Drivetrain post your torque PLEASE
Old Jul 29, 2005 | 03:39 AM
SpiderX's Avatar
SpiderX
post your torque numbers PLEASE
and what you did to achieve the greatest gain.
I'm trying to get more torque and I'd like to see what others have achieved and what has sent them backwards?
Thanks in advance
Old Jul 29, 2005 | 07:26 AM
jlm's Avatar
jlm
FYI: basically, hp is calculated by multiplying the measured torque at a particular RPM by the rpm. Since the rpm is plotted linearly, a constant torque would give a linearly rising hp curve. What actually happens is the torque rises to a more or less constant level at the lower rpms (around 3000) and stays relatively constant, until engine breathing punks out, then it starts to decrease. as soon as torque starts falling at the same rate as the rpm rises, your hp has peaked out. What you really need is a graph of torque vs rpm.
as an example, Road and track once did a test of a San Francisco cable car. torque went from zero to it's max value max in 1 second, as the cable was gripped. a very flat torque curve with minimal rise.
the typical mini will show about 75% max torque around 2500, max out around 4000, and slightly drop off until 5500-6000, then start to drop more severly after 6800. best my rig ever did was 174 ft-lbs at 4500; 160 at 3000, 130 at 2500.
Old Jul 29, 2005 | 08:00 AM
hornguys's Avatar
hornguys
2500 - 150 ft. lbs.
3000 - 160
3500 - 174
4000 - 177
4500 - 177
5000 - 177
5500 - 172
6000 - 158
6500 - 149
Old Jul 29, 2005 | 08:15 AM
SpiderX's Avatar
SpiderX
Are these numbers corrected for drive train loss?
Old Jul 29, 2005 | 09:58 AM
ingsoc's Avatar
ingsoc
Most likely not. I am curious if driveline loss for torque is the same as for hp. Any ideas?
Old Jul 29, 2005 | 10:12 AM
spillman's Avatar
spillman
23% is king of torque
I believe the 23% reduction will rule the torque war. More boost at lower rpm eguals more HP and Torque. I have put about 10,000 and about 10 runs down the 8th on the car since the install and everything works fine.
Old Jul 29, 2005 | 10:32 AM
hornguys's Avatar
hornguys
Spillman,
Very impressive.
What have you established as your effective redline?
Old Jul 29, 2005 | 11:06 AM
SpiderX's Avatar
SpiderX
Help me out here.
I see 200 ish for hp and 185 for torque....where does 23% come in?
Old Jul 29, 2005 | 11:43 AM
spillman's Avatar
spillman
My apologizes for not being specific but the 23% I was refering to was the supercharger pulley reduction amount. 19% supercharger pulley and a 4% crank pulley.
Old Jul 29, 2005 | 11:45 AM
spillman's Avatar
spillman
Originally Posted by hornguys
Spillman,
Very impressive.
My redline shifts are at about 6750-6800. I know this is over taxing the supecharger a little bit but the car keeps pulling hard up until then.
Old Jul 29, 2005 | 01:46 PM
SpiderX's Avatar
SpiderX
You may be right short of turbo and laughing gas.
Old Jul 29, 2005 | 02:10 PM
kesh420's Avatar
kesh420
SpiderX...
Never seen this topic on a forum
Interested...
Kesh
Old Jul 29, 2005 | 02:15 PM
UUNetBill's Avatar
UUNetBill
Hey, like, here's mine, eh?
Oh, wait, you said 'torque' - Jeez, I'm sorry, eh, I thought you said 'toque'. . .I'm such the hoser, eh?
Old Jul 29, 2005 | 04:30 PM
jlm's Avatar
jlm
my numbers were recorded by Hubie and are wheel readings, not "corrected"
Old Jul 29, 2005 | 04:51 PM
motorsports3's Avatar
motorsports3
Not even close
Old Jul 29, 2005 | 08:24 PM
SpiderX's Avatar
SpiderX
Originally Posted by motorsports3
Not even close
Really, can you elaborate?
Old Jul 29, 2005 | 08:25 PM
SpiderX's Avatar
SpiderX
Thanks....your contributions to my education are always appreciated.
USA-RET
Nov 9, 2015 07:27 PM
Sep 3, 2015 10:29 AM
Sep 2, 2015 11:15 AM
cw40342
Sep 2, 2015 06:01 AM
