Drivetrain What are the 300+whp cars doing for fuel systems
Old Aug 27, 2005 | 09:58 PM
spillman's Avatar
spillman
I am in the process of redoing my fuel system. Just wanted to see what you twin charge guys are doing to get more fuel. I am planning on a return style setup with a walbro pump.
Just wanted to see if you guys are changing the fuel pump to fuel rail lines and the fuel rail or just simply running a return line back to the fuel tank.
Any info would be great. And if any of you can contact El for me then that would be great also.
Old Aug 27, 2005 | 10:16 PM
gjpundsack's Avatar
gjpundsack
This thread of mine may help you...
http://www.cooperspeed.com/forums/showthread.php?t=2664
Old Aug 27, 2005 | 10:19 PM
Ryephile's Avatar
Ryephile
uhh, unless you're actually getting 300+WHP, you're going overboard. Just install bigger injectors, it seems the stock returnless fuel system, including pump and rail, are sufficient for 300cHP MCS's. Of course, installing a fuel pressure gauge will help determine if you need to upgrade the pump. I'm not sure why you would want to impliment a return line though.
Old Aug 28, 2005 | 01:54 PM
spillman's Avatar
spillman
I am already a bit over 300chp. I am just barely starting to have a lean out at 7,000 rpm. I am planning of doing something north of 320-340 whp.
Old Aug 28, 2005 | 02:03 PM
spillman's Avatar
spillman
Originally Posted by gjpundsack
Is this the right link? All I found was info on MTH and Evo tech ecu software.
Old Aug 28, 2005 | 03:17 PM
mybroscoop's Avatar
mybroscoop
how is your supercharger holdin up to that 23% reduction??? i cant imagine it will last too long due to over revving the supercharger, has anyone running this setup done a tear down and looked at the supercharger say after 1000 miles??/.
Old Aug 28, 2005 | 03:33 PM
spillman's Avatar
spillman
I just had the horn off going to the intercooler the other day and didn't see anything out of the ordinary. I have the intercooler off weekly and have not seen any metal flakes. I have over 15,000 miles on my setup.
Old Aug 28, 2005 | 03:47 PM
mybroscoop's Avatar
mybroscoop
wow that is quite impressive, thanks for sharing! do you shift earlier in the rpm band to prevent over revving the supercharger??
Old Aug 28, 2005 | 08:19 PM
1FSTMINI's Avatar
1FSTMINI
http://www.rceng.com/about.htm
They have injectors for our cars up to 750cc i think they said.
Old Aug 28, 2005 | 10:22 PM
Maximusmini's Avatar
Maximusmini
750cc is wuite rediculous and non usable.. unless of course you put a DSM motor in...
Old Aug 29, 2005 | 03:29 AM
spillman's Avatar
spillman
You can put bigger injectors in a car all day and still be running lean. My fuel injectors are not the limmiting factor here. The fuel pump, fuel lines, and fuel rails are whats the problem.
Old Aug 29, 2005 | 04:27 AM
ingsoc's Avatar
ingsoc
How will you reach into the 320+'s, spillman?
Old Aug 29, 2005 | 05:30 AM
1FSTMINI's Avatar
1FSTMINI
Amazing.........all that with a 380cc injector isnt bad . Id def go with a 440cc or 550cc
Old Aug 29, 2005 | 01:50 PM
spillman's Avatar
spillman
Im not using a dry shot I am using a wet shot. I don't plan on changing injectors. I just need to get more fuel to the nitrous/fuel nozzle.
Old Aug 29, 2005 | 01:51 PM
1FSTMINI's Avatar
1FSTMINI
Get out.....Your tellin me a 380cc is pleanty for what you have?
So all you need is a bigger fuel jet huh.
Old Aug 29, 2005 | 03:00 PM
spillman's Avatar
spillman
Actually I am seeing a lean out just barely at 7 grand but I can solve that with a different fuel pressure regulator.
And yes all you do is install a bigger jet that goes along with the larger nitrous jet. However I won't be using a larger jet. I will be using another valve all together. Hence the second stage. 75 shot for 1st and then whatever I want to use for 2nd.
Old Aug 30, 2005 | 06:18 AM
1FSTMINI's Avatar
1FSTMINI
This is all with the stock internals?
Old Aug 30, 2005 | 02:24 PM
spillman's Avatar
spillman
Until it pops.
Old Aug 30, 2005 | 04:35 PM
btal40's Avatar
btal40
haha i love that idea, wish i could do it! spillman is my new idol- you should have a video of when it pops or something
Old Aug 30, 2005 | 06:37 PM
Maximusmini
Mine already popped.. now it has been a month since I've driven my Vader. BTW I don't want to be someone's idol.
Old Aug 30, 2005 | 08:47 PM
btal40's Avatar
btal40
just joking, saying i wouldnt have the ***** to push it that far - givin respect to those who do. just something about the way he just said... till it pops that made me chuckle, i dont want his motor to pop or anyones for that matter. but this has nothing to do with the topic...
Old Aug 30, 2005 | 08:59 PM
spillman's Avatar
spillman
I have already accuired the knowledge I wanted from a well respected person who is know longer a part of this community. I think we all know who I am talking about. It seems NAM is no longer the place to go if you need info about something new or something the vendors don't offer. Kind of sad really. I remember the good 'ol days when things really "went down" on here.
Old Aug 30, 2005 | 09:16 PM
btal40's Avatar
btal40
ive been following your progress for a while now, people are learning stuff from your experience i think, i just dont know enough tech stuff yet to contribute but im learning if that means anything
Old Aug 30, 2005 | 10:20 PM
spillman's Avatar
spillman
I am still in the learning process along with everyone else in the MINI and every other automotive community. I just wish everyone wasn't so scared of trying new things with the car.
I don't think the levels of performance you can reach now are as far as our little 1.6L can be pushed. Call me crazy but sometimes I like to do things a little different then the way they are "supposed" to be done.
Old Aug 31, 2005 | 02:59 PM
isellem's Avatar
isellem
spillman are you running a wet shot or a dry shot... i can't recall
