have one on my BMW and it came with cleaning and re-oiling stuff. Pretty easy to do and arguably one of the best filters on the market. I'll eventually get one for my JCW airbox
Checkout - http://www.itgairfilters.com/content2.asp?section=trifoam
Old Feb 16, 2006 | 06:30 AM
NeilM's Avatar
NeilM
The easiest way is in a bucket of warm soapy water. If you're not married I guess a sink would work...
Neil
05 MCS
96 M3 - ITG filter and a few other things
Old Feb 16, 2006 | 11:00 AM
rick714's Avatar
rick714
What's the life of JCW paper filter?
Old Feb 16, 2006 | 07:15 PM
minibrute's Avatar
minibrute
paper filter life
I'm about to find out, my jcw paper filter has been performing duty for one year. I just got an ITG filter in the mail as recomended by some of you here, will install tomorrow if its not too cold.
Old Feb 17, 2006 | 04:55 AM
mbcoops's Avatar
mbcoops
I'll report about the JCW life as well. I've had it on since august for about 10,000 miles.
NeilM - If you clean the ITG with soap and water, do you oil it with something? And yes, I think I'll use the sink!
mb
Old Feb 17, 2006 | 05:33 AM
cooldaddy's Avatar
cooldaddy
I was told "Silkolene, which is generally avaiable at most motorcycle shops. ITG also recommends this product"
Old Feb 17, 2006 | 12:16 PM
minibrute's Avatar
minibrute
jcw airbox top removal
I'm trying to remove the top off my jcw airbox to replace the filter. I see the two t25 screws in the front of the airbox but something in the back, towards the firewall keeps the top from coming off. What am I missing ? I did use the search looking for a how to or a diy thread but could not find anything. Help me remove my air filter, thanx.
Old Feb 18, 2006 | 04:49 AM
BFG9000's Avatar
BFG9000
The hooks at the back of the box require you to slide the whole box top toward the back of the car to unhook, then the top can be lifted out.
Old Feb 18, 2006 | 06:29 AM
NeilM's Avatar
NeilM
NeilM - If you clean the ITG with soap and water, do you oil it with something?mb
The washing is to remove soiled oil. I use Palmolive dish soap, which also leaves my hands silky soft and smooth <g>
According to ITG one should not leave the filter to soak in water. Get it in, wash it, rinse, and allow to dry. BTW, my ITG cone filter takes about a day to dry fully. I imagine a panel filter dries more quickly.
You can also wash it in kerosene, but jeez, who wants to have a bucket of kerosene standing around?
The ITG filter should come with a spray can of their oil. I'm still using the original can, so haven't had to try any alternates. The ITG oil is more sticky than oily, which is of course how it should be. It's fairly important with all these 'oiled' foam filters not to over-oil them, since you don't want excess oil to fly off and contaminate stuff downstream. That's why the original ITG oil strikes me as the stuff to use. I assume that one can buy more from the original filter vendor?
And yes, I think I'll use the sink! mb
It's the manly thing to do!
Neil
05 MCS - Stock filter
96 M3 - ITG filter
Old Feb 18, 2006 | 08:52 AM
marksmith's Avatar
marksmith
Itg....
I used them for years (BMW's cars) and loved them. Glad I can get an ITG for my Works air box. Clean w/ dishwashing soap, warm h2o, quick wash, rinse, no SOAKING & don't squeeze (ring-dry) the filter too hard or you can de-laminate the foam layers. SLOW drying & be careful not to over-oil or it will clog the pours.
FYI: I always had 2 on hand, one dry/clean unit for quick changes while the drity one gets washed & dried for the next rotation cycle.
Old Feb 18, 2006 | 12:11 PM
cooldaddy's Avatar
cooldaddy
as far as I know myminiparts.com, where I got my ITG filter, doesn't sell the ITG Dust Retention Coating "oil", you'll have to find it, or something similar, at a local store or order it via the internet at e.g. BimmerSpecialist.com
Old Feb 18, 2006 | 02:51 PM
minibrute's Avatar
minibrute
airbox top removal
Thanks for the reply, I'll try again.
Old Feb 25, 2006 | 02:35 PM
mbcoops's Avatar
mbcoops
I installed the ITG filter today and removed the stock paper element. The paper filter didn't look TOO dirty after 13,000 miles, but when I tapped it on the ground, lots of stuff came out.
This detailed summary helped out A LOT, even for me, a mental and mechanical midget:
http://www.jwardell.com/mini/jcwintake.html
It took me longer than the 10 minutes described here because it took a while to get the thing off. Now that I know it gets caught on two flaps, it might be easier next time. I hope I reconnected everything correctly.
I feel absolutely zero difference between this filter and the stock.
mb
Old Feb 25, 2006 | 05:29 PM
cooldaddy's Avatar
cooldaddy
I felt the same thing - but the car sounds louder, not sure if that's because the paper filter needed changing (I was at 14K) or the change to foam. Anyway, the main reason I changed to the ITG is not needing the replace the over-expensive paper filter with a another over-expensive paper one...
mb
Old Feb 26, 2006 | 06:25 PM
marksmith's Avatar
marksmith
Kudos fro ITG
myminiparts.com got my ITG filter to my home in 48 hours! Very nice dealer! Install is a bit more complex than I expected but the next time will be faster.
-ITG fits perfectly. Seems to be a bit more intake noise (more air one would assume) and some subtle aural changes (SC whine more pronounced) and the throttle response is a tiny, tiny bit faster & smoother.
The real surprise is during "sporting" driving moments, at WOT, near the ideal up-shift points when there is NO MORE micro- throttle stall/choke off. This has been an small but ongoing JCW uissue w. my car and the ITG has magically solved the problem. KUDOS to ITG!!
-PS. ITG (induction technology group ltd) sells it's "dust retention coating" in a 200ml spray can. After cleaning & drying the filter, just spray a LIGHT coating on the foam filter & massage it a bit by hand into the filter matrix (yes, give a it a nice gentle message!) I will find the invoice where I purchased my ITG filter oil & post the vendors ID asap.
Old Feb 26, 2006 | 06:28 PM
marksmith's Avatar
marksmith
Kudos to ITG
The real surprise is during "sporting" driving moments, at WOT, near the ideal up-shift points when there is NO MORE micro- throttle stall/choke off. This has been an small but ongoing JCW issue w/ my car. The ITG has magically solved the problem. KUDOS to ITG!!
-PS. ITG (Induction Technology Group ltd) sells it's "dust retention coating" in a 200ml spray can. After cleaning & drying the filter, spray a LIGHT!! coating on the foam filter & massage it a bit by hand to work the oil into the foam matrix (yes, give a it a nice gentle message!) I have cleaned & re-used an ITG filter's up to 3 times in the past (I don't actually know what ITG says is the typical life span of a filter?) I will find the invoice where I purchased my ITG filter oil & post the vendors ID asap.
Old Feb 26, 2006 | 07:33 PM
mbcoops's Avatar
mbcoops
Thanks for the impressions - let us know where we should get the oil.
mb
