How To oil catch can install question
Old Oct 26, 2019 | 06:24 AM
islandguy808's Avatar
islandguy808
I'm assembling all the parts to install an oil catch can on my 2010 MCS Clubman. I've watched many vids on youtube on how to do it. One method was to cut the crank case breather hose (?) and connect a separate hose to it from the occ. And I see some where you connect just two hoses directly from the occ to the valve cover and where you removed the breather hose. I don't feel comfortable with the first method cutting this hose. What if the connections don't fit? But looking into the 2nd method, where do you get those adapters to connect the hose to the valve cover and breather hose? Sorry if I'm not using the correct terms for these parts. my occ did not come with the adapters like the ones in the vids did.
Also I'm seeing 2 different opinions on a pcv delete, one says its a must if you have a occ and one says don't do it, it'll be too much pressure build up and it will blow the gaskets.
Thanks for your advice.
Old Feb 1, 2020 | 09:50 AM
minidd99's Avatar
minidd99
You can get the adapters from M7Tuning separately. Watch their vid.
Old Feb 1, 2020 | 10:44 AM
Jason Cornelius's Avatar
Jason Cornelius
my 09 clubby s
DIY OCC for under 50 bucks. DONT empty into solo cup, that’s why it red, gas eating cup. First empty after 2000 miles. Recommend check way more than that. I’m going to do it every fill up since I’m checking oil anyway. 140,000 on odu
Old Feb 1, 2020 | 10:48 AM
Jason Cornelius
only 2 videos needed and one of them has all the parts listed off of amazon.
- has parts listed
Old Feb 1, 2020 | 11:09 AM
Getn off's Avatar
Getn off
Im with Islandguy here. The turbo inlet side is easy as it is a rubber hose. The rear pcv hose is actually plastic inside and I am not sure how to seal it once cut. I think this is his question.
I decided not to install any for this reason. I am not convinced that the turbo side was that important, as opposed to the rear one.
Troy
Old Feb 1, 2020 | 11:13 AM
Jason Cornelius
Troy
You deleted the hose completely on the rear with these...https://www.ecstuning.com/Checkout/?...srep=jcrabtree Buy 2 of them and boom no more oil into intake. 2000 miles no cel and I’m at 140,000. Watch this vid.
Old Feb 1, 2020 | 11:27 AM
Getn off's Avatar
Getn off
I have considered that, but not 100% convinced that it is a good idea as of yet.
Troy
Old Feb 1, 2020 | 11:32 AM
Jason Cornelius
Troy
It didn’t even notice that it was done. I know I’ve only had it for 3 months, but there are plenty of threads about it, and with a OCC in place you got nothing to lose other than the 20 bucks and the time to do it. It took me under 30 min to delete it. Flat head and a T25 only things needed. If you break your hose I’ll send you mine for cost of shipping.
Old Feb 1, 2020 | 11:44 AM
Getn off's Avatar
Getn off
I guess I was a bit vague. I am not sure if blocking off the rear is a good idea. The designers wouldn’t add a line (cost) instead of sealing it off originally unless it had a benefit. I am not sure the exact purpose of both vents are honestly.
Troy
Old Feb 1, 2020 | 11:46 AM
Jason Cornelius
Troy
if I’m not mistaken that’s is one of the design changes on the n18 to help with carbon build up on the intake valves. And those plugs are mini parts btw they knew of issue.
Old Feb 23, 2020 | 05:14 AM
Yoshimura 1's Avatar
Yoshimura 1
Good information on the install.
Old Nov 9, 2024 | 11:34 AM
pkgmSu2000's Avatar
pkgmSu2000
On the fence about one or two cans. Lines are under vacuum and if you don’t clamp up the hoses or your budget can doesn’t hold seal, look out. The other option is air/oil separator. Other option is engine with dual port/direct injection.
phillipcoopersgates
Sep 10, 2013 07:22 PM
DarkMiniCooperS
How to
66
Apr 20, 2011 05:27 PM
johnD
Sep 12, 2005 09:26 AM
MSFITOY
Mar 9, 2004 08:08 PM
