Drivetrain Andy, what mods do you have on your car?
Old Sep 23, 2005 | 06:40 AM
SpiderX's Avatar
SpiderX
By Andy's request I am asking him what his mods are and what he has found to be most effective on his car. This is not a trap as I PMd him to keep this private. he requested a new thread or an email and I did not readily see his email address
Old Sep 23, 2005 | 07:26 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
This will probably help out a bit (andy can let us know how up to date it is)
http://www.ross-tech.net/andy/mini/mymini.html
Seems like a few engine mods, and only one suspension mod. :smile:
Andy....just curious, but why a 19mm sway instead of the usual 22(for an MCS that is....19 is typical on MC's)?
Old Sep 23, 2005 | 09:12 AM
cooldaddy's Avatar
cooldaddy
are there any Dyno numbers on the cocomats?
Old Sep 23, 2005 | 12:38 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
I currently have:
19% pulley
380 cc injectors
GIAC software
One-ball exhaust
HAI
16x7.5" Kosei K1
205/40-16 Falken Azenis RT-615
I went with the RDR 19mm mostly since I wanted a fairly mild reduction in understeer. The 19 mm on its middle setting seems to work great for that.
I should update my web page.
Old Sep 23, 2005 | 12:39 PM
andy@ross-tech.com
They pull 2 coconuts hot, but only 1 coconut when they get heat-soaked.
andy@ross-tech.com
How is that possible? Look hard, you'll see it.
Old Sep 23, 2005 | 12:55 PM
SpiderX's Avatar
SpiderX
I was just in a hurry and had too much going on.......thanks for your reply
Old Sep 23, 2005 | 12:56 PM
sfjames2's Avatar
sfjames2
Andy, did you EVER put the Alta CAI back on or has it been HAI ever since the find?
Curious because I thought I saw the Alta CAI on in a recent pic. and remembered wondering why you might have reverted.
Old Sep 23, 2005 | 01:05 PM
andy@ross-tech.com
Nope, I sold the Alta.
Old Sep 23, 2005 | 01:09 PM
sfjames2's Avatar
sfjames2
thanks man.
Old Sep 23, 2005 | 01:25 PM
andy@ross-tech.com
NP. The page should be updated now.
Old Sep 23, 2005 | 01:30 PM
Paul Webster's Avatar
Paul Webster
Have you not been on the dyno or down the 1/4 mile lately Andy???
Old Sep 23, 2005 | 01:34 PM
Skiploder's Avatar
Skiploder
16x7.5" Kosei K1
Creeping up on the 05' gearing!
Old Sep 23, 2005 | 01:39 PM
andy@ross-tech.com
I haven't hit the dragstrip since I put the smaller diameter tires on. I'm hoping for good things.
Old Sep 23, 2005 | 01:54 PM
Paul Webster
I've got the 205-15 G force Drag Radials on and with the ecu in limp home mode it wouldn't go over the line in third without hitting the rpm limiter
Now its in normal mode I'll be hitting 4th a lot earlier but I think I might have traction issues because of the extra hp, it had 128hp (86.2 @2447lb) the other weekend in limp home mode
Of course its all bs until that green light drops on Sunday
Old Sep 23, 2005 | 02:04 PM
kapps's Avatar
kapps
Hey Andy, how are the Kosei K1's holding up? I prefer their look to the K1-TS but heard about some problems with the K1's.
Old Sep 23, 2005 | 02:14 PM
andy@ross-tech.com
The K1's are good. I actually don't mind looks of the K1-TS and would rather have them due to the lighter weight. When I first installed the K1's, I neglected to use anti-sieze on the hub surfaces and threads and, as a result, one of the front wheels had its bolts loosen up (I wasn't able to get them tight enough, apparently). After that scary incident, I put a small amount of anti-sieze on each bolt and torqued them to spec - no problems since. I have read other reports of people having loose K1's as well and I have no explanation why these particular wheels would be succeptible to that condition, while other wheels would not.
Old Sep 23, 2005 | 04:25 PM
SteveS's Avatar
SteveS
What do you think of the Azenis? I want 215-45-16 for cornering and a little closer (but less than) stock gearing, but they are not due out till next quarter. Are they about 8% smaller than stock?
Could you post your picture/dimenstions of the pulley belt loosener again so I can try to make one? Did you make your own or just reinforce the factory one?
Thanks a lot.
Old Sep 24, 2005 | 06:52 AM
MyPocketRocket's Avatar
MyPocketRocket
Andy, Do you still use the VGS on yours?
Old Sep 24, 2005 | 07:10 AM
mightydread's Avatar
mightydread
hi andy, was wondering what did you do as heat sheild box cover after you installed the helix short shifter ,i know some people had to remove it . did you make one or you just didnt reinstall it.
thanx
mikie
Old Sep 24, 2005 | 08:13 AM
andy@ross-tech.com
Thanks a lot.
I had the 215/45-16 RT-215 Azenis tires prior to these and the new ones feel as sticky if not more, and are definitely better in rain, as well as being quieter. The gearing change of course does not show up on the speedo, but it's very noticeable in daily driving, especially compared to other pre-'04 MCS.
I got the factory belt tensioner tool and it broke on the second use, so I had a local shop weld it back together and make it purdy.
I sure do, it makes driving 78.3% more enjoyable.
thanx
mikie
I threw it away. There was more dirt inside the plastic cover than there was outside. So, my shifter dirt is now free to exit the car and run free!
Old Sep 28, 2005 | 09:09 PM
SteveS's Avatar
SteveS
I'm confused by what you said. Do you mean it does not create a speedo error? Are you really going slower than the speedo? How much slower in reality are you going, compared to stock gearing, or 215-45-16?
Old Sep 29, 2005 | 06:14 AM
andy@ross-tech.com
There is speedometer errror now, an indicated 77.7 mph is equivalent to a real 70 mph (GPS-verified). Stock it was only about 2 mph error. What I meant is that the speedo and tach still have the same relationship. Only one of them is lying a little bit now. :smile:
Old Sep 29, 2005 | 10:33 AM
The Italian Job's Avatar
The Italian Job
Andy-
Maybe I am showing my ignorance but, what is a magnesium interior door casing? Sounds very cool, but I just can't picture what it is.
Old Sep 29, 2005 | 10:46 AM
andy@ross-tech.com
It was a goofy option that my car had. It looks like this:
Instead of the door panel being a textured black surface to match the rest of the plastic in the car, it is a smooth pale gray surface. Not the best shot, but I swapped it out for black panels from a Cooper:
steelz21
Sep 12, 2015 10:06 PM
Etrain
11
Aug 20, 2015 10:22 AM
massmini03
Aug 12, 2015 11:19 AM
ludedude
Aug 10, 2015 07:16 PM
