Drivetrain Official ALTA Q&A thread!
Old Oct 12, 2006 | 08:02 AM
  #601
ALTAPerformance's Avatar
ALTAPerformance
Ovrezee: No issue at all. Just use the instructions included with the pulley to determine proper belt selection. Have a great time!
Old Oct 12, 2006 | 10:42 AM
  #602
#20Works4me's Avatar
#20Works4me
HI Adam, I currently have the stock belt going to the 3% can I re use it? thanks once more
Old Oct 12, 2006 | 11:04 AM
  #603
ALTAPerformance
Ovrezee: 15% PLUS 3% = STOCK BELT! No problem. Good luck!
Thank you.
Old Oct 12, 2006 | 02:14 PM
  #604
A S K's Avatar
A S K
thanks for your insight.
i will add the 'alta nator' and see if there is a difference. if there is any change on my car after 'altanator', than i know it is doing something.
parasitic drag? what is this? can you care to explain little bit more undstandingly? i am new to the car mod/engine world and i am learning as i am getting them on and also on this forum but nothing much on this parasitic drag. i'll be waiting for your education on parasitic drag 101.
decel issue: i could see what you mean. i will definitely check to see if my brakes are faulty but as mentioned, it was noticeable after the mods installed. i had no problem when it was stock and was gaining mpg with the intake that i have installed but after the pulleys, i noticed the decline on my mpg and and deceling faster than normal. i do 80/20 hwy/city driving.
thanks for your help and talk to you soon.
Old Oct 23, 2006 | 11:47 PM
  #605
VBG's Avatar
VBG
CARB for the Alta CAI
Hi Adam,
Sorry, I've been out of touch for a bit.
Thank you for this encouraging news, please do continue to let us know as things proceed. It sounds like CARB for the intake is just around the corner now. It will be very welcomed .
Btw, thank you and thanks to all involved at Alta for persevering with this. I'm sure there will be a huge collective sigh of relief from Alta as well as every owner when those intake stickers become available in California.
Best,
-- Don
Originally Posted by ALTAPerformance
VBG: At last discussion with Jeff we have the CARB # for the Inlet Hose, and the intake is supposed to be any day now. But please keep in mind that we are dealing with a governmental agency not in our state, and sometimes things move very slowly. The CARB exemption is EXTREMELY important to us and we will make a mass announcement once everything is done. Also, I have a test sheet from an inspection station in the LA area that referenced an exemption for the intake already. I have not been able to get confirmation where the testing station was able to get the EO number. Again, working on all of this.
Thanks again folks!
Old Oct 24, 2006 | 07:48 AM
  #606
AstroBlackBeast's Avatar
AstroBlackBeast
Oil Catch Can parts
I have one of your oil catch cans that I haven't installed yet. It was shipped missing one of the little metal quick-release grommets for the oil level sight tube. Is it possible to send one to me? Please get back to me, thanks again and you guys make some nice product.
Old Oct 24, 2006 | 09:21 AM
  #607
ALTAPerformance
VBG: No problem! WE will continue to keep everyone posted. Thank you for your patience!
AstroBlackBeast: We can certainly do that no problem. Either call the retailer, or us directly. We will get some basic info and send it today. We will be on a skeleton crew next week for the SEMA show so try to get in touch soon!
Thanks again guys. If any of you are attending the SEMA show we are in booth 24825. Look forward to meeting you!
Old Oct 24, 2006 | 09:49 AM
  #608
UKSUV's Avatar
UKSUV
ALTA - Question #1 I have sent you numerous faxes and left messages regarding my busted heim joint on my right front endlilnk. With no response. At this point, I just went down to the local 4x4 shop and got another one. But, right now, my other side is bending at a 45 degree angle. Why are my front links doing this? I have H-Sport comp sways.
Question #2 My endlinks have clunked and rattled from day #1. I was tightening them so many times that I stripped every nut. Thankfully, the vendor I bought from (JSCSpeed) was cool and sent me replacements since I couldn't find any around Phoenix. I then proceeded to loctite all of them. Well, that lasted 4 months. Now they are doing it AGAIN. I shouldn't need to loctite them. What happens when I have to adjust them again? I am not the only one with this problem. Am I going to have any problems like this when I finally get around to intalling my ALTA upper/lower control arms?
