Drivetrain M7 Technology pulley.......New
Old Apr 20, 2005 | 10:46 PM
M7's Avatar
M7
Here is the latest exciting product from Team M7..........
As we were looking to add a pulley to our existing product offering, we realized
that if did so, it had to be better, with the typical M7 "outside the box"
engineering and mind set.
So after staring at the typical pulley for an extended period of time, a lot of ideas how to improve the breed came to mind.
And these are the improvements that we have done:
#1 Belt to pulley interface IE. we changed the geometry of the
grooves, allowing more belt to touch the pulley surface. This will give the belt
better grip.
#2 We added shoulders to the outside of the pulley, preventing
the belt to walk of the pulley surface.
#3 Active cooling, by pulling in cool air (holes in pulley shoulder).
#4 Super low belt slippage with our proprietary v-groove surface treatment.
#5 Thermal surface barrier for lower belt temperatures.
#6 We decided to use a 16% reduction for our pulley, it's more then
the usual size, for a tad better engine response. And the other benefit is, if
a 2% crank pulley is used your change of accessory rpm will be a little
more with in safe margins.
And as always feel free to call us, pick our brain, or just enjoy
a fun chat about our favourite car the MINI.......
Price: 129.95
Available now
peter
Team m7
562-608-8123
Old Apr 20, 2005 | 10:56 PM
Eastsidemini's Avatar
Eastsidemini
M7 pulley
Peter, the pulley looks as expected.
Old Apr 20, 2005 | 10:57 PM
cdconsor's Avatar
cdconsor
sounds great....
and will you be offering said 2% crank pully? other crank pully sizes?
what about ECU programming from this configuration?
Its a little like christmas morning whenever the m7 announcement finally reaches the boards. keep on innovating!
Chuck
Old Apr 20, 2005 | 11:01 PM
M7's Avatar
M7
Thank you...
I just posted the price....
Crank pulley will follow, and ECU uppgrade is always optional, but with that said
we have something great coming...
peter
Team M7
Old Apr 21, 2005 | 12:39 AM
Eastsidemini
M7
Hi Peter
I just posted you coming to Hawaii in the VA. Let me know what you think? BTY, can you teach me how to post picture like your pulley on NAM . I've been wanting to post my racing heel/toe pedals on the VA. Please help!
Old Apr 21, 2005 | 06:07 AM
Turbogeo's Avatar
Turbogeo
WOW! Nice! -George
Old Apr 21, 2005 | 06:11 AM
mbabischkin's Avatar
mbabischkin
First upload your pictures to the web, you have a gallery here on NAM you can use.
Once you've uploaded the picture. Open it in your browser and then right click on it and select properties. In the window that opens you need the URL of the picture, highlight it and copy it (ctrl-c)
In the post that you want to put the picture in do the following:
Where you want the picture in your post type [img] paste the image URL here [/img]
It should look something like this but without any spaces...
[img] www. myimage. com/photo. jpg [/img]
Feel free to PM me if you have any questions...
Old Apr 21, 2005 | 06:56 AM
MyPocketRocket's Avatar
MyPocketRocket
beauty!
Old Apr 21, 2005 | 07:18 AM
Wraith1416's Avatar
Wraith1416
ah 16%, i like
Old Apr 21, 2005 | 07:36 AM
kaelaria's Avatar
kaelaria
Have there been problems with belt temperature or slipage, or walking? I haven't seen any of that posted before...
Old Apr 21, 2005 | 07:59 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Looks very nice and somewhat different from other pullies.
Old Apr 21, 2005 | 08:04 AM
MSFITOY's Avatar
MSFITOY
That's fantastic Peter:smile: It's now on my list of to do again project
Old Apr 21, 2005 | 08:19 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
I have heard of a lot of problems with temperature...mostly on mini2 and at meets
Peter....looks great
Old Apr 21, 2005 | 08:25 AM
VoiD's Avatar
VoiD
will it run okay with stock ECU?
not sure I like the 16% as many of the ECU Flashes are optimized for 15% or 19%.
