Drivetrain Official ALTA Q&A thread!
Old Jan 29, 2007 | 08:59 AM
  #751
ALTAPerformance's Avatar
ALTAPerformance
scolburn79: I will look around and get back to you ;-) THANK YOU for your continued patronage. We really do appreciate it!
robino: Thanks for asking! The shifter is 12mm x 1.25. Hope that helps. I answered your question about the tips in your other thread, but happy to help here as well. There may be some rinse on the outside of the tip that will bubble off and leave a brown residue. We have noted the issue and are scrubbing the tips again before packing. Also, if the chrome is truly bubbling (this would be weird and not something we have seen before) we need to check into the cause. I know you are running catless and that would significantly increase the temperature at the tips. In theory that should not be a problem, but regardless we need to find out the root cause. Please call me or Jeff directly at the number below. Thanks again for your continued patronage!
Thanks again everyone! Hope everyone had a great weekend!
Old Jan 29, 2007 | 09:06 AM
  #752
robino's Avatar
robino
not running catless, the factory cat is welded to the OBX header (to a flex pipe)
yes, there WAS bubbling, now flaked off and small brown spots showing in those areas where the chrome chipped off, not enough to make me hate it yet...but if it continues it WILL look like total dog poo.
you guys should have used a polished tip of some sort instead of messing around with chromed tips. Tripple chroming the tips would resist any amount of heat if done right...i've owned a few Harleys to know that good chrome will resist heat.
thanks for the **** thread measurement
Old Jan 29, 2007 | 09:23 AM
  #753
ALTAPerformance
robino: No problem! Thanks for the follow up. Glad to have the information. The tips do go through a multi step process (I beleive it to be triple plated.) so if they are flaking, we want to fix that for you. PLEASE call me or Jeff here so we can address this for you. We want to help. Please allow us to do so. Thanks again for your business.
Old Jan 29, 2007 | 10:06 AM
  #754
a610's Avatar
a610
Not to be rude, but are you sure your air diverter would work with the GP intercooler? It looks like your diverter would cover the two additional bars on the GP intercooler. Is there trimming involved or am I missing somethng? Thanks
Old Jan 29, 2007 | 10:36 AM
  #755
ALTAPerformance
a610 and ultimately Frodo: You are not missing anything and I should have been more specific in my earlier reply. It could fit. But we don't recommend it without modification, as it will cover at least 2 rows of the core. However, it would technically fit. MY sincerest apologies if that previous comment was misleading. It was truly not intended to be. If enough GP owners were interested, we would be happy to produce a GP specific diverter as a group buy or similar. So if anyone is interested PLEASE let me know. Otherwise you could modify the current ALTA model, then have it re-powdercoated.
Hope that helps. Thanks everyone!
Old Jan 29, 2007 | 04:43 PM
  #756
newbs49's Avatar
newbs49
Alta
If your thinking of doing a diverter for a GP let me know. I think if you post in the GP section more interested GP owners would jump in.
Old Jan 29, 2007 | 10:42 PM
  #757
Frodo's Avatar
Frodo
Originally Posted by newbs49
Alta
Those of us looking at buying the GP intercooler will be interested as well. The GP plastic diverter is more than the ALTA. Thanks for the follow up Alta
Old Jan 29, 2007 | 11:55 PM
  #758
motonikki812's Avatar
motonikki812
Originally Posted by motonikki812
I need the metal sleeve that goes inside the oil catch can to keep it from sucking in like a lung when the motor is running. I talked to Jeff over the phone about 2-3 weeks ago and he assured me that he would send one out asap.
I have still not recieved it. Let me know what I must do to get this part.
Also, have you ever heard of MINI owners running into trouble with thier OCC because .... The tubes that go straight up out of the top of the can bend too hard pressing against the inner top of the bonnet and getting kinked; cutting of the air feed and return??? This is what I am noticing with mine. I have mounted the can in 2 different locations and it is still a concern. The only way that I can tell when I pop my hood is if the can is succking like a lung they are not kinked. If the motor is still running and I peak in to the back of the engine bay and the can is not sucked in, I can assume one of the hoses is kinked.... which is almost always is. I think this could of attributed to my recent valve cover explosion (you may have seen the post). There has to be a fix for this.... I am thinking that if you switch out the input/output plastic fittings on the top of the can with similar ones but are 90 degree bent it would remedy this problem. It would keep the hoses lower in the engine bay and out of the way of the things we dont see when the bonnet is closed. such as... the headlight assemblies, and inner bonnet liner with its form fitting areas that push into the compartment. I have tested the current fittings, hose lengths and can placment alot with trying to determine what caused my valve cover grenade incident.. and I think this could of been a major part of it...
Anyhoo, just info that you might be able to do something with...
If you have any 90 degree fittings I could really use those to, but I will probably just try to find them at my local auto parts store.
I really do need that sleeve for the inside of the can though.
email me for shipping info.
Thanks for your support and keep making killer parts!
Jasun Carter (805) 452-4589
jcarter457@worldsavings.com
I just wanted to drop a note and let you guys know that I recieved the OCC inside sleeve part today that I requested today.
Thanks very much!!!!
It was funny... The doorbell rang and I walked down to see who was there. I see the UPS guy walking back to his truck. I look down and see a small ALTA box and was super happy. I am thinking to myself "sweet the guys came through". Right as I shut the front door and walk back into my office I realize I have a voice mail waiting on my cell phone... I check the message and its Ryan from ALTA saying that the part is shipped and I should be seeing it anytime!
What timing! Thanks again and I look forward to draining more of my savings on cool stuff that I have to hide from my wife from you guys...