Question #3 What is the "RIGHT WAY" to adjust the endlinks? I have gotten several different answers. When I had problems of the heims snapping...everybody accused me of not setting them to the proper length (with was stock BTW)...can't really mess that up. Now, I am slammed down to the ground and did the best I could. Just "guesstimate" is not the answer I wanted to hear from ALTA. Then, get blamed for not properly setting them up? How DO YOU KNOW when they are set right? Especially for a slammed car? Is the bar parallel to the subframe?
I really like ALTA products and am about to buy an alternator and crank pulley from you. Don't make me wish I haden't...Cause I'm leaning towards that way......thanks guys :impatient
Old Oct 24, 2006 | 12:00 PM
  #609
Dr Obnxs's Avatar
Dr Obnxs
To set end-links....
you want them to be centered when the car is at rest. That means the bolt of the heim joint comes out perpendicular to the end-link. This allows for the most angular deflection.
Many have gone back and forth on the end-links. The stockers are light, and have wonderful angular range of motion, but they aren't adjustable so they're no good for corner balanced cars without some pre-load in the sways. It just seems that there isn't a perfect solution out yet..... FWIW, I have the Altas on my car in the rear, and when I bought them used they were very sloppy. I got new joint from Alta and now they are fine. But I get the feeling that for the aftermarket end-links out there, they are basically a wear item.....
Matt
Old Oct 24, 2006 | 01:17 PM
  #610
UKSUV's Avatar
UKSUV
Matt
Hey Matt...I've had these problems since day 1. And you have provided the best explaination as of yet. BTW, thanks again for the scoop. FWIW, I am going to make my own links from now on. $7 per hiem and $6 for the shaft. $40 per set compared to $117 (especially a "wear item") is a good deal. Same with the control arms.
Old Nov 2, 2006 | 12:35 PM
  #611
GreenIguana's Avatar
GreenIguana
Alta Exhaust issues
Why does my Alta exhaust have fitment issues out of the box??
The dealer installed and it comes out of the end at an angle, now it have melted my rear valance and they tell me I have to spend more time and money to go to a muffler shop and have them weld another piece to hold it from burning my car????
Why is this not fixed in R&D, and why is it still being sold with this issue???
I have been happy with my other Alta products but this one has fumed me on ever buying another one and wishing I had gotten the Borla.
Old Nov 3, 2006 | 10:07 AM
  #612
ALTA2's Avatar
ALTA2
Manufacturer
GreenIguana: Thank you for your previous and current purchases. This is NOT normal nor acceptable. Not knowing more about the installation facility, etc. I can only assume from here that this is related to the installation. The system will fit perfectly if installed properly. The tip should NOT be at an angle, touching the bumper etc. I am at the SEMA show until Monday but would be happy to speak to your installer, yourself etc. as shortly thereafter as possible. We warranty every part we sell regardless where it was purchased. I look forward to speaking to you then. Please e-mail me with your contact information and if you don't here from me sooner, please call me on Tuesday. Thanks again for choosing ALTA Performance.
Old Nov 3, 2006 | 10:30 AM
  #613
sprp85's Avatar
sprp85
Pefect example of an awesome customer service...!
Old Nov 3, 2006 | 10:33 AM
  #614
curv872's Avatar
curv872
When will you be making an official new products announcement?
I noticed coasttocoast has already "spilt the beans".
Old Nov 3, 2006 | 10:44 AM
  #615
UKSUV's Avatar
UKSUV
I know that Matt replied to my post but ALTA did not. I would like to hear their answers to my questions. And I posted it almost 2 weeks ago.
Old Nov 3, 2006 | 08:05 PM
  #616
shinka's Avatar
shinka
Except that there are many people who have had installation issues with the ALTA exhaust, including Randy Webb and myself. I've put it on twice now and can't get it right. If there are some supplementary instructions to get it to install correctly, I'd be very appreciative of it.
