Drivetrain Pulley Puller
Old Feb 14, 2019 | 04:50 AM
Stella11's Avatar
Stella11
Pulley Puller
Supercharger Pulley puller, Alta Performance or Cravenspeed? I have heard that the Cravenspeed can slip off when you're using it. I have not heard anything about the Alta.
Old Feb 14, 2019 | 06:16 AM
cooper48's Avatar
cooper48
Is this a question? MiniMania has a pulley puller that they'll loan to you (with a returnable deposit) if you buy their pulley. I did and everything works great!
Old Feb 14, 2019 | 07:15 AM
Stella11's Avatar
Stella11
It is a question, sorry. I'll have to check MiniMania out. Thanks!
Old Feb 14, 2019 | 08:20 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Not true unless you do something wrong or maybe had it upside down before you tightened it down. The Cravenspeed puller works great as that is what we use in our shop and what I have used to do about 400 pulleys. It is also the fastest and easiest to use as you don't need to mount a puller on it or remove the tensioner.
https://www.waymotorworks.com/pulley-puller.html
We also offer a deal if you buy our pulley kit
https://www.waymotorworks.com/wmw-pulley-package.html
Old Feb 14, 2019 | 08:41 AM
Andy_S's Avatar
Andy_S
I also rented the puller from Mini Mania. No hassles, I got my full deposit refunded. There were no instructions on returning it that I saw, but I emailed them and quickly got an RMA number.
I used a hardware store hose clamp / Jubilee Clip to keep the puller snugged down to the pulley. It took a lot of torque to initially break it loose. Definitely use some anti-seize or grease on the puller threads.
Old Feb 14, 2019 | 09:47 AM
andykrow's Avatar
andykrow
I have the Cravenspeed. Worked great and I'll never need it again. PM me if you want to grab it for half price.
Old Feb 14, 2019 | 11:16 AM
A383Wing's Avatar
A383Wing
When I changed the pulley on my R53 to a 15% pulley....I installed the removal tool and also put a large hose clamp around the tool and pulley just for peace of mind when I pulled it off.....may not have been necessary, but I felt a bit better about it
Bryan
Old Feb 14, 2019 | 05:12 PM
Aabaco_R53's Avatar
Aabaco_R53
The Alta one needs to have the supercharge off the car from what I’ve heard ... I got the cravenspeed one because I didn’t even have to remove the belt tensioner. It worked amazing and I didn’t have a single issue. I guess it could potentially slip off if you didn’t seat it properly when using it but I had zero issue and will highly recommend the cravenspeed one which I believe is identical to the WMW unit
Old Apr 18, 2021 | 03:37 PM
Simpletantra's Avatar
Simpletantra
I know it’s been a couple years, but you wouldn’t happen to still have the pulley puller would you?
Old Apr 19, 2021 | 08:43 AM
andykrow's Avatar
andykrow
Sorry, passed that along a couple years ago. Good luck!
Old Apr 19, 2021 | 10:13 AM
nd-photo.nl's Avatar
nd-photo.nl
Another happy customer of the Cravenspeed puller here, I can also recommend it
Old Mar 12, 2022 | 09:02 PM
NegativeNick's Avatar
NegativeNick
Lol. I bought a pulley from you Nov 2020. Asked about getting the pulley puller and your customer service told me to just buy one. I have emailed a few times about this, asking when I could get it so I can install my pulley, and every email is ignored.
bunce
Oct 9, 2008 09:12 PM
NiKTaMeR
Want to Buy - All Other Items (archive)
Apr 9, 2008 02:38 PM
KTOWN Z
May 9, 2007 06:39 PM
