Drivetrain Tuning a '06 factory JCW (E85, injectors, cams...)
Old Mar 4, 2019 | 10:50 AM
  #26
Revolution Motor Works's Avatar
Vendor
Originally Posted by BlwnAway
There will never be a factory ECU Flex-Fuel option for gen 1 cars, it's simply an out dated platform.
If you need to use the factory ECU for legal (inspections) reasons, your only option is to create separate maps for individual fuel types, and load them accordingly. Plus have all the necessary ancillary hardware as well. (Injectors, Fuel Pump, Regulator) Depending on the ethanol content.
the main problem is: fuel trimming with stock ecu
plus you don't know for sure how much ethanol you have in the tank which will lead to blown engines
my system, it always knows and makes corrections for it without you having to do anything except put the fuel in the tank and go
Old Mar 4, 2019 | 01:17 PM
  #27
SuN13300's Avatar
SuN13300
Originally Posted by Revolution Motor Works
its stand alone only. It's a full motorsport ecu with traction control, launch control, boost control, knock control, closed loop control..........etc etc
It has multi-fuel capabilities to run the flex fuel sensor, you tune the car on pump gas and all the way to e100 if you like
you set up the tables in the fuel system, timing etc to your car.
Ecu, is $1200
-6 fuel lines and all fittings to install, high flow fuel pump,boost-a pump, 1000cc injectors, auxiliary wiring harness to run sensors, flex fuel sensor and fuel pressure sensor $1375
Your system is definately the best engine control solution for flex fuel but I don't have that kind of money to put it that car...
I'm gonna have to switch tunes depending on the fuel but I think I'll run E85 most of the time. I put a new oem pump and filter and I'll see how it goes with ethanol.
Yes the software isn't made for flex fuel. I was asking because most of flex fuel kits are plugged in series with the injectors and adjust fueling artificially. Not the best way to do it but it works.
As you said I will have to create separate tunes. I have the 550cc injectors with stock (but new) fuel system. Why would you change the pressure regulator? stock fuel pressure is fine for me, what's your idea?
Stock ECU for sure can't handle real flex fuel. But if tuned correctly, I think it can handle 20% deviation in ethanol content. In France, super ethanol blend is made of E85 max in the summer and E65 min in the winter. If the tune is centered for E75 it will be fine knowing ethanol is less sensitive to knock and produce lower combustion temp.
Tuning will be fun I guess!
Old Mar 4, 2019 | 01:29 PM
  #28
BlwnAway's Avatar
BlwnAway
My bad, I forgot which thread this was, that was more of a blanket statement, it would really only be needed for ethanol fuels and high HP applications.
Old Mar 9, 2019 | 03:54 AM
  #29
SuN13300's Avatar
SuN13300
Injectors and clutch are installed.
We replaced all steering pump piping, installed powerflex bushings some vacuum lines that were damaged, transmission shafts, MAP sensors o-rings, CAM sensor o-rings, wheel bearings, shift box cables, fuel filter and fuel pump.
Scorpion exhaust manifold is being modified to install EGT sensor. Does anyone know the best location to pass Wideband and EGT sensor wiring inside the car?
Good thing we had the engine out, exhaust manifold had a leak and the cylinderhead could have been damaged :/
Old May 16, 2019 | 03:42 PM
  #30
Boostmaster's Avatar
Boostmaster
So nice to have the right tools for the job! Totally jealous.
5JCW6
Factory JCW Talk (2009+)
15
May 4, 2016 02:07 PM
Fuel-it!
Apr 13, 2016 07:12 PM
mcs_r53
Oct 17, 2013 09:28 PM
Guest
Dec 23, 2007 11:40 AM
mistro
Mar 14, 2007 05:32 PM
