Drivetrain New belt with 15% pulley?
Old Nov 21, 2004 | 01:57 AM
Prw3's Avatar
Prw3
Is a smaller length belt required with a 15% pulley?
Old Nov 21, 2004 | 03:38 AM
onasled's Avatar
onasled
........no.......
Old Nov 21, 2004 | 07:48 AM
tontobird's Avatar
tontobird
It is not required, but you may want to consider it. I have a 15% reduction pulley and have ordered the JCW belt to install in place of the stock sized belt. There are other manufacturers such as NAPA that have a smaller sized belt, as well. Perhaps someone will chime in with that info or you can so a search. I remember seeing the subject before.
Old Nov 22, 2004 | 09:10 AM
BlueMCS's Avatar
BlueMCS
Do it! Without it you are at the outside edge of the tensioner's range. No reason not to.
Old Nov 22, 2004 | 09:43 AM
apexer's Avatar
apexer
I have had the 15% for about 8K miles with stock belt. Still plenty of range on the tensioner... about 1/4 inch showing when installed and hasn't changed. Randy Webb doesn't change when he installs a 15% pulley. I've been to 3 of his Pully Parties and have watched him do over 45 installs.
Old Nov 22, 2004 | 09:48 AM
xsmini's Avatar
xsmini
I've had the 15% for about 20,000 miles now with the original belt. Tensioner still looks fine. I did order a JCW belt for when I do change it, probably around 60,000 miles or so.
Nik
Old Nov 22, 2004 | 09:50 AM
BlueMCS's Avatar
BlueMCS
I'm not comfortable unless I can see at least 1 hole in the tab at the top of the tensioner. That said, for general street use if your not getting into the high revs very often and it ain't slipping its probably just fine.
Old Nov 24, 2004 | 11:33 AM
TXMinee's Avatar
TXMinee
I know this sounds like a smart ***, but it really is the Aerospace Engineer coming out.... SO your point
Your example follows the logic that happen on the Apollo program. A 24 volt supply was hooked up to a 12 volt pump. On Apollo's 7-12 things were just find. On Apollo 13 things did not work so great and I think most people know the rest. Remember the oxygen tank bursting?
I know in Aerospace we are very critical of having things work to the n'th degree, but it is your car. I am looking into getting the JCW belt for my 15% pulley.
Gee do you think the Mini Engineers may have a clue???
Old Nov 24, 2004 | 11:38 AM
rajron's Avatar
rajron
Is that why they didn't go to 15%?
Old Nov 24, 2004 | 01:04 PM
TonyB's Avatar
TonyB
jlm's new tensionser might be the ticket for many.
Old Nov 24, 2004 | 01:08 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
FWIW, I've tried the JCW belt with my 15% pulley and it instantly started squealing like Ned Beatty in "Deliverance". Neither the well-worn stock belt, nor new or used 535's made the same kind of racket.
Old Nov 24, 2004 | 03:23 PM
apexer's Avatar
apexer
Anybody know for sure that the JCW belt is in fact shorter that the stock belt?
Old Nov 26, 2004 | 08:54 AM
BlueMCS's Avatar
BlueMCS
A reliable insider told me that Mini engineering spent a great deal of time makeing sure that the JCW belts would not be compatible with P&D or Alta pulleys. Now that's engineering!
Old Nov 26, 2004 | 10:09 AM
Minirox's Avatar
Minirox
Napa 060539 I found to be the ticket. Some have used the 060535 but its so tight you are putting the full force of the tensioner on it and causing it to wear out quicker due to the friction and to much tension.
Old Nov 26, 2004 | 10:18 AM
meanboy's Avatar
meanboy
SUUUUUUU WEEEEEEEEEEEEEEEE!!
Old Nov 26, 2004 | 10:25 AM
tontobird's Avatar
tontobird
That's fascinating, guess I'll soon find out!
elverado
Jan 18, 2022 02:51 AM
BernieCoop
Sep 10, 2021 03:15 AM
daviday
Sep 25, 2015 01:31 AM
makg
Sep 24, 2015 11:10 AM
Emnotek
Sep 11, 2015 04:16 PM
