Drivetrain Downpipes (Overboost?)
Old 03-25-2019, 05:01 AM
Floydian's Avatar
Floydian
Floydian is offline
This is going to be a long thread so bear with me.
I have a 2015 BMW 120i F20 LCI with the N13 engine. (Turbo is Garrett MGT1549 ZDL)
It already has a K&N Drop in Filter, 70mm Cat-back exhaust, GFB DV+, Wagner Competition Intercooler, Racechip Ultimate, and NGK 5992 plugs from the Mini JCW, I run it on 99 Ron fuel.
I am planning on replacing the downpipe with a catless version, has anyone faced with boost spike or boost creep after fitting a catless downpipe on a piggyback tune such as Racechip? Unfortunately remapping the car is out of the question for me at the moment.
I posted here as the N13 engine is very similar to the N18.
Old 03-26-2019, 11:35 AM
PEneoark's Avatar
PEneoark
PEneoark is offline
Have you tried a BMW forum?
Old 03-26-2019, 11:45 AM
njaremka's Avatar
njaremka
njaremka is offline
Alliance Member
Received 1,718 Likes on 1,384 Posts
I thought the boost control improved when I replaced the down pipe with a cat-less version. With less back pressure, seems easier for the waste gate to control the boost pressure.
Old 03-26-2019, 02:28 PM
knt's Avatar
knt
knt is offline
Won't running a catless downpipe give you a dashboard error without a proper remap?
Old 03-27-2019, 03:31 AM
njaremka's Avatar
njaremka
njaremka is offline
Alliance Member
yes
Old 03-29-2019, 06:25 PM
Tigger2011's Avatar
Tigger2011
Tigger2011 is offline
Alliance Member
You should have no issues with boost spike going catless. It's common on Subaru's but BMW's control method is different. The racechip is the wildcard. Normally with the stock tune you lose a little bottom end but pick it up on top. With a proper tune its power across the board.
Old 04-04-2019, 04:06 AM
Floydian's Avatar
Floydian
Floydian is offline
No. Information on the N13/N18 is far more extensive here.
Yes it will, thats why I am planning to cancel any error codes from the downstream 02 sensor.
Thanks!
Old 04-04-2019, 04:08 AM
Floydian's Avatar
Floydian
Floydian is offline
Does anybody know if the downstream narrowband O2 sensor effect AFR and fuel trims on the N18 engine?
Old 04-04-2019, 06:34 AM
njaremka's Avatar
njaremka
njaremka is offline
Alliance Member
It does not. It's sole reason for existing is to monitor the cat efficiency.
inimmini
05-07-2012 09:42 AM
thestiguy
04-08-2007 06:39 AM
autoxguy305
12-14-2006 08:49 AM
MarioKart
11-27-2006 10:17 AM
DarkMiniCooperS
09-16-2005 11:33 AM
Quick Reply: Drivetrain Downpipes (Overboost?)
