Drivetrain Mini pulling to the right
Old Sep 16, 2005 | 12:17 PM
Battle Cattle's Avatar
Battle Cattle
Not sure if this is the right spot but... here goes
I have recently noticed my car pulling to the right at slow speeds under mph in about 10 feet I would be in a ditch and if at 40MPH I would pull in about 100-150 ft. Now I only have 2900mi on my car, so is this something I should have the dealer look at to see if there is a bigger problem or what? I drove these same roads in the same manner in my ford taurus before I got my mini and never had a problem... so it isn't like its pothole country. Also next weekend the 24th I am going on a 2700mi round trip for 1 week so I kinda want to get it fixed before then..
-Josh
Old Sep 16, 2005 | 12:54 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
My 1st thought would be low tire pressure in one of your right side tires.
The tire warning light only comes on if there is a pressure drop while the car is on.
Old Sep 16, 2005 | 12:57 PM
Donna/Mike's Avatar
Donna/Mike
Sand Dollar Collector
I experienced the same issue and thought - geez do I need a front end alignment already??? Nope - it was low tire pressure...
Donna
Old Sep 16, 2005 | 12:59 PM
chows4us's Avatar
chows4us
-Josh
Josh, thats a classic sign that it needs alignment. I think there is another thread here the other day about MINIs following the crown of the road. Mine does it all the time but your sounds like an alignment issue. Take it to MINI (for free service). Drive it on a completely flat surface (hard to find) and see if it still does it.
If your SURE its not following the crown of the road, get it looked at IMHO.
Old Sep 16, 2005 | 01:24 PM
The Short Bus's Avatar
The Short Bus
-Josh
Don't be coming around here with a poor limping mini Get that beauty fixed!
Old Sep 16, 2005 | 01:28 PM
Guest's Avatar
Guest
Probably Tramlining. My car is on stock runflats and completely even on level ground, but if one of my wheels gets into a dip I have to fight the steering wheel to keep it going straight. You'd be surprised how strong the car can track if one of the wheels is on a part of the road with differing levels of traction.
Old Sep 16, 2005 | 02:05 PM
k-huevo's Avatar
k-huevo
The issue I had was not quite the same but here it is for entertainment value. I noticed the car was pulling to the side under hard braking and taking a direction of its own on extremely crowned roads. The dealer suggested I upgrade the brakes. While changing the springs it was a surprise to find all of the shipping strut shims still on the driver’s side front strut.
Old Sep 16, 2005 | 03:15 PM
betet's Avatar
betet
I'm going to chime in some "worst" case scenario.. Your car is pretty new so it shouldn't have this problem.. When I got my car (used), it was pulling to one side and I didn't think anything of it.. I also thought it was just an alignment issue.. When I was replacing my OEM shocks/springs w/ aftermarket, I did notice that my OEM camber had ripped... Dealer also pointed out that I had the "ballooning/mushrooming" problem of the shock tower (passenger side)...
It turns out that the old owner had probably hit some major pothole/bump, thus ripping the OEM camber plate, and causing the mushrooming problem.. Dealer wouldn't replace the camber because 1. I had an aftermarket setup (even though I just had installed it when I noticed the rip), and 2. the mushrooming problem tells them the car had hit something bad.. I ended up changing it to RDR camber plates, and my pulling to one side disappeared...
I'm sure this is not your problem, but something to check if the alignment or tire pressure is not the problem.. I still believe this is a weak link of a MINI because I'm not alone in this problem. If you do a search, you will find lots and lots of info on this mushrooming problem..
///Gilbert
Old Sep 16, 2005 | 07:43 PM
Battle Cattle
If I didn't have to go to work when I first posted I would have told ya I made sure all my pressures were the same and made sure I didnt see any visible damage to rims/tires. I don't think I was tramlining because it happens everywhere... including my driveway... I have a square one so i can go in different directions with the same result. Sounds like I needs to give them a call tomorrow and get my baby in before I leave.
-Josh
Old Sep 17, 2005 | 11:38 PM
Guest's Avatar
Guest
-Josh
If it's happening everywhere I think you probably just need an alignment. Check it out at the dealership if you're car's under warranty. I hope it isn't something serious like the camber plate
Old Sep 18, 2005 | 12:39 AM
minicoop78's Avatar
minicoop78
Old Sep 29, 2005 | 09:01 AM
sprp85's Avatar
sprp85
hm
any update on this??
Old Oct 4, 2005 | 05:18 PM
Battle Cattle
alignment.... fixed...
-Josh
09R56
Nov 16, 2022 10:49 AM
Cereall
Sep 5, 2019 06:05 PM
Motown
Apr 20, 2018 09:31 AM
xpunisherx
Aug 10, 2015 10:50 PM
bc219
Aug 10, 2015 11:22 AM