Old Nov 3, 2006 | 08:49 PM
  #617
sprp85's Avatar
sprp85
I believe Randy Webb had an older version of alta exhaust, which several people experienced fitment issues..
I heard newer ones are alot better in term of fitment
Old Nov 3, 2006 | 08:53 PM
  #618
shinka's Avatar
shinka
I got mine in…I believe it was Jan or Feb of this year. Is mine new or old?
Old Nov 5, 2006 | 07:28 AM
  #619
Larry Clemens's Avatar
Larry Clemens
shinka: Thank you for the open mind and again for your business. Keep in touch!
Thanks again folks!
Any update on the CARB exemption for the CAI?
Old Nov 6, 2006 | 11:37 AM
  #620
ALTAPerformance
LArry Clemens: Jeff met with an ARB rep at SEMA and he assured us things were progressing well. They were finishing a 128 PT request from another company in CA and ours were just behind them for the second pass through. Sorry for the delay.
shinka: Yours should be new. If you are having an ongoing problem, PLEASE call me or Jeff in tech directly. Lets solve it! You can see by other members that this is NOT an issue that effects all. Very few have any issues at all.
sprp85: Randy's issue was related to the earlier Milltek header that rotated the exhaust flange beyond factory. This could be compensated for with the slipfits found in their own exhaust, but since ours is properly flanged, it forced the system off course. Milltek has since resolved this issue. Photos showing the problem were found (and i believe still found) on Randy's site. The show the factory header next to the Milltek and you can see the tail flange is off. (Also, thank you for compliment above;-)
UKSUV: I personally don't have an e-mail or phone message from you. I will be out of the office for SEMA but will be back late in the week. If you purchased these new and have the receipt, just let me know and if you are in the warranty period we are certainly happy to help. There are two wasy to install the front links. If you have a lowered vehicle, follow the specifics to that. If not then follow the instructions for the stock height. Failure to install and adjust properly can biind the endlinks. The links have reverse threads. Be sure to hold the center section when tightening them. This is NOT a common issue (please keep in mind we use these on our own cars so we should certainly know. PLUS we use these on a variety of cars and certainly not just limited to the MINI.) For #3 PLEASE see the latest instructions. If they are unclear call us prior to proceeding. No one wants you to have an issue now or down the road. Sorry if this didn't get answered in a timely fashion.
curv872: Check out our new website launching on the 11th. It has all the new parts. We think it is great that our loyal dealers took the information they gained at the show and are publishing it to their advantage. Let us know with any specific questions.
Thanks again everyone!
Old Nov 6, 2006 | 02:02 PM
  #621
asinn's Avatar
asinn
alta new intercooler version 2
hi,
I saw some website are selling alta new intercooler, however i still haven't see anything on the alta website yet, is alta going to release the intercooler on their website? also could you tell me what is the major difference between the newer design intercooler than the older one? how much performance improvement will i expect fromt the new design?
regards
Alfred
Old Nov 9, 2006 | 04:46 PM
  #622
ALTA2's Avatar
ALTA2
Manufacturer
asinn,
When the new site launches you will see the new IC. So yes we are releasing one!
The difference is what it does different compared to the old one. The new intercooler makes it power with less restriction on the charge side of the core. The charge side has a much larger cross section, and in turn allows for free flowing air on the charge side. When we designed our original core, we made it the same as stock (in that air flows down through it) but made it as big as reasonably possible. More than a year ago, when we were coming up with the Twurbo kit, we were looking at making something bigger. Given the space constraints under the hood, we came up with what you see now.
Quite a while ago, we gave one of these to Dr. Obnoxs on NAM, and he reported the findings. The findings were more HP! So that is how it started.
Its good to be back home from SEMA, sorry for not giving the NAM community much attention lately!
Old Nov 14, 2006 | 06:59 AM
  #623
minimort's Avatar
minimort
When does the new site launch?
Old Nov 14, 2006 | 07:08 AM
  #624
Minibeast's Avatar
Minibeast
I just checked...3 hour 27 minutes...LOL
Old Nov 14, 2006 | 07:42 AM
  #625
Drillslinger's Avatar
Drillslinger
What?!? I get 4 hrs 17 minutes
