Drivetrain M7 Technology pulley.......New
Originally Posted by Strom
Not quite sure yet - I'm going to discuss with him before installing. He seemed kinda busy when I was talking to him on the phone. :smile:
Randy
M7 Tuning
Awesome! I assumed that was about the price. I'm really looking forward to it.
Also, I didn't mean to imply anything about Steve's availability on the phone. He was very helpful. I just forgot to ask about the cost of installation, and didn't want to call him back later as he seemed busy.
If you have never been to Steve's, you don't have any idea what busy is!!:smile:
Even on a slow day Steve is running from car to car, never refusing to talk to any customer or work on any car that pulls in.
Now fast forward to one of the MINI installation days, when 30 MINIs descend on his shop, the controlled chaos is something to behold.
Bill
Bill
Originally Posted by webstrands
Peter,
What material is your pulley made of and how much does it weigh?
Thanks,
Rob
Thanks,
Rob
Randy
M7 Tuning
edited because JLM caught me with my spell check down
Originally Posted by maxmini
Rob, our pulley is made from stainless seel and weighs 16.153 ounces.
Randy
M7 Tuning
Randy
M7 Tuning
Is that an average weight, and, if so, how many pulleys were weighed? Also, what is the coefficient of variation in the weight? Finally, would it be fair to say that the pulley weighs about 1 lb or slightly under 1/2 kg (actually, 0.46 kg)?
Originally Posted by RECOOP
Randy,
That was an average of the first ten pullys in the box.
There was less than .018 variation bewteen the lightest and heviest weighed.
It would be fair but illegal per some NAM standards to generalize that the item in question weighed " about " 1 LB.
The test took place at 3:30 to 3:50 on 5/05/05 at 127ft above sea level.
Ambient temp was 67 degrees.
Wind was 3kts. out of the south.
The instrument used was a CAS electronic digital scale most recently checked and calibrated per ISO 9001 standards on 2/7/05
Randy
M7 Tuning
Dear Recoop,
Randy
M7 Tuning
Randy
M7 Tuning
Originally Posted by Rick-Anderson
But what was the position of the moon?
I swear to god i was going to say something about that but thought i had gone just about far enough LOL . Besides the moon hasn't come up yet how the hell should I know ?
Randy
M7 Tuning
Dear Recoop,
Randy
M7 Tuning
Randy
M7 Tuning
Good luck to you folks!
/gary
Originally Posted by miniaq
my works mini has the 14.3% reduction pulley, will changing to a 16% pulley make any real gains
To be perfectly honest going from 14.8% to a 16% pulley will make a real gain. The tricky part is what your definition of " real " might be. As with any Mini related mod each car reacts differently to modifications. Another variable is what other mods will be working in conjunction with the new pulley? Lets put it this way if you do a dyno run with your current setup and then with the 16% there will be a positive change in both the hp and torque curve and numbers. How much of a difference depends on the previously mentioned variables.
In all reality as far as seat of the pants difference goes there could be a minimal feeling of improvement but nothing like you get going from a car with no pulley to the 15% for example.
The bottom line is that your situation is not what we have set as our market for the 16%. True some are making that upgrade but we really are looking for those with no pulley to start with. I hope this helps you with your quandary.
Randy
M7 Tuning
Randy
M7 Tuning
Randy
M7 Tuning
I will be changing either the SC pulley (17%) or the crank pulley on my 05 JCW...I would need a 2.7% overdrive crank pulley to equal a 17% SC pulley, however. I just don't want to go over 17%. I'm also considering a larger IC and ported&polished SC to go along with the above.
The ported&polished SC, I'm told, will flow more air. This reportedly helps to keep SC temps down. A more efficient IC is a great, albeit expensive, partner to the pulley - my opinion.
Originally Posted by eMINI
A ported & polished SC sounds like a very reasonable approach. Where would one go to get such a piece?
I presently have our final version ready to be installed next week on my car for the last series of tests. We have had a couple of cars doing long term testing for the last few months with good results. We will be announcing this product officially in the next two weeks. Randy
M7 Tuning
Randy
M7 Tuning
Randy
M7 Tuning
My blower was p&p by ENDYN. I have a stock 05 blower ready for porting. no need for epoxy, already done.
Pulley claims
Randy,
Now that we've had a brief humorous interlude, let's get back to the nitty-gritty. What is the basis for making the various claims about the new pulley that M7 is promoting? There has been a fair amount of discussion regarding heat transfer, but we haven't heard anything about that subject with respect to the M7 pulley. Would you or Peter kindly supply this forum some objective information/data regarding the pulley, especially the alleged "heat" properties? Inquiring minds want to know ...
Pulley Claimed
Randy,
To prove the properties of the heat shield on our M7 Technology Pulley
I simply clamped a pulley (ours and another famous brand) pulley on our
workshop wise. I proceded to use our Benzomatic Propane burner, firing
in to the back of the pulleys where the SC shaft would normaly sit, for excactly 15 seconds no more, no less.
Here's the Data:
Pulley A
Start temp 75º, 15 sec 113º, 2 Minutes 121º, 4 Minutes 121º
10 Minutes 120º
Start temp 74.5º, 15 sec 104º, 2 Minutes 105º, 4 Minutes 107º
10 Minutes 102º
You can also take our Micro Vent Holes in cosideration as they do
flush cold air over the pulley/ belt interface. And as our proprietary surface
treatment and geometry will not allow belt squirm or slippage, thus not generate additional friction induced heat.
Bottom line is that our pulley does run cooler for many reasons, as indicated above.
Test equipment:
Dwyer top of the line IR Thermometer.
Bensomatic Propane Burner.
Eberhart & Co Chronograph.
Fire in the hole
Peter
Team M7 = Think outside the box
562-608-8123
vulkandino
Oct 31, 2015 08:29 PM
Emnotek
Sep 29, 2015 07:37 AM
Sep 25, 2015 11:46 AM
Sep 25, 2015 11:44 AM
