Drivetrain Air intake and filter question...
Old Aug 25, 2018 | 07:42 PM
brycewise11's Avatar
brycewise11
Why would I want to choose a cone, cylinder, or panel filter for my air intake? Is there any scenario where one makes a better choice over another? Also the DOS system looked like a great design but I think they are out of business...are there any similar products on the market?
Old Aug 25, 2018 | 10:13 PM
vetsvette's Avatar
vetsvette
Moderator
What model is your car?
Old Aug 26, 2018 | 02:11 PM
emilio.'s Avatar
emilio.
Seems like changing the stock airbox doesn’t give almost any power... maybe we can wait for Eventuri, but the price will be high...
Old Aug 26, 2018 | 08:11 PM
brycewise11
Its a 2009 R57 S, I accidentally posted in Gen 3, I meant to post in Gen 2
Old Aug 26, 2018 | 10:08 PM
MrGrumpy's Avatar
MrGrumpy
You’re not going to get much if any performance increase from one. Mostly what it does is make those sweet, sweet turbo sounds easier to hear. But the factory airbox does a good job of providing sufficient airflow. It is also a better cold air intake than most of the aftermarket intakes out there.
From personal experience, when was using a cone filter, it sounded awesome, and seemed to give me just the slightest bit more power at low rpm. But at the same time, my intake air temp was running about ten degrees hotter than with the factory airbox. In the middle of summer, that was enough by itself to make me decide to swap it back to the factory airbox, but then I installed a GFB DV+ diverter and it turns out that those are much quieter than the stock DV. So all of my sweet blow off noise went away and that made it a no-brainer for me.
Its really up to each individual how they choose to modify their car. For me the intake temps were more important than the noise and negligible performance increase, but somebody else may not care about a few degrees as much. As long as you are trying to do something to your car, you’re doing alright as far as I’m concerned.
Old Aug 26, 2018 | 10:17 PM
vetsvette's Avatar
vetsvette
Moderator
Moved thread to 2nd Gen.
Old Aug 27, 2018 | 06:57 AM
Qik420's Avatar
Qik420
As stated above, you won't get any performance gains by "upgrading" your intake. The factory CAI air flows great, at most all one would "need" to do is upgrade to that dry AFE panel drop in filter. Most aftermarket systems are actually hot air intakes that suck in engine bay air. Granted these engines being forced induction, the ambient air temps don't really matter BUT, any decrease in air temps is a plus in my book. I didn't like the cost of most aftermarket setups so pieced together my own version of the DOS intake. I initially did run the filter directly into the cowl just like the DOS, but found it to be too loud. I played around with a couple different "quieting" methods and in the end a couple of bends made the intake noises a bit more tolerable but still loud enough to hear the turbo. My original cowl cover ended up looking like swiss cheese but they're fairly cheap at around $40 on eMINIparts. I ordered the K&N Orion off Amazon and the intake tubing and clamps from intakehoses.com .
Old Aug 27, 2018 | 08:13 AM
MrGrumpy's Avatar
MrGrumpy
That is a pretty slick set up you have there! I’m very intrigued by it. If you wouldn’t mind, I’d like to know what you did there, is the filter in that canister? And are you drawing fresh air from the cowl area? It looks pretty awesome. Nice work.
Old Aug 27, 2018 | 08:38 AM
Qik420's Avatar
Qik420
You got it, filter is in the canister and it pulls air from the cowl. IAT's are right at (during non aggressive driving) ambient which ended up being 5-8 below what they were with the factory box. That long intake tube, I think, is the culprit, once the engine is hot it has to heat up that tube a good bit and transfers it to the air passing thru. I got the filter this past March for $94 on Amazon, but the price seems to have doubled since then. You could get away with installing it exactly like the DOS, it's real simple. Get the filter mounted to the MAF then line the other end where you want it to go into the cowl, mark and cut your hole. I lined the cut edge with 1" rubber hose I found at Home Depot, just cut a slit down the middle and stuck it round the cut edge on the cowl. If you go the DOS route you won't have to make a mounting situation for the filter like I have it.
https://www.knfilters.com/search/pro...x?prod=54-5000
Old Aug 27, 2018 | 08:50 AM
MrGrumpy's Avatar
MrGrumpy
That’s great, Thanks!
Qik420's Avatar
Qik420
This was a video I recorded when it ran right into the cowl. If I had to put a number on how much quieter the current setup is, I'd say it's maybe 10-15% quieter than what you hear in this video. 1st stop sign is regular acceleration, 2nd was more aggressive. Shifted early to get more turbo noise in before the wind took over.
Old Aug 27, 2018 | 09:34 AM
MrGrumpy's Avatar
MrGrumpy
Love that sound! I’m really tempted to remove my GFB DV+, but just can’t bring myself to do it. I love the blow off soiling the factory DV makes when it dumps! But the darn thing works so well holding more boost between shifts that I just can’t do it, lol. I think my eventual answer for my conundrum is probably to buy a Forge recirc valve, but I do really like how effective the DV+ is. I have an Alta spring too, I guess I could always go that route too.... it’s definitely cheaper, lol.
spcalan1
Apr 12, 2013 04:53 PM
andre lobe
Jul 27, 2011 10:01 PM
kukaepe
Jul 2, 2009 10:54 PM
fairmont
Mar 13, 2005 06:40 AM
ultramini
May 31, 2004 01:56 PM
