Drivetrain Leaking Oil
Old Apr 3, 2019 | 05:59 AM
Stella11's Avatar
Stella11
Leaking Oil
Ok, so my son and I changed the o-ring on the crank positioning sensor and the oil pan gasket this pass weekend. I have not refilled the oil yet and this morning I noticed that there was oil under the car from the front of the motor. The oil appears to be straight down from the CPS but without oil in the motor yet I can't believe it would from that. I was dressed for work so I couldn't climb under it but does anyone have any ideas?
Old Apr 3, 2019 | 06:57 AM
BlwnAway's Avatar
BlwnAway
There isn't much in that area that can actually leak, besides the CPS O-Ring, esp with no oil added yet.
So that leads you to a few things:
- Motor oil that had pooled over time or while f doing the job, that you didn't catch on clean up.
- Motor oil trailing from somewhere else.
- Other oil trailing from somewhere else.
Unfortunately (or maybe not, for the experience and/or coolant refresh) this may call for putting the car in "Full" Service Mode, removing radiator and core support, for a thorough inspection.
Good Luck
Old Apr 3, 2019 | 07:06 AM
Stella11's Avatar
Stella11
I was thinking we would have to do full service mode, if nothing else to clean all the old oil off the motor. I didn't want to have to do that but I guess it looks like we'll be getting dirty again this weekend!
Old Apr 3, 2019 | 07:35 AM
BlwnAway's Avatar
BlwnAway
Personally, I think "Everyone" should have to do Full Service Mode at least once, if they plan on working in their own car, it's a great way to get a better understanding of how things are put together and work together.
Old Apr 3, 2019 | 08:37 AM
Stella11's Avatar
Stella11
I agree. I have minimal experience working on cars and none on Mini's but thanks to Youtube and friends, my son and I are slowly learning and enjoying it, when I don't lose bolts or that dang 10mm!
Old Apr 3, 2019 | 11:42 AM
cooper48's Avatar
cooper48
Once you go FESM, you'll be able to do it again in 20-30 minutes -- easier each time you do it. There is only 10-12 fasteners. You'll spend most of your time unhooking lights and horns. The beauty of FESM is that you get complete access to your motor, i.e., supercharger, water pump, generator, AC compressor, pulleys, etc. Makes it super easy to work on.
Old Apr 4, 2019 | 01:22 PM
Akumazeto's Avatar
Akumazeto
Would be even easier if there was a damn drain on the rad lol
Old Apr 4, 2019 | 01:25 PM
DneprDave's Avatar
DneprDave
What's FESM?
Old Apr 4, 2019 | 05:01 PM
cooper48's Avatar
cooper48
Front End Service Mode
Old Apr 4, 2019 | 05:20 PM
Stella11's Avatar
Stella11
So I went out and looked tonight, I think it's antifreeze leaking from the water pump. It appears to be coming from the drivers side of the supercharger. Good thing I bought a new water pump today.
Old Jun 3, 2019 | 02:42 PM
Mini invictus's Avatar
Mini invictus
You may not need to replace the water pump just the seal, or the hose.
Zechariah Retzloff
Aug 25, 2018 07:23 PM
MinisWIthAttitude
Apr 22, 2016 04:05 PM
Flying Sq
Mar 16, 2015 12:19 AM
Turbogeo
Apr 30, 2005 09:13 PM
OKMini
Classic Mini Talk
Apr 5, 2004 09:13 PM
