Drivetrain Foam Filters Explained!!!
Old Apr 22, 2005 | 12:52 PM
  #51
sfjames2's Avatar
sfjames2
ALTA, I removed my stock header a month or so ago and noticed a crusty build up on each of the header tube openings. I broke some off and rubbed it between my fingers and it was like fine grit. I suspected it got thru my foam filter and thru the K&N back on for piece of mind.
What would you suspect that stuff was? I had mine on there since the first AMVIV, prob. 9 months, 30,000 miles.
James
Old Apr 22, 2005 | 12:56 PM
  #52
minimonkey's Avatar
minimonkey
Thanks for the great education! I learned much. Thanks for taking the time.
Old Apr 22, 2005 | 04:13 PM
  #53
ALTA2's Avatar
ALTA2
Manufacturer
sfjames2,
This crusty stuff is pretty normal. It is a combination of oil (part of normal blow by, and the reason why all engines cosume oil in some amount), and deposits from gasoline. Generally this happens after a few thousand miles. I would guess with a few thousand miles and no Catch Can would cause this. I would guess if you analyzed the material, you would find carbon, and other deposits that may be found in gasoline.
minimonkey,
No problem, there is tons of info to be shared in this community, and nothing to hide about our products, so we don't mind telling everyone the real deal.
Old Apr 22, 2005 | 04:32 PM
  #54
sfjames2's Avatar
sfjames2
Originally Posted by ALTA2
sfjames2,
Thanks for responding, seen carbon build up in a exh. manifold before, but not like that. thanks again
James
Old May 15, 2005 | 09:25 PM
  #55
FUEGO's Avatar
FUEGO
Add me to the list for an Alta for an '05 MCC.
BTW - does the filter/intake difference apply to just the manual tranny because of the change to the GETRAG? Ours is a MCC w/CVT.
Filmy
15
Jun 6, 2023 06:27 AM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
rob&JCW
Sep 10, 2015 12:06 PM
Sep 10, 2015 11:55 AM
Sep 4, 2015 09:10 AM