Old Apr 21, 2005 | 08:31 AM
tennis_man's Avatar
tennis_man
With a 15% pulley reduction you can use the stock belt. With a 17% or 19% pulley you need to use a smaller belt. What size of belt would you use with a 16% pulley?
Old Apr 21, 2005 | 08:34 AM
asaulo1's Avatar
asaulo1
Peter
will this new pulley work with the stock belt or will it require a special belt? what was the reason to go 1% up on the pulley size? are there cars that already have had this installed? and for how long? I was holding off on the pulley on my 05 MCS but now I think, you've just changed my mind....
Alfred
Old Apr 21, 2005 | 08:46 AM
M7's Avatar
M7
Good Morning..
I like to address some of your questions.
As the engine compartment heats up, so does accessory drives, pulleys
and metal surfaces. This will prematurely age rubber, plastics or other
natural or man made materials. Our Thermal barrier will keep the belt cooler
thus extending the life expectancy of the belt.
Slippage is a well known problem with the style of rubber belt used on the MINI.
At high load a small amout of slippage will occur and this will again generate
heat and a small amount of power loss.
The 16% pulley will work beutifully with a 15% ECU map. As most programs
keeps the A/F ratios in the very rich regions, the added load from the 16%
M7 Technology pulley will lean up the ratios giving you better throttle response and more power.
As for throwing belts...no it's not a problem with a 15%-16% or 17% pulley
but if you would change the crank pulley to a 3% unit, suddenly we got
a problem IE. thrown belts. The lipp will prevent that from happening.
At this point we have utilized the stock belt, but we will try the
the Napa # 25-060539 this week.
The reason for a 16% is purely a personal preference for even numbers.
I also like the idea that you can add a 2% crank pulley, get to 18%
with less stress on the other accessories and operate within the rpm
envelope that the SC was designed for.
peter
Team M7
562-608-8123
Old Apr 21, 2005 | 08:51 AM
Partsman's Avatar
Partsman
Legion_of_Doom
m7 pulley
Does anyone know what this new pulley is made out of?
Old Apr 21, 2005 | 08:52 AM
gmcdonnell's Avatar
gmcdonnell
peter
Team M7
562-608-8123
Don't want to hijack your thread, but is this part number a smaller belt and can it be used with your new pulley?
/gary mc
Old Apr 21, 2005 | 08:59 AM
dave's Avatar
dave
pug poo picker-upper
From reading peter's post above that appears to be the smaller belt and they have yet to test the 16% pulley with the smaller belt, but plan to soon.
Also: Threads Merged.
Old Apr 21, 2005 | 09:14 AM
M1N1GUN's Avatar
M1N1GUN
Peter, this looks great. Looking forward to the early adopters impressions!!
Haha, so you may have to change your name to M16, or M14 (double 7's)?
I have the same question as PARTSMAN109; what is this particular pulley made from?
Looking forward to a busy year for the M7 crew...
Old Apr 21, 2005 | 09:17 AM
asaulo1's Avatar
asaulo1
Peter
has steve installed any of the new pulleys yet? hoping for an M7 pulley party soon!!! :smile:
Old Apr 21, 2005 | 09:20 AM
mini d's Avatar
mini d
Even numbers?
peter
Team M7
562-608-8123
How come you're not known as M6? (Disclaimer: no malice intended, just found it amusing.)
Old Apr 21, 2005 | 09:27 AM
M7's Avatar
M7
M7 sounded great, so M7 it was.....
The Technology pulley was released as a product last night, so Steve has not
had a chance to install one.
The material in the pulley is Unobtanium*
*Stainless Steel
peter
Team M7
562-608-8123
Old Apr 21, 2005 | 09:52 AM
Strom's Avatar
Strom
Will these be available to install at the party at Steve's on May 1st?
