Oil leaking from oil drain plug
Old Mar 13, 2015 | 01:03 PM
Flying Sq's Avatar
Flying Sq
Hey, I have an 05 MCS, and I noticed oil was dripping from my car, I thought it was time for a gasket replacement, but after getting under the car to do a recent oil change, it seems like it is coming from the drain bolt. When I tried to tighten the bolt back up, it feels like it is bucking out once it is near fully threaded. It has to be spinning on the last thread. There is a point, where it tightens up, then loosens a bit, then I can bring it back around to the tight spot, all of it is above hand tight, not enough though. I don't know what could have happened. I did use a plastic crush washer, and before that I skipped swapping the metal one on the last two changes, could that be the issue?
Old Mar 13, 2015 | 01:08 PM
Pure Red's Avatar
Pure Red
sounds like thread wear or stripped threads. Although you have to drain the oil to do this, can you take a picture of both the drain plug and the oil pan with the drain plug out? Just capture the oil in a reuseable pan or container.
Old Mar 13, 2015 | 01:15 PM
Flying Sq's Avatar
Flying Sq
Yea, good thing it's the weekend and the weather should be decent. I'm fearing stripped threads, as I replaced the drain bolt with a magnetic one, so the old bolt shouldn't be an issue (still have it). Will probably have the pictures up by tomorrow afternoon.
Old Mar 13, 2015 | 01:39 PM
Sounds like threads are stripped.
Old Mar 13, 2015 | 01:46 PM
ti_tony's Avatar
ti_tony
If it is stripped you can wrap it with Teflon tape, put a little more than normal and tighten carefully. Buy you a little time till you figure out what to do.
Old Mar 13, 2015 | 01:50 PM
ZippyNH's Avatar
ZippyNH
The plug was made to be a ONE TIME use item...most use it a couple times...
First...try a new OEM pug..it has the rubber washer built in....
If the pans threads are stripped mildly...Teflon tape might help...if this is the case, I would install a "fumoto" drain valve...install it once and it is done....
Might need to tap new threads or use a thread replacement product...pan a new pan...if you make the old one work in some way...I would use the drain valve, aka a fumoto...
Old Mar 14, 2015 | 04:42 PM
rwkeating's Avatar
rwkeating
On top of what ZippyNH said "The plug was made to be a ONE TIME use item ...", you should also use a torque wrench when install the drain plug. I've always done that and have not had a leak, no stripped threads and the drain plug is always easy to remove.
I remember the first oil change I did after the dealers "free" oil change. Man was that drain plug hard to get off. I guarantee it was not torqued to spec!
Old Mar 15, 2015 | 02:53 PM
Eric_Rowland's Avatar
Eric_Rowland
My car came with the OEM oil temp gauge, which comes with a temp sensor integrated into the drain plug. After a dealer oil change, I noticed it dripping. Turns out they stripped the pan - the temp drain plug only has three or so threads on it. I just replaced it with a generic plug with a lot more threads - no problem. Miss my oil temp gauge, though.
Old Mar 15, 2015 | 03:13 PM
Capt_bj's Avatar
Capt_bj
OP might want to review
https://www.northamericanmotoring.co...n-threads.html
or any of the other threads on the GEN1 BUNG . . . .
Old Mar 16, 2015 | 12:19 AM
rikaro's Avatar
rikaro
Time for a new pan. Make sure you get a new gasket as well
part numbers
11137513061
11131487221
woodstudio
Mar 15, 2020 08:28 AM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
azntaiji
Aug 13, 2015 03:24 PM
