Drivetrain RMS/Webb Motorsports twinscrew
Originally Posted by RandyBMC
I will be after the testing, and with honest marketing.
Randy
Randy
that is what I needed to hear... HONEST
btw... I like sig.... careful of queens.... they sneak up on you and bite you in the.....
Just so it is clear - that wasn't my marketing hype...
Because of the rotor design, you do have more density than the Roots has.
Randy
Randy
Your theorhetical situation is wrong, and that may be what is hampering the idea for you. The water temp is lower than the intake charge - and you want to keep it that way.
Randy
Randy
Have you studied heat transfer or are you simply repeating what RMS told you about the design?
Sounds like you are questioning Webb's intelligence and ability.
What I would like to see is (and I will pay money for this)
Webb Mule
El Diablito Rojo
Andy@Ross-Tech's MINI
The above cars do a Car and Driver style challenge, using their driver or owners, doesnt matter. Overall wins. Other tuners more than welcome to partake.
There is enough in the challenge to cover 1/4 mile, 0-60, cornering, braking, etc etc.
The winner can add the sillhouette of the loser's cars to his door.
I can guarantee that my car is slower than either of the ones you listed above. I am just tired of vendors repeating marketing claims without understanding the science behind them. BTW, questioning whether someone has studied heat transfer has nothing to do with intelligence.
That makes no sense at all. Let's say you have 1 gallon of water at 100F and I pass it through a heat exchanger that is 50F at the rate of 1 gallon per minute. Now, let's say I have two systems, each of which have 1/2 gallon of water at 100F and I pass each of them through their own 50F heat exchanger at 1/2 gallon per minute. The amount of heat transfer is exactly the same.
The only difference I can see is the small amount of heat radiated from the hoses since you have more hose surface area.
BTW, without knowing the temp of the coolant, it's just as likely that the hoses are absorbing heat from the engine bay.
I agree with your point that resellers shouldn't necessarily be making claims that they don't understand. At the same time though, if you dispute those claims shouldn't you be taking it up with the manufacturer? It's not necessarily the place of a reseller to have to research and fact-check every product they sell - or in this case, may possibly sell in the future. Why is this really worth argueing about. One hose versus two is completely irrelevent and is not a sticking point on anyone's purchase decision.
I see your point, and in the grand scheme of things, one hose -vs- two does not have a lot of significance. I am just questioning Randy's statement that this IC is better BECAUSE it has two hoses. I haven't seen a plausible answer for that other than what you mentioned.
I also noticed that you have no WMS products on the car. None at all.
Quite frankly, Randy Webb does not fall into the phony clueless vendor category you refer to. The guy is genuine, like his passion for the car.
When you realise this, like many have, you're gonna tattoo his name to your butt.
I've never accused Randy of being a phony or a clueless vendor. I am simply asking him to back up his somewhat odd statements with scientific explanation. .
I don't think Nuzzo's car is all mini, by any means: Motronic and mechanical throttle, for example.
Andy's citing form Corky about relative boost/vs rpm would distinctly favor the twincharge route: using the low rpm boost building of the roots and the higher rpm and efficiency of the turbo.
Randy's explanation for the twin water flow is not sufficient yet. As I get it, each of the two water volumes (at the same temp and lowest (T1) they will get, since they are right out of the radiator) are introduced to the separate cores and will spend equal time in each core as they pass through. the core closer to the blower (air at T2) sees a delta of (T2-T1=combustion air temp-corewater temp). the water temp (and therefore its heat content, based on temp and proportional to mass) will rise depending on this delta plus a few other variables, like flow rate, conduction efficiency, etc. and the air temp will drop to T3. Since T2>T3, the water in the second core will heat up less.
now the water volumes mix again. I see no difference in the final heat energy being passed to the water as two 1/2 masses or one mass unless a Jeff has indicated, some other variable has changed, like conduction efficiency.
