Drivetrain Supercharging Making Noise? Need more power?
Old Mar 10, 2018 | 01:58 PM
Revolution Motor Works's Avatar
Vendor
Back in 2007 I started looking for a better supercharger as a bolt on. I was looking for the TVS900 as it would be a good fit to make a direct replacement. Problem was, it wasn't available, only the much larger TVS1320 which required many changes to get it to fit. Not a cost effective kit. I built it , the kit was amazing from a power point but most wouldn't want to go to that extent at the time. (hold your hats as there will be a kit for this later this year from us) Then Harrop Engineering out of Australia got the rotor package for the TVS900 and a star was born. I got the first unit to test and fabricated my own kit with FMIC, custom billet intake manifold, custom 3" air box, 3" throttle body, electric water pump and heavy duty radiator. I also came up with a custom flex fuel system to maximize performance and allow for dumping anything from 91 pump gas to E85 into the tank and not having to worry as the Link G4+ stand alone system sorts it out. Large K&N flat panel filter for maximum air flow
RMW billet intake manifold
TVS900 with RMW 1.8L stroker on E85
Lower dyno run is: Cam/pulley/injectors/tune
Middle is BVH, Cam/pulley, header, injectors tune
Top graph is RMW 1.8L stroker with TVS900 FMIC on E85
RMW billet outlet flange to FMIC
Link G4+ stand alone ecu with RMW custom wiring harness for fuel pressure, flex fuel sensor, oil pressure/temp sensors and wideband
RMW billet inlet to supercharger flange
Old Mar 10, 2018 | 02:15 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
I am impressed!
Old Mar 10, 2018 | 02:19 PM
Vendor
there is one of these beasts up in Portland, you might see him at the track
Old Mar 10, 2018 | 02:22 PM
pnwR53S's Avatar
pnwR53S
Lane’s?
Old Mar 10, 2018 | 02:24 PM
Vendor
Originally Posted by pnwR53S
Lane’s?
yes sir........ask for a ride
Old Mar 10, 2018 | 02:28 PM
pnwR53S's Avatar
pnwR53S
I did. Alas there were too much traffic.
Old Mar 10, 2018 | 02:32 PM
Vendor
some fun cars to get a ride in if you can...........
Old Mar 10, 2018 | 03:58 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Holy Cow, looks who's back . . . . .
Old Mar 14, 2018 | 09:35 PM
downshift1's Avatar
downshift1
So if you add the intercooler and intake to the Harrop TVS kit would you expect similar numbers?
Old Mar 14, 2018 | 09:57 PM
Vendor
I'm making a kit that will adapt to it. Flex fuel and all
my kits have 3" throttle body and inlets which makes more power
hoping to make up some of the differences with more intercooling
Old Apr 5, 2018 | 05:37 AM
putttn's Avatar
putttn
Jan, what kind of HP can you attain with this setup? You tuned my car in Tacoma to 215 years ago. You also put in 450’s. It’s run great ever since but since I’m a old dog I need to get way more HP.
Old Apr 5, 2018 | 07:54 AM
Vendor
all depends on what mods are done to the car but it's capable of 360whp with the right mods and fuel
Old Apr 5, 2018 | 10:22 AM
putttn's Avatar
putttn
So the 400++ HP is turbo?
Old Apr 5, 2018 | 10:26 AM
Vendor
or a custom TVS1320 KIT ON E85 and built engine
Old Apr 5, 2018 | 10:37 AM
BlwnAway's Avatar
BlwnAway
Jan, whose WideBody kits are those, and what tire width are you able to run on those cars?
Old Apr 5, 2018 | 11:00 AM
Vendor
It's my kit
up to 275
Old Apr 5, 2018 | 11:36 AM
BlwnAway's Avatar
BlwnAway
It's my kit
up to 275
Can't find it in the store, can you give me or PM me pricing.
Mark
Old Apr 5, 2018 | 03:54 PM
putttn's Avatar
putttn
Mark
Add me to that PM Jan. Are you running these on the street?
Old Apr 6, 2018 | 07:35 PM
Vendor
Mark
the kit with FMIC bumper is $2000 + shipping
the one that fits stock front bumper for S is $1600 + shipping
yes
Old Apr 6, 2018 | 07:43 PM
BlwnAway's Avatar
BlwnAway
Excellent, thanks Jan.
That's the best looking Wide Body kit I've seen for the Mini.
Oh, is there body work/cutting required for tire clearance or do you just have to stay away from lowering springs.
I ask because my H-Sport and Yellows combo rub the outer edge of my inner fender well, when compressed already, and that's just with 215's
Old Apr 6, 2018 | 07:44 PM
Vendor
its better in person
Old Apr 7, 2018 | 08:44 AM
Vendor
you only need to cut the body up under the factory mounting, so you could go back to stock and never see that it was cut
Old Apr 7, 2018 | 10:30 AM
BlwnAway's Avatar
BlwnAway
Excellent, thanks.
Now back to TVS Talk....
Old Dec 9, 2018 | 05:46 PM
Akumazeto's Avatar
Akumazeto
What else would be required with this kit Jan? Low mileage mc40 looking for some um....PEP lol
Old Dec 9, 2018 | 07:35 PM
lotter1's Avatar
lotter1
there goes my tax refund!
K20K1LLA
Jul 24, 2020 10:21 AM
rickyr53
Dec 16, 2010 10:21 PM
k_h_d
Sep 26, 2008 06:30 AM
ChaChaCha
Tires, Wheels, & Brakes
Mar 6, 2008 06:44 PM
