Drivetrain Newbie Question About Fuel Pump
Old Oct 17, 2018 | 03:54 PM
OJmini's Avatar
OJmini
Is it worth it to have and upgraded Fuel Pump if your Car is below 300whp? Im trying to decide if im going to swap pump now or swap pump later when i get enough funds for a rebuild engine.
Old Oct 17, 2018 | 09:15 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
It would help if you included what model/year you have. Otherwise the answer is "it depends." Then post this question in the appropriate forum section for your model. Unless you have a normally aspirated engine, then the answer is No.
Old Oct 17, 2018 | 09:22 PM
OJmini's Avatar
OJmini
Its on 05 r52 s
Old Oct 18, 2018 | 09:16 PM
squawSkiBum
Moderator
moving to where you should get some answers, or at least opinions.
Old Oct 19, 2018 | 08:07 AM
OJmini's Avatar
OJmini
thank you
Old Oct 20, 2018 | 02:01 PM
BlwnAway's Avatar
BlwnAway
I'll still using the stock fuel pump, and I'm over 300 whp, so it's not "needed".
​​​​​If you do decide you want to, look into the Deatschwerks, high flow replacement, 9 times out of 10 you don't need more pressure, just more flow.
Old Oct 26, 2018 | 09:02 PM
Mini_Crazy's Avatar
Mini_Crazy
OJ Mini has a 13 year old car. While a new OEM pump (Siemens VDO) will support 300hp, my 2005 was having fueling problems getting above 230hp level with the original pump. I replaced both pump and filter (one in each tank), and they looked filthy, even though I had been running name-brand TopTier fuel. Replacing both yielded positive results.
Some of the aftermarket brands (other than BMW-MINI or VDO) reportedly don't flow as well as the OEM pump.
Lopanda
Dec 23, 2024 07:11 PM
CorpsmanKid
Jan 3, 2020 06:05 AM
rob_lewis
Sep 14, 2017 08:03 AM
MaddyMini
R60/R61 Stock Problems/Issues
Jul 24, 2017 09:19 AM
warchieft2k
Feb 1, 2005 09:23 AM
