Drivetrain catch can catch
Originally Posted by MSFITOY
How about one of them metal pot scrubbers that look like a ball of metal shaving?
Originally Posted by phase IV
So the Alta CC isn't made of metal (Al)? I would have thought it was. I guess I'll need to consider the M7 CC. I do like the bling factor (color choices) of the Alta though.
The Alta has not even been on there for a year yet. Thinking of getting m7's now.
When we started looking into making a catch can system we were told by our hose suppliers that oil and silicone do not play well together. The oil will start to penetrate the silicone hose and actually change the color as well as cause the material to break down. This is the reason for the aluminum can as well as non silicone hoses in our system.
Randy
Team M7
www.m7tuning.com
Randy
Team M7
www.m7tuning.com
Randy
Team M7
www.m7tuning.com
Randy
Team M7
www.m7tuning.com
silicone and oil = bad choice and the Vendors didn't tell you this?
I've been wondering when someone was going to catch on that silicone and oil aren't compatable.
Unless you use Fluoro-Silicone.
Fluoro-Silicone has properties that allow it to withstand extreme temperatures and pressures and will not break down in contact with engine oil.
Or use Fuel, Oil, Emissions, Hose it doesn't look as trick but it is made for the job.
Has anyone dug up the old posts here on oil catch cans?
Note: Silicone hose is NOT compatible with fuel or oil.
to sum up then:
it would seem that silicone is the wrong material due to oil reaction problems and collapsibility under vacuum;
the catch can should be sucked on by the blower intake tube and fed only from the PCV valve;
a stainless steel scrubby or chain should be inside to collect condensation;
one opinion is the can should be mounted low, so spooge collecting in the hose drains into the can rather than back where it came from.
the aluminum can from e-bay for $40 and a $0.65 scrub pad work pretty well;
What is special about the 3x more expensive M7 can?
the alta instructions to Tee into the crank vent and dump into the intake plugging the blower tube, seem at odds, as well as the collapsible silicone construction.
DIY oil catch can + older posts
There is more some where but if interested this will provide some reading on the subject.
Is this cyclic???? check out the date
https://www.northamericanmotoring.co...ad.php?t=15183
Build your own;
http://www.allpar.com/fix/pcv-breather.html
https://www.northamericanmotoring.co...ad.php?t=21971
Build your own;
a couple of pics; i just popped the can into the cowl well and used a foam bit to tuck it in. My opinion is higher is better so the hose can drain back into the head. I still have it hooked up the "alta way", but will change that soon enough.
Water in the Catch Can
I don't have a catch can on my S, but one of the reasons for water in the can could be condensation, especially if you route a hose to the ambient side of the throttle body.
Your catch can gets warm from the oil that goes into it as well as the warm gases passing through. As it cools down it will draw air from the ambient side of the system into the can and any water vapor in the air cools down as well
The catch can never gets hot enough to boil the condensation off, so it just keeps collecting and collecting. If it is on the engince side only, you get very little water vapor ingested, mostly oil and other solvent type vapors, thus no to little water collection in a can on the down side of the throttle body.
Seems to make sense to me, from a purely heat transfer/fluid flow point of view. Of course, I could be full of vapor myself . . .
Last edited by cheiron19; Nov 24, 2004 at 01:11 PM. Reason: Poor spelling skippy . . .
Considering the cost of some of those aftermarket catch cans, maybe it would be a better idea just to roll up some dollar bills and jam them in the breather lines. You could just throw them away or burn them when they get all gunked up.
can hook up
I have a Perrin that I picked up from Ebay. This is the same company that make Alta's. I've been collecting oil well. All I did was connect my catch can inline of the PVC valve and the supercharger. I called Alta and they said that if I wanted to keep the stock config but wanted to add the catch can, the best place was how I ended up doing.
Here is pic.
Here is pic.
Arly, where does the hose go that's running under the intercooler? Are you hooked into both crankcase vents or just the one on the left?
The one on the left is the partial throttle vent that normally just vents down under the intercooler while the one on the right is a full throttle vent that goes into the intake.
can
I just ran it to the tube that goes to the supercharger. I am planning on getting a smaller can for the intake side. A guy on ebay sells one for $11. This setup will catch oil from both sides.
MiniMotor: very interesting;
I thought I was following the Alta recommended hookup, but if what you are reporting is the right stuff, we need two catch cans, one in the PCV/vacuum circuit, one in the vent circuit. I'm changing my hookup to put the c-can only in the PVC circuit with the can-out going back to the blower in tube.
Now I need to find a piece of metal tubing to fit inside and reinforce the condenser. Makes me wonder if it's blown up like a ballon while under boost
Watch the shipping charges
$11.99 for shipping.
$23.98 delivered to your door.
a bit more than $12