Jasun
Old Jan 30, 2007 | 12:19 PM
  #759
scolburn79's Avatar
scolburn79
Hi Alta,
Just seeing how you went with trying to find a 15%S/C Pulley Version 2.0 that you don't need? Thanks again
Stephen
Old Feb 8, 2007 | 06:04 PM
  #760
robino's Avatar
robino
love your direct flow intercooler, nice and easy install, looks great, question though: What are those two little steel L brackets for? The ones that say Alta on them? In your instructions it says to use them on the 'outer' IC clamp nipples as per the picture, but there's no picture that shows where they go or how they're angled...
whichever way i tried to use them, they make no sense as to why they should be used. Can you direct me to a link showing how and where these are used?
Thanks.
I've also trimmed the stock scoop, my other question is, when are you coming out with a scoop of your own that would exaggerate this opening even more...?
Old Feb 9, 2007 | 08:35 AM
  #761
ALTAPerformance
newbs49 & Frodo: Thanks for the idea. I have Jeff working on it right now. I will get back to you GP owners shortly!
Thanks again!
Old Feb 9, 2007 | 08:38 AM
  #762
ALTAPerformance
motonikki812: GLad we FINALLY came through for you. Keep us posted! Talk to you soon!
scolburn79: Still looking!
robino: Let me see if I can get some photos for you posted up here. I am kind of internet illiterate. Check back in a few. Thanks again!
Old Feb 9, 2007 | 08:44 AM
  #763
ALTA2's Avatar
ALTA2
Manufacturer
See if this makes sense:
You see where the trim wraps over the IC and down the side. The small 90 degree bracket bolts to the outer most posts, and gives something for the trim to grab.
Since you have already cut your trim, you will need to get a new piece. But have no fear, we have lots of this! Just email us your address, and we will send some off to you!
Hope that helps!
Nice Intake!
Old Feb 9, 2007 | 04:58 PM
  #764
robino's Avatar
robino
ok now it makes sense...
i had no picture to go by, so...but yes, i will need a new piece
Old Feb 10, 2007 | 03:41 AM
  #765
Frodo's Avatar
Frodo
Thanks again!
Thanks guys, for the record, I don't have a GP (I wish) I just want to use a GP intercooler. The intercooler is fairly cheap but the plastic diverter is a lot more than yours. Plus we would have the water sprayer too! So for those of us wanting a GP intercooler (retrofit) this would be a great cost savings and would look better too For the GP guys and gals, it would be a easy way to add the water sprayer and increase the airflow. Just my 2 cents.
I have time to wait...but if I see a good deal on your direct flow IC I may have to jump on it Thanks again
Frodo
Old Feb 10, 2007 | 07:57 AM
  #766
newbs49's Avatar
newbs49
Frodo
Your correct!!! Us GP guys want more air without giving up to much of a change to our cars. Plus the water spray for the track is a plus.
Old Feb 10, 2007 | 12:04 PM
  #767
Frodo's Avatar
Frodo
Well newbs I guess we are on the same page
Hey Alta, do I get credit for the idea? (I doubt I was the first to ask ) is that credit good for a discount? (Have to try )
Frodo
Old Feb 12, 2007 | 10:20 AM
  #768
ALTAPerformance
Frodo: Thanks for the heads up! As always we are constantly reviewing new product ideas. If and when the item comes to fruition feel free to call me directly!
news49: I 100% agree. Stay tuned!
Thanks again everyone.
Old Feb 12, 2007 | 10:23 AM
  #769
ALTAPerformance
Also, just wanted to say thanks to the PDXMINI.org club for a wonderful event on Saturday and Sunday. We had a great time and look forward to the next opportunity to help out on "Mod-Day"!
Also, if any other clubs around the country would like ALTA to help out either in person or with other forms of support PLEASE let me know. We have another event scheduled with the Puget Sound MINI Club soon, but would be more than happy to help others too. Hit us up!
Thanks again!
Old Feb 12, 2007 | 10:52 AM
  #770
jaridp's Avatar
jaridp
Thanks again!
Hey Adam. If you need a test mule for GP stuff...you know where I am!!
Old Feb 12, 2007 | 11:00 AM
  #771
ALTAPerformance
jaridp: Thanks for the offer! I had nearly forgotten about your car. I will call you today and make arrangements to get some accurate dims off the core. Then I can have the proto for you to try out as well. We always enjoy working with you and appreciate the help in the past as well. Chat soon!
Old Feb 12, 2007 | 11:06 AM
  #772
Frodo's Avatar
Frodo
Frodo: Thanks for the heads up! As always we are constantly reviewing new product ideas. If and when the item comes to fruition feel free to call me directly!..
Adam/Alta gets an A+ in customer service today ...to be honest, Alta has stepped up in the customer service for a while...
You know, for some reason I keep adding more and more Alta products on my car. Don't get me wrong there are some great stuff by other venders and I wish I had the $$ to add some of them on my car. It happens that the planets line up with Alta when I have money to buy something. My car is not all Alta but close...
Frodo
Old Feb 12, 2007 | 11:33 AM
  #773
jaridp's Avatar
jaridp
OOOo we will be chatting sooner than you think!! I am working on a certain mellow yellow project for ya!
Old Feb 12, 2007 | 12:50 PM
  #774
newbs49's Avatar
newbs49
I feel left out now. I've suggested a few things for the GP, but I'm on the other coast. How's that replacement airfilter coming for the JCW/GP air box.
Old Feb 12, 2007 | 12:57 PM
  #775
jaridp's Avatar
jaridp
This has been done by other companies..How bout some more unique stuff!
