Drivetrain NM Power module question
Old Jan 5, 2018 | 08:47 AM
tommyg's Avatar
tommyg
Just received mine yesterday, and a bit confused. It came with installation instructions, but nothing on the settings. I open it up and there's a 1 switch and a 2 switch, both in the down position.
Everything i've been reading says you can run it in stage 1 or stage 2. Want to make sure I understand how to set for each stage so I call NM. The lady told me that there is no stage 1 or stage 2, just leave both switches in the down position, they are only to be adjusted if there are issues.
Does this sound right? if not, appreciate any guidance on how to correctly set for each stage.
Old Jan 5, 2018 | 09:09 AM
2017All4's Avatar
2017All4
Super Moderator
http://www.nm-eng.com/media/attachme..._NM.648846.pdf
Old Jan 5, 2018 | 09:11 AM
tommyg's Avatar
tommyg
Mine is different from that. Actually an easier install, straight plug and play. There are no switches accessible on the bottom of the unit, I had to unscrew it to access the switches.
Old Jan 5, 2018 | 09:12 AM
2017All4's Avatar
2017All4
Super Moderator
Interesting. Same concept. Race mode is more boost but requires higher octane fuel.
Old Jan 5, 2018 | 09:14 AM
tommyg's Avatar
tommyg
This is mine:
http://www.nm-eng.com/media/attachme..._NM.648856.pdf
Maybe it is only one setting now?
Old Jan 5, 2018 | 09:37 AM
2017All4's Avatar
2017All4
Super Moderator
Ah, my mistake. I saw this in 3rd Gen so assumed you had a B series engine. Sorry.
Old Jan 5, 2018 | 09:42 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
yeah, wrong section. the F56 NM module is different
Old Jan 5, 2018 | 09:50 AM
tommyg's Avatar
tommyg
got it, my bad! I'm new to this thing, just got my Mini a few months ago.
Old Jan 5, 2018 | 10:07 AM
Mini_Vinnie
Moderator
Ha, all good man! Nothing wrong with doing research before you install stuff
fenderpicks
Jan 27, 2015 02:30 PM
kevshootz
Nov 27, 2007 12:58 AM
F15EWeapon
Feb 22, 2006 09:46 PM
haulin_oats
May 11, 2005 08:20 AM
GreyStreet
Oct 25, 2004 05:03 PM
