Drivetrain Semi-Custom Exhaust
Old Aug 9, 2005 | 11:22 AM
minimort's Avatar
minimort
Semi-Custom Exhaust
I'm going to be using a sorta-custom cat-back exhaust on my '02 S, and was wondering if anyone had this same set up.
I'm going to be using the rear section of the MCS Magnaflow exhaust (section with the 2 mufflers and the tips). This will be connected to the stock cat using a 3" pipe. Bends will be similar to stock, with the same hangers.
I'm hoping for better flow (obviously as the pipe is bigger) and more noise.
I'm just not sure how loud I'm looking at.
Anyone have any ideas?
Old Aug 9, 2005 | 11:49 AM
obehave's Avatar
obehave
Just curious.
Won't you be going from a 3" in to a 2.5" exhaust?
I don't see a lot of advantage in that.
Old Aug 9, 2005 | 11:56 AM
Maximusmini's Avatar
Maximusmini
As long as you're not as loud as Mine is you shouldn't have any problems. I have a 3 inch exhaust all the way back courtesy of the twincharger. I am running a single non baffled 3 inch in and out race muffler. At WOT it sounds as if it is redlining at 22,000 rpm.
Old Aug 9, 2005 | 12:10 PM
minimort's Avatar
minimort
Originally Posted by obehave
Just curious.
Yep that makes sense. Only going to be doing 2.5" all the way back then, unless I replace all the pipes that is.
Old Aug 9, 2005 | 02:01 PM
obehave's Avatar
obehave
With no resonator it should sound nice.
3" all the way through would be pretty beefy. Might be a tad heavy too.
Old Aug 9, 2005 | 05:45 PM
ScottinBend's Avatar
ScottinBend
Just curious.
If he is going from a single 3" to dual 2.5" pipes it will work wonderfully.
Old Aug 9, 2005 | 07:09 PM
kalbone's Avatar
kalbone
i'm getting a 3" pipe installed tomorrow
Old Aug 10, 2005 | 05:13 AM
obehave's Avatar
obehave
There will still be a pinch point where he transitions from 3" to 2.5". Unless he were to heavily modify the entrance to the ring that is the back section of a Magnaflow systems.
Doable but not in the description of what was going to be done.
So unless that's done it won't work wonderfully.
Old Aug 10, 2005 | 05:55 AM
minimort's Avatar
minimort
I will hopefully not be heavily modifying anything. I'm trying to get the most for the $, so if it's easier just to go 2.5" back and skip the resonator, I may just have to do that.
I was also thinking that instead of a resonator, I could go with a glass pack...hmmmm...
Old Aug 10, 2005 | 10:30 AM
obehave's Avatar
obehave
If you do go that route pay a bit more for one that uses stainless wool. The traditional glass batting lasts about 10K miles before it compresses and becomes junk.
Just use a straight pipe and throw a roll of header tape around the section just under the front seats
Kidding.
Old Aug 10, 2005 | 04:37 PM
minimort's Avatar
minimort
Haha. It sounds bad, but I'm kinda cheap.
I'm looking to get a "decent" exhaust for as little $ as possible. I can get a 18" glasspack off Ebay for like $20, prob. pretty crappy, but then it's only $20, right?
I figure I can do the whole system for less than the Megan cat-back.
Old Aug 10, 2005 | 07:59 PM
ScottinBend
If he maintains the 3" all the way to the "y" it won't have a pinch point. 3" pipe split into 2 2.5" pipes is not going to be resriticted. I thought that's what he was implying.
Old Aug 11, 2005 | 05:22 AM
minimort's Avatar
minimort
With the Magnaflow back box, there is a piece of 2.5" pipe, which then goes into a T connecting to the mufflers. I am now thinking that due to the piece here, and the fact that the pipes coming from the mufflers to the tips are also 2.5", going with 3" may be a bit excessive. It would provide more flow for a bit, but then it goes back to the 2.5"
Old Aug 11, 2005 | 06:14 AM
obehave's Avatar
obehave
The short tail piece in this pic. That's the chunk Scott and I are discussing.
If you chopped it off as he suggests the 3" would probably work but that adds to expense, not much though.
Old Aug 11, 2005 | 08:08 AM
norm03s's Avatar
norm03s
Also
[QUOTE=obehave]If you do go that route pay a bit more for one that uses stainless wool. The traditional glass batting lasts about 10K miles before it compresses and becomes junk.
When you speck out the "glass pack" make sure you get one the has a perforated internal pipe rather that the louvered ones, they flow better.
Old Aug 11, 2005 | 08:40 AM
minimort's Avatar
minimort
I was thinking about one of these :
http://cgi.ebay.com/ebaymotors/Flowt...QQcmdZViewItem
Old Aug 11, 2005 | 12:44 PM
obehave's Avatar
obehave
That has the louvers that Norm was warning against and he's right.
Flow tech. They make some called Purple Hornies too if I remember right.
Old Aug 11, 2005 | 01:05 PM
minimort's Avatar
minimort
Yeah, I was looking at those, the Purple Hornies, but they are either 3" both ends or 2.25" all around. not going to help me there. Plus, they are louvered as well.
I wasn't really too concerned with longevity, looking to be loud and somewhat unique, as well as cheap.
Old Aug 11, 2005 | 01:45 PM
obehave's Avatar
obehave
I think you're there then.
You'll be asked for pics and sound files so be ready.
Old Aug 11, 2005 | 02:22 PM
minimort's Avatar
minimort
I'm planning on that.
I think I'll have the whole system built, shipped and installed for less than the Meghan Racing exhaust before shipping. Not too shabby.
It's gonna be loud as all hell though
Old Aug 11, 2005 | 02:24 PM
kalbone's Avatar
kalbone
i got a 3" exhaust installed yesterday, from the cat back. it sounds very deep. and its very efffin loud.
Old Aug 11, 2005 | 02:32 PM
minimort's Avatar
minimort
Sweet, pics?
Old Aug 11, 2005 | 02:37 PM
orthomini's Avatar
orthomini
exhaust
check out aero turbine. i think they make some resonators and they are stainless as well.
Old Aug 11, 2005 | 02:48 PM
kalbone's Avatar
kalbone
here's some pics
Old Aug 12, 2005 | 10:16 AM
kalbone's Avatar
kalbone
new pics