Randy's got a car to finish-up, and soon, as he's heading for the Bay Area tomorrow morining. And I know he's following-up on several buisness matters, one more me
. I don't think we can (or should) expect him on the boards at all times of the day. I'm sure he'll chime-in later...
The marketing info provided earlier can be found here:
http://www.kennebell.net/misc/class-act.htm
Just in the portion that dominicminicoopers referenced, it's apparent that they are poking fun at turbos, not so much other supercharger solutions (none were mentioned):
"....Maximum mid-range and low-end torque. No one can touch us in this area. "Instant maximum boost" means instantly more torque and horsepower when you punch it at any rpm above 2000...
....Unlike others that depend on rpm for boost (approx. 1-1.5 psi of boost per 1000 rpm), there's no waiting for the rpm to build with the Kenne Bell supercharger..."
The innuendo is supportive of supercharging (what they sell, of course), and in particular the twinscrew. With turbo comparisions being made in the thread at that time, it was provided for that reason. If one wants to draw conclusions from this info in relation to Eatons, do so at your own risk...
. I don't think we can (or should) expect him on the boards at all times of the day. I'm sure he'll chime-in later...The marketing info provided earlier can be found here:
My take is this: The water side is in parallel so the water inlet temps will be the same. The air sides of the cores are in series so the first core takes the brunt of the heat soak leaving the second core to stabilize the temps. I'd suspect the first core temp is higher than the second so the water outlet temps would differ as well until they mix. If the water temp is lower on the second core it will be able to absorb additional heat from the charge air. If the heat exchanger is large enough to dissipate the heat from the water I don't see why this wouldn't work.
[font=Times New Roman][size=3] [/size][/font]
If you have a water inlet on one side and the outlet on the other the water will have that much longer to heat up thus making the outlet side of the IC less efficient as the water is not cooling it as well being that it's gotten that much warmer.
If this same IC were cut to half the length then the water would have that much less chance to warm up making the outlet temp lower, ...thus becoming that much more efficient and cooling the IC more evenly as the outlet side is still running cooler water.
Make sense?
try this bit of reasoning, heh, heh!
assume the assertion is true, that twin core system results in a lower water temp than a single mass. If that is so, then a triple core system would be better, etc. But approaching the limit of an infinite number of cores is the same thing as a single core system. threfore, the assertion is false, QED
I have studied heat transfer - and I've had no information from RMS on the theory, those were my conclusions.
I have stated why I believe it works, and I know it works in practical testing - end of story.
I'm not getting my education into this, but I am well versed in these matters.
Randy
Randy
Heat exchangers occur naturally in the circulation system of whales. Arteries to the skin carrying warm blood are intertwined with veins from the skin carrying cold blood causing the warm arterial blood to exchange heat with the cold venous blood. This reduces overall heat loss by the whale when diving in cold waters.
Back from Under Review
This thread has been edited. Admittedly, probably not my cleanest edit, but given the length of the thread, it'll have to do for now.
Let's keep this thread on track (pun intended) from this point out (i.e. related to the RMS twinscrew).
Hopefully we won't have to pull out this handy tool.
Thanks for bringing it back. It's a great thread.
Now, when you seperate the water into two different areas, the total surface area of the container increases [you added two more contact sides for fluid to dissipate energy to, remember], while the volume stays the same [x/2 per zone]. True, the contact patch with the surface being 'intercooled' will not increase, but nevertheless the volume of the container (and its heat-dissipating efficiency) will increase.
In a two-zone system, there is less water per unit surface area. When temps plateau, the temp will be less than with a single zone, since there is more efficient heat discharge (more surface area with which to absorb/transfer). Surface area to volume is THE determining concept.
You are right, though to point out that eventually adding more zones will give fewer returns. The rate will not, however, even out to the cooling of a one zone system. The real-world limit would be one of balancing the diminishing returns with the dramatic increase in complexity of design, manufacturing, and install. 1,000 zones is just not practical, but two is better than one.
